iRobot Roomba 551 Battery Replacement
    1. iRobot Roomba 551  Battery Replacement, Side Brush: step 1, image 1 of 1
      • Place your Roomba upside-down on a hard surface.
      Ask FixBot
    2. iRobot Roomba 551  Battery Replacement: step 2, image 1 of 1
      • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
      Ask FixBot
    3. iRobot Roomba 551  Battery Replacement: step 3, image 1 of 1
      • Gently pull upwards on the brush to remove it.
      Ask FixBot
    1. iRobot Roomba 551  Battery Replacement, Bottom Plate: step 4, image 1 of 1
      • Rotate the Roomba upside-down so the bottom is facing towards you.
      Ask FixBot
    2. iRobot Roomba 551  Battery Replacement: step 5, image 1 of 2 iRobot Roomba 551  Battery Replacement: step 5, image 2 of 2
      • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
      Ask FixBot
    3. iRobot Roomba 551  Battery Replacement: step 6, image 1 of 1
      • Carefully lift the bottom plate.
      • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
      Ask FixBot
    1. iRobot Roomba 551  Battery Replacement, Battery: step 7, image 1 of 2 iRobot Roomba 551  Battery Replacement, Battery: step 7, image 2 of 2
      • Lift and remove the old battery by pulling the tabs on both sides.
      • Gently replace with a new battery.
      Ask FixBot
6 other people completed this guide.
Deborah Newberry
623 Reputation
4 Guides authored
Cal Poly, Team 13-14, Regan Winter 2014 Member of Cal Poly, Team 13-14, Regan Winter 2014
CPSU-REGAN-W14S13G14
4 Members
156 Guides authored
1 Guide Comment
Thank you Deborah!
James - Reply Share
Past 24 Hours: 4
Past 7 Days: 13
Past 30 Days: 51
All Time: 12,075
