iPod shuffle 3rd Generation Front Case Replacement
Views: 7.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
117
All Time:
7,390
Comments: 2
2 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
Replace a scratched front case to make your iPod Shuffle like new.
Tools
    1. iPod shuffle 3rd Generation Front Case Replacement, Rear Case: step 1, image 1 of 1
      • Widen the small gap between the front and rear case by inserting a metal spudger into the gap near the top of the iPod.
      • Be careful when using a metal spudger, as you may scratch the outer case.
      Ask FixBot
    2. iPod shuffle 3rd Generation Front Case Replacement: step 2, image 1 of 2 iPod shuffle 3rd Generation Front Case Replacement: step 2, image 2 of 2
      • Insert an iPod opening tool into the newly widened gap, and pry the rear case up and away from the front case.
      Ask FixBot
    3. iPod shuffle 3rd Generation Front Case Replacement: step 3, image 1 of 1
      • Insert the iPod Shuffle opening tool into the gap between the front and rear case on the same side, at the bottom corner of the iPod.
      • Pry the rear case away from the front case.
      Ask FixBot
    4. iPod shuffle 3rd Generation Front Case Replacement: step 4, image 1 of 1
      • Lift the bottom of the rear case and remove it from the rest of the iPod.
      Ask FixBot
    1. iPod shuffle 3rd Generation Front Case Replacement, Logic Board: step 5, image 1 of 1
      • Disconnect the headphone jack and shuffle switch connector by prying it off the logic board with a spudger.
      Ask FixBot
    2. iPod shuffle 3rd Generation Front Case Replacement: step 6, image 1 of 1
      • Remove the single Phillips screw securing the logic board to the front case.
      Ask FixBot
    3. iPod shuffle 3rd Generation Front Case Replacement: step 7, image 1 of 1
      • Peel the battery up from the front case with an iPod opening tool.
      • Remove the logic board and battery from the iPod.
      Ask FixBot
    1. iPod shuffle 3rd Generation Front Case Replacement, Headphone Jack & Shuffle Switch: step 8, image 1 of 1
      • Pry the headphone jack from the front case with an iPod opening tool.
      • Don't attempt to remove the headphone jack yet, it is connected to the shuffle switch.
      Ask FixBot
    2. iPod shuffle 3rd Generation Front Case Replacement: step 9, image 1 of 1
      • Using the pointed tip of a spudger, push the shuffle switch in to separate it from the front case.
      Ask FixBot
    3. iPod shuffle 3rd Generation Front Case Replacement: step 10, image 1 of 1
      • Remove the headphone jack and shuffle switch from the front case.
      Ask FixBot
2 other people completed this guide.
Matthew Newsom
43,117 Reputation
67 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 117
All Time: 7,390
