iRobot Braava 380t Motor Replacement
    • Flip Braava upside down and loosen the screw between the two wheels.
    Ask FixBot
    • Lift the battery and disconnect the wire connecting the battery.
    Ask FixBot
    • Remove the cleaning pad and the four screws above the battery cavity.
    Ask FixBot
    • Flip Braava onto its wheels and pull the cover from the front. Take out the wire the connects the body and the cover.
    Ask FixBot
    • Hold the wheel of the defective motor and turn the wheel cover clockwise and take it out when it stops turning.
    Ask FixBot
    • Use a tweezer to take out the black clip that holds the wheel. Be careful: The clip can fly off.
    Ask FixBot
    • Pull out the wheel and take out the silver plate and two screws that hold the washer.
    Ask FixBot
    • Flip Braava upside down and peel back the sticker of the defective side and take out four screws. This will get you to the motor.
    Ask FixBot
    • Take out the cover and the cable that holds the motor. It is at the bottom corner of the motherboard. The left motor is at the left corner and the right motor is at the right corner.
    Ask FixBot
Glowing_Ice
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 18
All Time: 986
