Using a Philips head #00 screwdriver locate and remove each of the four screws located along the tall side of the iRulu.
Tool used on this step:Tweezers$4.99
Using a pair of tweezers, gently disconnect the cable connectors from the circuit board.
Completely separate the screen and case.
Tool used on this step:Desoldering Pump$3.99
Insert the new speaker heads where the old speakers were previously.
Now use the soldering iron to solder the leads of the two speakers onto the logic board.
