Up to 20% off select tools
iRobot Braava 320 Body Shell Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
5
Past 7 Days:
19
Past 30 Days:
96
All Time:
1,294
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 - 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Although a cracked or broken body shell may not hinder the performance of your Braava, replacing it will help restore the cosmetic beauty of your device. It is a simple and straight forward replacement, requiring only four exposed screws to be removed.
    1. iRobot Braava 320 Body Shell Replacement, Battery: step 1, image 1 of 1
      • Flip your device over and locate the battery cover.
      • The battery cover is located in the center of the device in between both wheels.
      Ask FixBot
    2. iRobot Braava 320 Body Shell Replacement: step 2, image 1 of 1
      • Using a Flathead #4 screwdriver, gently turn the 12mm screw that holds the battery cover in.
      • The screw does not remove, it stays attached to the cover.
      Ask FixBot
    3. iRobot Braava 320 Body Shell Replacement: step 3, image 1 of 2 iRobot Braava 320 Body Shell Replacement: step 3, image 2 of 2
      • Gently remove the battery from the tray and disconnect the battery cable.
      • To remove the battery, pull it straight up. To disconnect the cable, gently pull it straight out of the connector.
      • To reinstall the cable, hold it near the end and gently push it in the connector.
      Ask FixBot
    1. iRobot Braava 320 Body Shell Replacement, Body Shell and Control Panel: step 4, image 1 of 1
      • With the battery removed, rotate your device so the front of it is facing you.
      • Remove the four 10mm Phillips #2 screws that attach the shell.
      Ask FixBot
    2. iRobot Braava 320 Body Shell Replacement: step 5, image 1 of 2 iRobot Braava 320 Body Shell Replacement: step 5, image 2 of 2
      • Using both hands, hold the device together while you flip it over.
      • Starting from the front, gently lift up the shell and slowly tilt back until it is fully removed.
      Ask FixBot
Author
with
Adam Lewis
234 Reputation
1 Guide authored
USF Tampa, Team S1-G3, Nance Spring 2017 Member of USF Tampa, Team S1-G3, Nance Spring 2017
USFT-NANCE-S17S1G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 96
All Time: 1,294
