Up to 20% off select tools
iRobot Braava 320 Battery Replacement
Views: 5.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
101
All Time:
5,497
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 2 minutes
Difficulty: Very easy
Tools
Introduction
Go to step 1 ↓
The battery is an essential component to the iRobot Braava 320. Without a functioning battery, your iRobot could have trouble turning on, staying on, or charging. Replacing the battery may solve these issues.
    1. iRobot Braava 320 Battery  Replacement, Battery: step 1, image 1 of 1
      • Flip your device over and locate the battery cover.
      • The battery cover is located in the center of the device in between both wheels.
      Ask FixBot
    2. iRobot Braava 320 Battery  Replacement: step 2, image 1 of 1
      • Using a Flathead #4 screwdriver, gently turn the 12mm screw that holds the battery cover in.
      • The screw does not remove, it stays attached to the cover.
      Ask FixBot
    3. iRobot Braava 320 Battery  Replacement: step 3, image 1 of 2 iRobot Braava 320 Battery  Replacement: step 3, image 2 of 2
      • Gently remove the battery from the tray and disconnect the battery cable.
      • To remove the battery, pull it straight up. To disconnect the cable, gently pull it straight out of the connector.
      • To reinstall the cable, hold it near the end and gently push it in the connector.
      Ask FixBot
Author
with
bradley boardwine
222 Reputation
2 Guides authored
USF Tampa, Team S1-G3, Nance Spring 2017 Member of USF Tampa, Team S1-G3, Nance Spring 2017
USFT-NANCE-S17S1G3
4 Members
60 Guides authored
1 Guide Comment
where do I get a new battery from?
j.svetlova - Reply Share
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 101
All Time: 5,497
