iRobot Roomba 560 Handle Replacement
    1. iRobot Roomba 560 Handle Replacement, Side Sweeper: step 1, image 1 of 1
      • Flip the Roomba upside down.
      • Unscrew the single 5 mm screw on the yellow side sweeper using the Phillips #2 driver.
      Ask FixBot
    2. iRobot Roomba 560 Handle Replacement: step 2, image 1 of 1
      • Lift the yellow side sweeper, removing it from the device.
      Ask FixBot
    1. iRobot Roomba 560 Handle Replacement, Battery: step 3, image 1 of 1
      • Using the Phillips #2 driver, remove the four 10 mm screws that hold the back panel in place.
      Ask FixBot
    2. iRobot Roomba 560 Handle Replacement: step 4, image 1 of 1
      • Lift up the back panel to remove it from the device.
      Ask FixBot
    3. iRobot Roomba 560 Handle Replacement: step 5, image 1 of 2 iRobot Roomba 560 Handle Replacement: step 5, image 2 of 2
      • Lift up the yellow battery by pulling up the green tabs on its side.
      • Handle the battery with care.
      Ask FixBot
    1. iRobot Roomba 560 Handle Replacement, Clear Sensor Lens: step 6, image 1 of 1
      • Rotate the Roomba so the bumper is in front of you.
      Ask FixBot
    2. iRobot Roomba 560 Handle Replacement: step 7, image 1 of 1
      • Using the Phillips #1 driver, remove the ten 10 mm screws on the bumper that run along the outer edge of the Roomba.
      Ask FixBot
    3. iRobot Roomba 560 Handle Replacement: step 8, image 1 of 2 iRobot Roomba 560 Handle Replacement: step 8, image 2 of 2
      • Lift the thin top cover that holds the bumper in place.
      Ask FixBot
    4. iRobot Roomba 560 Handle Replacement: step 9, image 1 of 1
      • Gently lift the device upwards from the bumper to detach these two pieces.
      • There are wires connecting the bumper to the device. Be careful while lifting the device off the bumper as to not damage these wires.
      Ask FixBot
    5. iRobot Roomba 560 Handle Replacement: step 10, image 1 of 2 iRobot Roomba 560 Handle Replacement: step 10, image 2 of 2
      • Lift the bumper upwards for easier access.
      • Unscrew the two 5 mm screws that connect the red and white wires to the device using the Phillips #1 driver.
      • The sensor can be unplugged from the motherboard so the bumper isn't hanging off the Roomba.
      Ask FixBot
    6. iRobot Roomba 560 Handle Replacement: step 11, image 1 of 2 iRobot Roomba 560 Handle Replacement: step 11, image 2 of 2
      • Lift the circular black panel off the lens.
      • Lift the clear lens that is on the other side of the bumper and replace it with a new lens.
      Ask FixBot
    1. iRobot Roomba 560 Handle Replacement, Top Panels: step 12, image 1 of 2 iRobot Roomba 560 Handle Replacement, Top Panels: step 12, image 2 of 2
      • Turn the device over so that it is face up with the vacuum bin in front of you .
      • Press the button of the vacuum bin and pull out the bin from the device.
      Ask FixBot
    2. iRobot Roomba 560 Handle Replacement: step 13, image 1 of 1
      • Use your hands to unhook the snaps between the silver panel from the black panel located where the vacuum bin was.
      Ask FixBot
    3. iRobot Roomba 560 Handle Replacement: step 14, image 1 of 3 iRobot Roomba 560 Handle Replacement: step 14, image 2 of 3 iRobot Roomba 560 Handle Replacement: step 14, image 3 of 3
      • Using the plastic opening tool, go around the outer edges of the silver panel and unhook the snaps holding it in place.
      • When prying open the top panel from the inner casing, do so gently. Never "force" the top panel to snap off, or you could risk breaking pieces.
      Ask FixBot
    4. iRobot Roomba 560 Handle Replacement: step 15, image 1 of 2 iRobot Roomba 560 Handle Replacement: step 15, image 2 of 2
      • Lift the black handle and use the plastic opening tool to unhook the snaps underneath it.
      • Use the same tool to pry the silver cover from the black central control board.
      Ask FixBot
    5. iRobot Roomba 560 Handle Replacement: step 16, image 1 of 3 iRobot Roomba 560 Handle Replacement: step 16, image 2 of 3 iRobot Roomba 560 Handle Replacement: step 16, image 3 of 3
      • Lift the silver panel off of the black panel.
      Ask FixBot
    6. iRobot Roomba 560 Handle Replacement: step 17, image 1 of 1
      • Use a Phillips #2 screwdriver to remove the following screws:
      • Two 7.5 mm-long screws at either end of the semicircular handle
      • Ten 5 mm-long screws
      • Use a Phillips #1 screwdriver to remove the 5 mm-long screw at the bottom of the control board.
      Ask FixBot
    7. iRobot Roomba 560 Handle Replacement: step 18, image 1 of 1
      • Lift the black panel off the device.
      • This will provide access to the motherboard and black circular control panel.
      Ask FixBot
    1. iRobot Roomba 560 Handle Replacement, Handle: step 19, image 1 of 1
      • Hold the black panel in front of you with the handle facing the other side.
      • Locate the two hinges that will be pressed in the next step.
      Ask FixBot
    2. iRobot Roomba 560 Handle Replacement: step 20, image 1 of 2 iRobot Roomba 560 Handle Replacement: step 20, image 2 of 2
      • Rotate the black panel so that the handle is now facing you.
      • Insert your hands through the rectangular holes.
      • Using your index fingers, press the hinges that were located in the previous step.
      Ask FixBot
    3. iRobot Roomba 560 Handle Replacement: step 21, image 1 of 1
      • Lift the black handle for replacement.
      Ask FixBot
3 other people completed this guide.
Davis Negrete
176 Reputation
1 Guide authored
Cal Poly, Team 1-22, Maness Fall 2015 Member of Cal Poly, Team 1-22, Maness Fall 2015
CPSU-MANESS-F15S1G22
4 Members
84 Guides authored
1 Guide Comment
Pour avoir terminé, je préciserai qu'il y a un sens pour remonter la lentille sinon le pare chocs ne coulisse pas.
De même, il n´est pas nécessaire de changer la lentille. Remettre celle d'origine (si elle n´est pas abîmée) convient très bien.
Excellent tutoriel !
Fabien-Antoine CHAPELLE - Reply Share
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 48
All Time: 7,048
