iRULU AX106 Battery Replacement
Views: 4.6K
View statistics:
Past 24 Hours:
0
Past 7 Days:
6
Past 30 Days:
33
All Time:
4,640
Comments: 4
1 comment on steps, 3 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 1 hour
Difficulty: Difficult
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
The iRULU AX106 is a android tablet and due to the tablet being released in 2012 there is many things that will need to be replaced over the years. This guide requires the use of a soldering iron and also the use of a screwdriver. In this replacement guide the user will learn how to disassemble the iRULU down to the logic board, and replace the battery.
Tools
    1. iRULU AX106 Battery Replacement, iRULU AX106: step 1, image 1 of 1
      • Using a Philips head #00 screwdriver locate and remove each of the four screws located along the tall side of the iRulu.
      • There may be plastic covers protecting the screws, if this is the case take a phillips head screwdriver, and gently apply pressure on the covers until they come off.
      Ask FixBot
    2. iRULU AX106 Battery Replacement: step 2, image 1 of 2 iRULU AX106 Battery Replacement: step 2, image 2 of 2
      • Use the opening tool to pry the screen from the case applying pressure at each of the four corners of the screen.
      • While a good deal of force is required to separate the screen from the case, make sure to separate the screen from the case at each corner before attempting to completely remove the screen. There are delicate wires that may be damaged if the screen is removed is before the corners are separated.
      Ask FixBot
    3. iRULU AX106 Battery Replacement: step 3, image 1 of 3 iRULU AX106 Battery Replacement: step 3, image 2 of 3 iRULU AX106 Battery Replacement: step 3, image 3 of 3
      Tool used on this step:
      Buy
      Ask FixBot
    1. iRULU AX106 Battery Replacement, Battery: step 4, image 1 of 2 iRULU AX106 Battery Replacement, Battery: step 4, image 2 of 2
      • The battery is located right above the logic board, and can be identified as a large flat black rectangle.
      • Use the plastic opening to scrape away the glue that is holding down the battery.
      Ask FixBot
    2. iRULU AX106 Battery Replacement: step 5, image 1 of 1
      Desoldering Pump
      $3.99
      Buy
      • You should see that the battery is connected by 2 wires, one black and one red that lead to the logic board.
      • Make note of what color wire is soldered to the respective node before un-soldering the wires.
      • Heat up a soldering iron and melt the solder that is connecting the battery to the logic board.
      • Use a solder sucker to remove the solder as it melts, using caution to remove the wire.
      • Completely remove the battery from the device.
      • Insert the new battery and re-solder the corresponding wires to their respective locations.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
2 other people completed this guide.
James McLean
9 Reputation
1 Guide authored
3 Guide Comments
Where do you get a new battery
Janet dowdy - Reply Share
The batteries should be in a holder, not have to unsolder and solder. Most people do not have a soldering iron.
Lynn Buckingham - Reply Share
Is that a iPad battery?
Yanny 57 - Reply Share
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 33
All Time: 4,640
