Up to 20% off select tools
iPod Shuffle 4th Generation Control Buttons Replacement
Views: 15K
View statistics:
Past 24 Hours:
6
Past 7 Days:
36
Past 30 Days:
153
All Time:
14,786
Comments: 10
8 comments on steps, 2 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Difficult
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
Introduction
Go to step 1 ↓
Replace the electronic portion of the control buttons.
    1. iPod Shuffle 4th Generation Control Buttons Replacement, Rear Panel: step 1, image 1 of 1
      • Accessing the internals of the 4th generation Shuffle is extremely difficult, as the rear panel is both glued to the front case and secured by metal retaining clips. It is highly unlikely that you will be able to remove the rear panel without inflicting cosmetic and/or structural damage.
      • Before proceeding, be sure your Shuffle is switched off.
      Ask FixBot
      • Use a heat gun, hairdryer, iOpener, etc. to heat the back of the Shuffle until it's slightly too hot to the touch.
      • If using a heat gun, only apply heat for a few seconds at a time. Check the temperature of the metal - if it gets too hot to handle, let it cool.
      Ask FixBot
    2. iPod Shuffle 4th Generation Control Buttons Replacement: step 3, image 1 of 2 iPod Shuffle 4th Generation Control Buttons Replacement: step 3, image 2 of 2
      • Use a combination of iPod opening tools and metal spudgers to pry the rear panel away from the Shuffle by the seam nearest the ON/OFF switch.
      • There are no clips on the top and bottom of the rear panel. With the Apple logo upright and facing you, all the clips are to the left and right.
      • If you use a metal spudger, you will scratch the housing.
      • You can try to pull on the rear panel by the clip. If you use too much force, you will bend the rear panel. If it feels stuck, stop and heat the glue to soften it.
      Ask FixBot
    3. iPod Shuffle 4th Generation Control Buttons Replacement: step 4, image 1 of 1
      • Remove the rear panel from the Shuffle.
      • There may be a piece of black rubber covering the logic board, or it may come out with the rear panel. This piece is part of a rubber seal that goes around the edges of the rear panel and covers the controls from the inside.
      Ask FixBot
    1. iPod Shuffle 4th Generation Control Buttons Replacement, Logic Board Assembly: step 5, image 1 of 1
      • If present, remove the thin black moisture seal covering the Shuffle's internals.
      • Remove the single 2.1 mm Phillips screw securing the logic board to the front case.
      Ask FixBot
    2. iPod Shuffle 4th Generation Control Buttons Replacement: step 6, image 1 of 2 iPod Shuffle 4th Generation Control Buttons Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Use the edge of an iPod opening tool to flip up the retaining flap on the control button cable ZIF socket.
      • Be sure you are prying up on the hinged retaining flap, not the socket itself.
      • Use a pair of tweezers to gently pull the control button ribbon cable out of its socket.
      Ask FixBot
    3. iPod Shuffle 4th Generation Control Buttons Replacement: step 7, image 1 of 2 iPod Shuffle 4th Generation Control Buttons Replacement: step 7, image 2 of 2
      • Use an iPod opening tool to gently pry the battery off the adhesive securing it to the front case.
      • Lift the battery out of the front case, being sure not to strain its delicate leads.
      Ask FixBot
    4. iPod Shuffle 4th Generation Control Buttons Replacement: step 8, image 1 of 2 iPod Shuffle 4th Generation Control Buttons Replacement: step 8, image 2 of 2
      • Insert the tip of a metal probe into the hole molded into the logic board retainer nearest the logic board.
      • Pry the retainer first away from the front of the front case, then pull it away from the side of the front case.
      • Remove the logic board retainer from the Shuffle.
      Ask FixBot
    5. iPod Shuffle 4th Generation Control Buttons Replacement: step 9, image 1 of 2 iPod Shuffle 4th Generation Control Buttons Replacement: step 9, image 2 of 2
      • Use the edge of an iPod opening tool to push the headphone jack down toward the center of the Shuffle.
      Ask FixBot
    6. iPod Shuffle 4th Generation Control Buttons Replacement: step 10, image 1 of 2 iPod Shuffle 4th Generation Control Buttons Replacement: step 10, image 2 of 2
      • Continue pushing the logic board down away from the top edge of the Shuffle.
      • Pull the logic board out of the front case by the side nearest the ON/OFF button and gently maneuver the headphone jack out of its recess in the front case.
      • Remove the logic board assembly from the Shuffle.
      Ask FixBot
    1. iPod Shuffle 4th Generation Control Buttons Replacement, Control Buttons: step 11, image 1 of 1
      • Remove the following four screws:
      • Two 1.2 mm Phillips screws with large heads.
      • Two 1.6 mm Phillips screws with small heads.
      Ask FixBot
    2. iPod Shuffle 4th Generation Control Buttons Replacement: step 12, image 1 of 2 iPod Shuffle 4th Generation Control Buttons Replacement: step 12, image 2 of 2
      • Use an iPod opening tool to pull the control button plate out of the front case.
      • Remove the control buttons from the Shuffle.
      Ask FixBot
7 other people completed this guide.
Author
with
2 Guide Comments
I'm gonna try to remove the back cover with minimal prying to reduce cosmetic defects. The plan is to somehow remove the spring loaded clip by pushing out the lever pin, then drilling holes along the edge of the over wherre the 3 little hooks are (In this image, where the right thumb is touching. https://d3nevzfk7ii3be.cloudfront.net/ig...).
It would be great if someone could provide a closer look at where exactly the hooks are so I can position my 1.5mm drill bit better. Also, if you can to figure out how to remove the spring loaded clip mechanism without going through the 4 screws, that'd be awesome! I suspect the pin is held in place by just adhesive, but don't want to risk pushing too hard and causing defects. :(
Sam Waiban - Reply Share
just open the clip past where it is suppose to open and it pops right off.
echow2001 - Reply Share
Past 24 Hours: 6
Past 7 Days: 36
Past 30 Days: 153
All Time: 14,786
