iRobot Roomba 655 Pet Series Display Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
91
All Time:
1,457
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This is when things start to get a little more tricky. Start to be more careful because everything you are dealing with is attached to your motherboard from here on out.
Tools
    1. iRobot Roomba 655 Pet Series Display  Replacement, Front Face Plate: step 1, image 1 of 2 iRobot Roomba 655 Pet Series Display  Replacement, Front Face Plate: step 1, image 2 of 2
      • Remove the dust bin by pushing on the button for the dust bin removal
      • Pull the dust bin out
      Ask FixBot
    2. iRobot Roomba 655 Pet Series Display  Replacement: step 2, image 1 of 2 iRobot Roomba 655 Pet Series Display  Replacement: step 2, image 2 of 2
      • Pull up on the silver handle to release the top protectant plastic
      • Remove the top plastic carefully
      Ask FixBot
    1. iRobot Roomba 655 Pet Series Display  Replacement, Front Bumper: step 3, image 1 of 2 iRobot Roomba 655 Pet Series Display  Replacement, Front Bumper: step 3, image 2 of 2
      • Remove the ten 11mm screws that hold the front bumper to the plastic bumper protector with your Phillips #1 screwdriver.
      • Pull the plastic bumper protector up and off of the bumper.
      Ask FixBot
    2. iRobot Roomba 655 Pet Series Display  Replacement: step 4, image 1 of 3 iRobot Roomba 655 Pet Series Display  Replacement: step 4, image 2 of 3 iRobot Roomba 655 Pet Series Display  Replacement: step 4, image 3 of 3
      • Flip the Roomba back over, so you are viewing the top.
      • Pull up on the front bumper to remove it.
      • Be careful not to pull too hard because there is wiring attached to the bumper.
      • Remove the two 7mm screws with your Phillips #1 screwdriver, holding the wire sensors in place to the front bumper.
      Ask FixBot
    1. iRobot Roomba 655 Pet Series Display  Replacement, Internal Faceplate: step 5, image 1 of 3 iRobot Roomba 655 Pet Series Display  Replacement, Internal Faceplate: step 5, image 2 of 3 iRobot Roomba 655 Pet Series Display  Replacement, Internal Faceplate: step 5, image 3 of 3
      • The outside six - 10mm screws and the inside set of four - 10mm screws are the same here, use your Phillips head #2 to remove them
      • Use your Phillips head #0 to remove the one - 7mm bottom center screw
      • Use your Phillips head #2 to remove the two - 8mm screws by the handle
      • Push down the two release points to pull the plastic piece up
      • Pull the plastic piece up
      Ask FixBot
    1. iRobot Roomba 655 Pet Series Display  Replacement, Display: step 6, image 1 of 3 iRobot Roomba 655 Pet Series Display  Replacement, Display: step 6, image 2 of 3 iRobot Roomba 655 Pet Series Display  Replacement, Display: step 6, image 3 of 3
      • Pull the silver tab, and clear tinted display off
      • Remove the 4 - 9mm screws holding the display with your Phillips head #0
      Ask FixBot
    2. iRobot Roomba 655 Pet Series Display  Replacement: step 7, image 1 of 3 iRobot Roomba 655 Pet Series Display  Replacement: step 7, image 2 of 3 iRobot Roomba 655 Pet Series Display  Replacement: step 7, image 3 of 3
      • Remove the display
      • Remove the plastic protectant film from the motherboard
      Ask FixBot
Rhett
1,350 Reputation
7 Guides authored
Cal Poly, Team 21-20, Maness Winter 2015 Member of Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
4 Members
168 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 91
All Time: 1,457
