iRobot Roomba 690 Drive Wheels Replacement
    1. iRobot Roomba 690 Drive Wheels Replacement, Spinning Brush: step 1, image 1 of 1
      • Place the Roomba upside down so that the wheels and brushes are facing upward.
      Ask FixBot
    2. iRobot Roomba 690 Drive Wheels Replacement: step 2, image 1 of 3 iRobot Roomba 690 Drive Wheels Replacement: step 2, image 2 of 3 iRobot Roomba 690 Drive Wheels Replacement: step 2, image 3 of 3
      • Loosen the captive screw in the spinning brush using a Phillips #0 screwdriver.
      • Remove the spinning brush from the vacuum.
      Ask FixBot
    1. iRobot Roomba 690 Drive Wheels Replacement, Battery: step 3, image 1 of 1
      • Remove the four 6.4 mm screws from the bottom of the Roomba using a Phillips #0 screwdriver.
      • They are labeled with triangular arrows next to them on the cover.
      Ask FixBot
    2. iRobot Roomba 690 Drive Wheels Replacement: step 4, image 1 of 1
      • Lift the bottom cover up from the rest of the Roomba.
      Ask FixBot
    3. iRobot Roomba 690 Drive Wheels Replacement: step 5, image 1 of 3 iRobot Roomba 690 Drive Wheels Replacement: step 5, image 2 of 3 iRobot Roomba 690 Drive Wheels Replacement: step 5, image 3 of 3
      • Lift out the battery by pulling up on the two flexible tabs that are attached to the left and right sides.
      Ask FixBot
    1. iRobot Roomba 690 Drive Wheels Replacement, Drive Wheels: step 6, image 1 of 2 iRobot Roomba 690 Drive Wheels Replacement, Drive Wheels: step 6, image 2 of 2
      • Each drive wheel is labeled left and right.
      • Remove three 12 mm screws from each drive wheel using a Phillips #0 screwdriver.
      • Remove the drive wheels from the vacuum.
      Ask FixBot
John Galvin
584 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 36
All Time: 978
