Tools
Spudger4.9
Introduction
Go to step 1 ↓Use this guide to replace the electronic portion of the power and volume controls as well as the plastic buttons on the exterior of the device.
The picture at left (front panel already removed) shows the locations of the metal clips (shown in red) that snap on to the plastic frame. In the next few steps, try to pry the front panel up from the gaps between these clips.
Insert a small iPod opening tool with the edge angled up toward the underside of the display between the white plastic backlight and the metal shield beneath it.
Pry up along the lower edge of the display enough to grab it with your fingers, being careful to not flex the screen.
Use the flat end of a spudger to pry the battery off the adhesive securing it to the metal display tray.
Remove the metal display tray and set it aside.
Lay the battery flat in the rear panel.
Remove the two Phillips screws securing the power/volume controls to the rear panel.
16 other people completed this guide.
1 Guide Comment
I would really recommend a brad new opening tool that has the edge in order to bite. I also had fairly good luck using the new iFlex.
