iRobot Braava Jet 240 Filter Replacement
Views: 3.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
72
All Time:
3,171
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
If the filter on your iRobot Braava Jet 240 needs to be replaced, follow this guide.
The filter is located between the tank cover and the tank. The filter catches any residue that is in the water, ensuring that the iRobot Braava Jet 240 only sprays clean water. If the filter collects too much dirt, it needs to be removed and cleaned. The filter could also tear, in which case it should be replaced.
    1. iRobot Braava Jet 240 Filter Replacement, Battery: step 1, image 1 of 1
      • Turn the device off.
      Ask FixBot
    2. iRobot Braava Jet 240 Filter Replacement: step 2, image 1 of 2 iRobot Braava Jet 240 Filter Replacement: step 2, image 2 of 2
      • Use your fingers to gently pop out the battery.
      Ask FixBot
    1. iRobot Braava Jet 240 Filter Replacement, Filter: step 3, image 1 of 2 iRobot Braava Jet 240 Filter Replacement, Filter: step 3, image 2 of 2
      • Lift the handle to access the filter.
      Ask FixBot
    2. iRobot Braava Jet 240 Filter Replacement: step 4, image 1 of 3 iRobot Braava Jet 240 Filter Replacement: step 4, image 2 of 3 iRobot Braava Jet 240 Filter Replacement: step 4, image 3 of 3
      • Pull up the filter cover.
      Ask FixBot
    3. iRobot Braava Jet 240 Filter Replacement: step 5, image 1 of 3 iRobot Braava Jet 240 Filter Replacement: step 5, image 2 of 3 iRobot Braava Jet 240 Filter Replacement: step 5, image 3 of 3
      • Insert your finger into the filter and pull it up to remove it from the device.
      Ask FixBot
2 other people completed this guide.
Claire Franz
2,814 Reputation
7 Guides authored
Cal Poly, Team S22-G2, Regan Winter 2020 Member of Cal Poly, Team S22-G2, Regan Winter 2020
CPSU-REGAN-W20S22G2
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 72
All Time: 3,171
