Up to 20% off select tools
iPod Shuffle 1st Generation USB Port Replacement
Views: 20K
View statistics:
Past 24 Hours:
6
Past 7 Days:
27
Past 30 Days:
160
All Time:
20,263
Comments: 25
24 comments on steps, 1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 8
8 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Difficult
Parts
Tools
Introduction
Go to step 1 ↓
The USB connector on the bottom of the iPod.
    1. iPod Shuffle 1st Generation USB Port Replacement, Hold Switch: step 1, image 1 of 1
      • Before opening your iPod, ensure that the hold switch is in the locked position.
      Ask FixBot
    2. iPod Shuffle 1st Generation USB Port Replacement: step 2, image 1 of 1
      • Use a spudger to pry up the white plastic hold switch.
      Ask FixBot
    1. iPod Shuffle 1st Generation USB Port Replacement, Casing: step 3, image 1 of 1
      • If present, remove the cap from the USB port.
      Ask FixBot
    2. iPod Shuffle 1st Generation USB Port Replacement: step 4, image 1 of 1
      • The following step can be challenging and time consuming. Be sure to go slowly and have patience to prevent damaging your iPod.
      • Use an Exacto knife to separate the glue holding the USB port on the iPod. Run the knife along the seam between the two sections of the iPod until the glue is separated. Expect to run the knife along this edge 20-30 times before the glue will be entirely freed.
      Ask FixBot
    3. iPod Shuffle 1st Generation USB Port Replacement: step 5, image 1 of 1
      • Continue to run the knife around all four edges of the USB port until the glue is released. You may be able to gently wiggle the knife from side to side to help release the glue.
      Ask FixBot
    4. iPod Shuffle 1st Generation USB Port Replacement: step 6, image 1 of 1
      • Use a spudger to push on the headphone jack and slide the USB port out of its housing.
      • If the USB port doesn't come free, check to make sure all the glue holding the USB port in place has been released. Pulling on the USB port itself is not recommended as there is a fragile ribbon cable that can be ripped if the USB port suddenly comes free.
      Ask FixBot
    5. iPod Shuffle 1st Generation USB Port Replacement: step 7, image 1 of 1
      • After the USB port comes free, carefully slide it out of its housing. Don't pull it out too far because there's still a ribbon cable connecting it to the logic board.
      Ask FixBot
    6. iPod Shuffle 1st Generation USB Port Replacement: step 8, image 1 of 1
      • Continue to slide the iPod out of its casing by using a spudger to push on the logic board near the headphone jack.
      Ask FixBot
    7. iPod Shuffle 1st Generation USB Port Replacement: step 9, image 1 of 1
      • Turn the iPod so that the click wheel is facing up. This will prevent the battery indicator from falling out.
      • If the battery indicator does fall out, don't forget to replace it prior to reassembling the iPod. Getting the battery indicator back in place can be tricky. You'll have to slide it in from the end of the iPod's casing and get it to fall into its slot in the casing.
      • Slide the iPod out of its casing.
      Ask FixBot
    1. iPod Shuffle 1st Generation USB Port Replacement, USB Port: step 10, image 1 of 1
      • Use a spudger to flip up the black plastic tab holding the USB port ribbon in place. The black tab will rotate up 90 degrees, releasing the ribbon cable.
      Ask FixBot
    2. iPod Shuffle 1st Generation USB Port Replacement: step 11, image 1 of 1
      • Carefully peel the yellow USB ribbon up from the battery.
      Ask FixBot
    3. iPod Shuffle 1st Generation USB Port Replacement: step 12, image 1 of 1
      • Slide the USB ribbon out of its connector.
      • Lift the USB port and detached ribbon cable out of the iPod.
      Ask FixBot
5 other people completed this guide.
Author
with
iRobot
1 Reputation
632 Guides authored
1 Guide Comment
Will this be back in stock in the near future?
Maanav Patel - Reply Share
Past 24 Hours: 6
Past 7 Days: 27
Past 30 Days: 160
All Time: 20,263
