Up to 20% off select tools
iRULU AX106 Disassembly
Views: 3.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
84
All Time:
3,273
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
In this disassembly guide the user will learn how to disassemble the iRULU down to the circuit board.
    1. iRULU AX106 Disassembly, iRULU AX106: step 1, image 1 of 1
      • Using a Philips head #00 screwdriver locate and remove each of the four screws located along the tall side of the iRulu.
      • There may be plastic covers protecting the screws, if this is the case take a phillips head screwdriver, and gently apply pressure on the covers until they come off.
      Ask FixBot
    2. iRULU AX106 Disassembly: step 2, image 1 of 2 iRULU AX106 Disassembly: step 2, image 2 of 2
      • Use the opening tool to pry the screen from the case applying pressure at each of the four corners of the screen.
      • While a good deal of force is required to separate the screen from the case, make sure to separate the screen from the case at each corner before attempting to completely remove the screen. There are delicate wires that may be damaged if the screen is removed is before the corners are separated.
      Ask FixBot
    3. iRULU AX106 Disassembly: step 3, image 1 of 3 iRULU AX106 Disassembly: step 3, image 2 of 3 iRULU AX106 Disassembly: step 3, image 3 of 3
      Tool used on this step:
      Buy
      Ask FixBot
3 other people completed this guide.
Author
with
Andrew Mele
146 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 84
All Time: 3,273
