iRobot Braava Jet 240 Tank Replacement
    1. iRobot Braava Jet 240 Tank Replacement, Battery: step 1, image 1 of 1
      • Turn the device off.
      Ask FixBot
    2. iRobot Braava Jet 240 Tank Replacement: step 2, image 1 of 2 iRobot Braava Jet 240 Tank Replacement: step 2, image 2 of 2
      • Use your fingers to gently pop out the battery.
      Ask FixBot
    1. iRobot Braava Jet 240 Tank Replacement, Mop Pad: step 3, image 1 of 2 iRobot Braava Jet 240 Tank Replacement, Mop Pad: step 3, image 2 of 2
      • Lift up the handle to reveal the eject button.
      Ask FixBot
    2. iRobot Braava Jet 240 Tank Replacement: step 4, image 1 of 3 iRobot Braava Jet 240 Tank Replacement: step 4, image 2 of 3 iRobot Braava Jet 240 Tank Replacement: step 4, image 3 of 3
      • Use your finger to push the eject button forward.
      Ask FixBot
    3. iRobot Braava Jet 240 Tank Replacement: step 5, image 1 of 1
      • Tilt the robot on its side and let the mop pad slide out.
      Ask FixBot
    1. iRobot Braava Jet 240 Tank Replacement, Front Shell: step 6, image 1 of 2 iRobot Braava Jet 240 Tank Replacement, Front Shell: step 6, image 2 of 2
      • Remove the two 22.0 mm screws on the bottom-front of the robot using a Phillips #1 screwdriver.
      Ask FixBot
    2. iRobot Braava Jet 240 Tank Replacement: step 7, image 1 of 2 iRobot Braava Jet 240 Tank Replacement: step 7, image 2 of 2
      • Use a Phillips #1 screwdriver and an iFixit opening tool to remove the two 15.0 mm screws on the front sides of the robot.
      Ask FixBot
    3. iRobot Braava Jet 240 Tank Replacement: step 8, image 1 of 3 iRobot Braava Jet 240 Tank Replacement: step 8, image 2 of 3 iRobot Braava Jet 240 Tank Replacement: step 8, image 3 of 3
      • Carefully pull back on the front shell to remove it from the robot.
      Ask FixBot
    1. iRobot Braava Jet 240 Tank Replacement, Back Shell: step 9, image 1 of 2 iRobot Braava Jet 240 Tank Replacement, Back Shell: step 9, image 2 of 2
      • Insert a Phillips #1 screwdriver through the screw holes.
      • Unscrew the two 9.7 mm screws.
      Ask FixBot
    2. iRobot Braava Jet 240 Tank Replacement: step 10, image 1 of 2 iRobot Braava Jet 240 Tank Replacement: step 10, image 2 of 2
      • Unscrew the four 9.7 mm screws using a long neck #1 Phillips screwdriver.
      • If the screws are unscrewed but do not come out easily, turn the robot upside down and gently shake it.
      Ask FixBot
    3. iRobot Braava Jet 240 Tank Replacement: step 11, image 1 of 3 iRobot Braava Jet 240 Tank Replacement: step 11, image 2 of 3 iRobot Braava Jet 240 Tank Replacement: step 11, image 3 of 3
      • Pull up on the back shell to remove it from the robot.
      • For reassembly, pop the mop pad release trigger back into place if it fell out during back shell removal.
      Ask FixBot
    1. iRobot Braava Jet 240 Tank Replacement, Tank: step 12, image 1 of 2 iRobot Braava Jet 240 Tank Replacement, Tank: step 12, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the two 9.7 mm screws on the tank.
      Ask FixBot
    2. iRobot Braava Jet 240 Tank Replacement: step 13, image 1 of 3 iRobot Braava Jet 240 Tank Replacement: step 13, image 2 of 3 iRobot Braava Jet 240 Tank Replacement: step 13, image 3 of 3
      • Pull up on the L - shaped plastic piece and remove it from the tank assembly.
      Ask FixBot
    3. iRobot Braava Jet 240 Tank Replacement: step 14, image 1 of 2 iRobot Braava Jet 240 Tank Replacement: step 14, image 2 of 2
      • Lift the tank up and away from the device.
      • Don't pull the tank too hard because it is still attached to the water tube at the back.
      Ask FixBot
    4. iRobot Braava Jet 240 Tank Replacement: step 15, image 1 of 3 iRobot Braava Jet 240 Tank Replacement: step 15, image 2 of 3 iRobot Braava Jet 240 Tank Replacement: step 15, image 3 of 3
      • First pull up, then pull down on the spring to detach it from the hooks.
      Ask FixBot
    5. iRobot Braava Jet 240 Tank Replacement, Remove the motherboard case: step 16, image 1 of 2 iRobot Braava Jet 240 Tank Replacement, Remove the motherboard case: step 16, image 2 of 2
      • Lift up on the motherboard case to remove it from the device. This will expose the water tube that is attached to the tank.
      Ask FixBot
    6. iRobot Braava Jet 240 Tank Replacement: step 17, image 1 of 2 iRobot Braava Jet 240 Tank Replacement: step 17, image 2 of 2
      • Pull the tubing off of the tank connector.
      Ask FixBot
3 other people completed this guide.
Claire Franz
2,814 Reputation
7 Guides authored
Cal Poly, Team S22-G2, Regan Winter 2020 Member of Cal Poly, Team S22-G2, Regan Winter 2020
CPSU-REGAN-W20S22G2
5 Members
96 Guides authored
5 Guide Comments
Good guide. I would suggest doing steps 13-16 before step 12 and a small hook (bent wire, staple or the like) makes reattaching the spring (step 15) a lot easier. Otherwise, perfect.
Gareth Thomas - Reply Share
Thanks Claire for this. I have an issue and maybe you can help with it. https://imgur.com/a/Nw3nxrM
Thanks!
Diego Cacivio - Reply Share
I agree with moving steps 13-16 before step 12. Two reasons. First, it may be easier to remove the water tube from the tank while the tank is fastened in place. Second, removal of the motherboard case is an important building block step that provides access to free-floating platform, motors, tubing, and magnetic pads. I am roughing out a guide for removing the motherboard case built on this guide that you might be able to use. Feel free to edit it if you'd like.
Elven Decker - Reply Share
it would be nice if someone has a way to add an external water bottle to give more water to the unit. Thanks
Sing LoveTo - Reply Share
Okay tank is out….question is how do you CLEAN it ?
Daniel Rafanowicz - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 44
All Time: 4,914
