iRobot Roomba 4160 Brush Replacement
    1. iRobot Roomba 4160 Brush Replacement, Brush Guard: step 1, image 1 of 1
      • Make sure the Roomba is turned off to prevent injury.
      • Turn the Roomba upside down so that the underside is exposed. The wheels and brushes should be visible.
      • Identify the brush guard, which is the black rectangular frame that the metal rods are attached to.
      Ask FixBot
    2. iRobot Roomba 4160 Brush Replacement: step 2, image 1 of 1
      • Locate the 2 small rectangular yellow tabs on either side of the brush guard, directly adjacent to the blue flap.
      • Place index fingers on both tabs, and apply slight pressure in the direction of the yellow battery pack.
      • While you are applying pressure, the guard should hinge up in the direction of the yellow battery pack.
      Ask FixBot
    3. iRobot Roomba 4160 Brush Replacement: step 3, image 1 of 2 iRobot Roomba 4160 Brush Replacement: step 3, image 2 of 2
      • After the guard hinges up, lift the guard up and away from the Roomba.
      Ask FixBot
    1. iRobot Roomba 4160 Brush Replacement, Brush: step 4, image 1 of 1
      • Remove the wire brush by grabbing it by the yellow plastic part of the brush.
      • Pull the brush upwards until it comes out.
      Ask FixBot
    2. iRobot Roomba 4160 Brush Replacement: step 5, image 1 of 2 iRobot Roomba 4160 Brush Replacement: step 5, image 2 of 2
      • Remove the rubber spinning brush by grabbing it by the rubber part on both ends.
      • Pull the brush upwards until it dislodges.
      Ask FixBot
2 other people completed this guide.
noah falck
104 Reputation
1 Guide authored
Cal Poly, Team 6-4, Forte Spring 2014 Member of Cal Poly, Team 6-4, Forte Spring 2014
CPSU-FORTE-S14S6G4
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 88
All Time: 721
