iPod Shuffle 2nd Generation Logic Board Assembly Replacement
    1. iPod Shuffle 2nd Generation Logic Board Assembly Replacement, Logic Board Assembly: step 1, image 1 of 1
      • Before beginning, be sure your Shuffle is turned off as shown.
      Ask FixBot
    2. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: step 2, image 1 of 2 iPod Shuffle 2nd Generation Logic Board Assembly Replacement: step 2, image 2 of 2
      • Use the edge of an iPod opening tool to pry the plastic cover off the headphone jack side of the Shuffle.
      • Remove the plastic cover and set it aside.
      Ask FixBot
    3. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: step 3, image 1 of 1
      • Remove the two Phillips screws from the headphone jack side of the Shuffle.
      Ask FixBot
    4. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: step 4, image 1 of 2 iPod Shuffle 2nd Generation Logic Board Assembly Replacement: step 4, image 2 of 2
      • Use the edge of an iPod opening tool to remove the steel cover from the headphone jack side of the Shuffle.
      Ask FixBot
    5. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: step 5, image 1 of 2 iPod Shuffle 2nd Generation Logic Board Assembly Replacement: step 5, image 2 of 2
      • Use the edge of an iPod opening tool to pry the plastic cover off the controls side of the Shuffle.
      Ask FixBot
    6. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: step 6, image 1 of 2 iPod Shuffle 2nd Generation Logic Board Assembly Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers to remove the hold and shuffle sliders from the Shuffle.
      Ask FixBot
    7. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: step 7, image 1 of 1
      • Remove the two Phillips screws on the controls side of the Shuffle.
      Ask FixBot
    8. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: step 8, image 1 of 2 iPod Shuffle 2nd Generation Logic Board Assembly Replacement: step 8, image 2 of 2
      • Use the edge of an iPod opening tool to remove the steel plate from the controls side of the Shuffle.
      Ask FixBot
    9. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: step 9, image 1 of 1
      • Use the edge of an iPod opening tool to slightly pry the steel plate on the headphone jack side of the Shuffle away from the lip cut into the outer case.
      Ask FixBot
    10. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: step 10, image 1 of 2 iPod Shuffle 2nd Generation Logic Board Assembly Replacement: step 10, image 2 of 2
      • Use your iPod opening tool to push the logic board assembly out of the outer case enough to grab the logic board by its edges.
      • Pull the logic board assembly out of the outer case.
      Ask FixBot
23 other people completed this guide.
1 Guide Comment
The screws are Phillips #000 - the Phillips #00 screwdriver is a bit too big and may strip them.
Sparky - Reply Share
Past 24 Hours: 0
Past 7 Days: 18
Past 30 Days: 80
All Time: 20,715
