iRobot Roomba 551 Brushes Replacement
    1. iRobot Roomba 551 Brushes Replacement, Side Brush: step 1, image 1 of 1
      • Place your Roomba upside-down on a hard surface.
      Ask FixBot
    2. iRobot Roomba 551 Brushes Replacement: step 2, image 1 of 1
      • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
      Ask FixBot
    3. iRobot Roomba 551 Brushes Replacement: step 3, image 1 of 1
      • Gently pull upwards on the brush to remove it.
      Ask FixBot
    1. iRobot Roomba 551 Brushes Replacement, Bottom Plate: step 4, image 1 of 1
      • Rotate the Roomba upside-down so the bottom is facing towards you.
      Ask FixBot
    2. iRobot Roomba 551 Brushes Replacement: step 5, image 1 of 2 iRobot Roomba 551 Brushes Replacement: step 5, image 2 of 2
      • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
      Ask FixBot
    3. iRobot Roomba 551 Brushes Replacement: step 6, image 1 of 1
      • Carefully lift the bottom plate.
      • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
      Ask FixBot
    1. iRobot Roomba 551 Brushes Replacement, Brushes: step 7, image 1 of 2 iRobot Roomba 551 Brushes Replacement, Brushes: step 7, image 2 of 2
      • Pinch the yellow tabs on the sides of the brush cage and lift up to open.
      Ask FixBot
    2. iRobot Roomba 551 Brushes Replacement: step 8, image 1 of 3 iRobot Roomba 551 Brushes Replacement: step 8, image 2 of 3 iRobot Roomba 551 Brushes Replacement: step 8, image 3 of 3
      • Grab each brush and lift upwards to remove.
      Ask FixBot
John McTigue
331 Reputation
3 Guides authored
Cal Poly, Team 13-14, Regan Winter 2014 Member of Cal Poly, Team 13-14, Regan Winter 2014
CPSU-REGAN-W14S13G14
4 Members
156 Guides authored
2 Guide Comments
Should be no need to remove the back plate. Just open the brush cage and lift out the brushes
Gunnar Nybraten - Reply Share
I did all that, bought a new brush cage and it is still announcing error 2-clean brushes.
Christa Eads - Reply Share
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 61
All Time: 10,514
