iRobot Roomba 595 Pet Series Wheel Spring Replacement
  1. iRobot Roomba 595 Pet Series Wheel Spring Replacement, Secondary Brush: step 1, image 1 of 1
    • Flip the Roomba upside down. Using the Phillips #0 screwdriver, carefully remove the 5 mm screw holding the brush in place.
    Ask FixBot
  2. iRobot Roomba 595 Pet Series Wheel Spring Replacement: step 2, image 1 of 1
    • Gently pull the brush up and remove it from the device.
    Ask FixBot
  3. iRobot Roomba 595 Pet Series Wheel Spring Replacement, Wheel Spring: step 3, image 1 of 2 iRobot Roomba 595 Pet Series Wheel Spring Replacement, Wheel Spring: step 3, image 2 of 2
    • Unscrew the four 10mm screws on the underside of the Roomba with a Phillips #1 screwdriver.
    • Remove the Roomba's external underside.
    Ask FixBot
  4. iRobot Roomba 595 Pet Series Wheel Spring Replacement: step 4, image 1 of 1
    • Remove the 15 mm screws with the Phillips #0 screwdriver bit.
    Ask FixBot
  5. iRobot Roomba 595 Pet Series Wheel Spring Replacement: step 5, image 1 of 1
    • Once the screws have been taken care of, the wheel component (with the spring inside) can be removed from the main assembly.
    Ask FixBot
  6. iRobot Roomba 595 Pet Series Wheel Spring Replacement: step 6, image 1 of 3 iRobot Roomba 595 Pet Series Wheel Spring Replacement: step 6, image 2 of 3 iRobot Roomba 595 Pet Series Wheel Spring Replacement: step 6, image 3 of 3
    • Remove the two 5mm screws in the component and gently twist the casing until the spring is exposed.
    • Carefully remove the spring from the component assembly as shown
    Ask FixBot
Dale Shirley-Potopsingh
446 Reputation
4 Guides authored
USF Tampa, Team S10-G5, Thompson Fall 2017 Member of USF Tampa, Team S10-G5, Thompson Fall 2017
USFT-THOMPSON-F17S10G5
3 Members
15 Guides authored
4 Guide Comments
My spring has fallen out and you don’t show where the spring attatches
Rebecca Hubber - Reply Share
Where can I get a new spring, mine is missing on the left wheel
emls23 - Reply Share
The bracket for the front (white and black) wheel broke. Where can I get a new one?
Kathryn Roberts - Reply Share
Where can I get a new spring for right wheel? Do these questions ever get answered?
KMF - Reply Share
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 51
All Time: 2,288
