iRobot Braava Jet 240 Wheel Replacement
    1. iRobot Braava Jet 240 Wheel Replacement, Battery: step 1, image 1 of 1
      • Turn the device off.
      Ask FixBot
    2. iRobot Braava Jet 240 Wheel Replacement: step 2, image 1 of 2 iRobot Braava Jet 240 Wheel Replacement: step 2, image 2 of 2
      • Use your fingers to gently pop out the battery.
      Ask FixBot
    1. iRobot Braava Jet 240 Wheel Replacement, Mop Pad: step 3, image 1 of 2 iRobot Braava Jet 240 Wheel Replacement, Mop Pad: step 3, image 2 of 2
      • Lift up the handle to reveal the eject button.
      Ask FixBot
    2. iRobot Braava Jet 240 Wheel Replacement: step 4, image 1 of 3 iRobot Braava Jet 240 Wheel Replacement: step 4, image 2 of 3 iRobot Braava Jet 240 Wheel Replacement: step 4, image 3 of 3
      • Use your finger to push the eject button forward.
      Ask FixBot
    3. iRobot Braava Jet 240 Wheel Replacement: step 5, image 1 of 1
      • Tilt the robot on its side and let the mop pad slide out.
      Ask FixBot
    1. iRobot Braava Jet 240 Wheel Replacement, Wheel: step 6, image 1 of 2 iRobot Braava Jet 240 Wheel Replacement, Wheel: step 6, image 2 of 2
      • Using your thumbs, first push back the motor assembly, then push up.
      Ask FixBot
    2. iRobot Braava Jet 240 Wheel Replacement: step 7, image 1 of 2 iRobot Braava Jet 240 Wheel Replacement: step 7, image 2 of 2
      • Remove the 11.55 mm screws in the middle of both wheels using the Phillips #1 screwdriver.
      Ask FixBot
    3. iRobot Braava Jet 240 Wheel Replacement: step 8, image 1 of 3 iRobot Braava Jet 240 Wheel Replacement: step 8, image 2 of 3 iRobot Braava Jet 240 Wheel Replacement: step 8, image 3 of 3
      • Pull the wheel off from the axel, pulling from the top end first so it can slide out at an angle.
      • It will be easier to remove the wheels if the motor assembly is tilted so that the wheel that you are removing is elevated.
      Ask FixBot
9 other people completed this guide.
Claire Franz
2,814 Reputation
7 Guides authored
Cal Poly, Team S22-G2, Regan Winter 2020 Member of Cal Poly, Team S22-G2, Regan Winter 2020
CPSU-REGAN-W20S22G2
5 Members
96 Guides authored
7 Guide Comments
Thank you so much!
Michaela - Reply Share
Where can I get the replacement wheels?
John
john - Reply Share
iRobot does not sell replacement parts for the 240, other than things like batteries. I look for dead As-Is units on eBay and buy them to scavenge parts. (And it really irks me that iRobot doesn't sell the parts!)
William Fickas - Reply Share
Thanks, William Fickas! I wish I knew this when I bought my 240. Selling their product but not keeping long term customers happy seems to be this company's mantra.
ejhcornelisse - Reply Share
Followed the guide and a spring fell out!? It has 5 turns and about 1" long with a 3/16" loop on one end? I'm thinking that I lifted the wheel assembly up just a bit too high. Any idea where that spring came from? Maybe somewhere in the middle of the assemble? Other than that the guide is perfect! Thank you and keep up the good work!
Bob Read - Reply Share
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 75
All Time: 10,974
