iPod Shuffle 3rd Generation Logic Board Replacement
    1. iPod Shuffle 3rd Generation Logic Board Replacement, Rear Case: step 1, image 1 of 1
      • Widen the small gap between the front and rear case by inserting a metal spudger into the gap near the top of the iPod.
      • Be careful when using a metal spudger, as you may scratch the outer case.
      Ask FixBot
    2. iPod Shuffle 3rd Generation Logic Board Replacement: step 2, image 1 of 2 iPod Shuffle 3rd Generation Logic Board Replacement: step 2, image 2 of 2
      • Insert an iPod opening tool into the newly widened gap, and pry the rear case up and away from the front case.
      Ask FixBot
    3. iPod Shuffle 3rd Generation Logic Board Replacement: step 3, image 1 of 1
      • Insert the iPod Shuffle opening tool into the gap between the front and rear case on the same side, at the bottom corner of the iPod.
      • Pry the rear case away from the front case.
      Ask FixBot
    4. iPod Shuffle 3rd Generation Logic Board Replacement: step 4, image 1 of 1
      • Lift the bottom of the rear case and remove it from the rest of the iPod.
      Ask FixBot
    1. iPod Shuffle 3rd Generation Logic Board Replacement, Logic Board: step 5, image 1 of 1
      • Disconnect the headphone jack and shuffle switch connector by prying it off the logic board with a spudger.
      Ask FixBot
    2. iPod Shuffle 3rd Generation Logic Board Replacement: step 6, image 1 of 1
      • Remove the single Phillips screw securing the logic board to the front case.
      Ask FixBot
    3. iPod Shuffle 3rd Generation Logic Board Replacement: step 7, image 1 of 1
      • Peel the battery up from the front case with an iPod opening tool.
      • Remove the logic board and battery from the iPod.
      Ask FixBot
2 other people completed this guide.
Matthew Newsom
42,936 Reputation
67 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 41
All Time: 7,132
