iRobot Braava Jet 240 Nozzle Replacement
  1. iRobot Braava Jet 240 Nozzle Replacement, Battery: step 1, image 1 of 1
    • Turn the device off.
    Ask FixBot
  2. iRobot Braava Jet 240 Nozzle Replacement: step 2, image 1 of 2 iRobot Braava Jet 240 Nozzle Replacement: step 2, image 2 of 2
    • Use your fingers to gently pop out the battery.
    Ask FixBot
  3. iRobot Braava Jet 240 Nozzle Replacement, Mop Pad: step 3, image 1 of 2 iRobot Braava Jet 240 Nozzle Replacement, Mop Pad: step 3, image 2 of 2
    • Lift up the handle to reveal the eject button.
    Ask FixBot
  4. iRobot Braava Jet 240 Nozzle Replacement: step 4, image 1 of 3 iRobot Braava Jet 240 Nozzle Replacement: step 4, image 2 of 3 iRobot Braava Jet 240 Nozzle Replacement: step 4, image 3 of 3
    • Use your finger to push the eject button forward.
    Ask FixBot
  5. iRobot Braava Jet 240 Nozzle Replacement: step 5, image 1 of 1
    • Tilt the robot on its side and let the mop pad slide out.
    Ask FixBot
  6. iRobot Braava Jet 240 Nozzle Replacement, Front Shell: step 6, image 1 of 2 iRobot Braava Jet 240 Nozzle Replacement, Front Shell: step 6, image 2 of 2
    • Remove the two 22.0 mm screws on the bottom-front of the robot using a Phillips #1 screwdriver.
    Ask FixBot
  7. iRobot Braava Jet 240 Nozzle Replacement: step 7, image 1 of 2 iRobot Braava Jet 240 Nozzle Replacement: step 7, image 2 of 2
    • Use a Phillips #1 screwdriver and an iFixit opening tool to remove the two 15.0 mm screws on the front sides of the robot.
    Ask FixBot
  8. iRobot Braava Jet 240 Nozzle Replacement: step 8, image 1 of 3 iRobot Braava Jet 240 Nozzle Replacement: step 8, image 2 of 3 iRobot Braava Jet 240 Nozzle Replacement: step 8, image 3 of 3
    • Carefully pull back on the front shell to remove it from the robot.
    Ask FixBot
  9. iRobot Braava Jet 240 Nozzle Replacement, Nozzle: step 9, image 1 of 2 iRobot Braava Jet 240 Nozzle Replacement, Nozzle: step 9, image 2 of 2
    • Pull the nozzle assembly away from the body of the robot.
    Ask FixBot
  10. iRobot Braava Jet 240 Nozzle Replacement: step 10, image 1 of 3 iRobot Braava Jet 240 Nozzle Replacement: step 10, image 2 of 3 iRobot Braava Jet 240 Nozzle Replacement: step 10, image 3 of 3
    • Using a Phillips #1 screwdriver, remove the 16 mm screw that holds the nozzle in place.
    Ask FixBot
  11. iRobot Braava Jet 240 Nozzle Replacement: step 11, image 1 of 1
    • Continue unscrewing the 16 mm screw until it comes out of the nozzle.
    Ask FixBot
  12. iRobot Braava Jet 240 Nozzle Replacement: step 12, image 1 of 3 iRobot Braava Jet 240 Nozzle Replacement: step 12, image 2 of 3 iRobot Braava Jet 240 Nozzle Replacement: step 12, image 3 of 3
    • Gently remove the tube from the nozzle.
    Ask FixBot
14 other people completed this guide.
Claire Franz
2,805 Reputation
7 Guides authored
Cal Poly, Team S22-G2, Regan Winter 2020 Member of Cal Poly, Team S22-G2, Regan Winter 2020
CPSU-REGAN-W20S22G2
5 Members
12 Guides authored
14 Guide Comments
Hi Claire! I have a guide for unclogging the pump after a prolonged storage duration, and I wish to use your photos and guide for the first half of the guide. Shall we collaborate on writing that guide?
Thanks!
Matt S - Reply Share
Hi Matt! That’s a great idea. It sounds like you’re wanting to use this Nozzle Replacement guide as a prerequisite guide for your guide on the pump, is that correct?
Claire Franz - Reply Share
If you’re like me and you have issues with the pump after a long duration in deep storage, there could be an issue with the tube within the pump where the pump would clog itself.
Follow all the steps to this guide, then look for the clear tube connected to the nozzle tube. You will see a circular black disk, with two metal pins and 2 metal wires on it. In the middle, there should be a Philips head screw. Use your #1 Screwdriver to unscrew the screw,
Next, carefully pull up on that black disk assembly. You will slowly pull up the tube. Be careful not to pull it too hard and puncture the tube.
Look at the clear tube. If you have stored it for too long, it is highly likely that the two white rollers on the black disk assembly have caused indents on the tube, causing a clog. Remedying that clog should be easy, gently press down on the tube on where the clog is, perpendicular to the clog. You should hear a little pop once the clog is unblocked. Repeat for the second clog, if required.
Following that, reassemble the machine going in reverse.
This problem should be a known issue for most Braava Jet 240s. There is no safe parking location for the pump for long storage, and the prolonged pressure on the clear tube will cause it to clog eventually.
Hope this helped and saved you from buying another Braava Jet.
IRobot doesn’t sell nozzle replacement.
Hiroko Takikita - Reply Share
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 123
All Time: 12,089
