iPod Shuffle 1st Generation Battery & Logic Board Replacement
    1. iPod Shuffle 1st Generation Battery & Logic Board Replacement, Hold Switch: step 1, image 1 of 1
      • Before opening your iPod, ensure that the hold switch is in the locked position.
      Ask FixBot
    2. iPod Shuffle 1st Generation Battery & Logic Board Replacement: step 2, image 1 of 1
      • Use a spudger to pry up the white plastic hold switch.
      Ask FixBot
    1. iPod Shuffle 1st Generation Battery & Logic Board Replacement, Casing: step 3, image 1 of 1
      • If present, remove the cap from the USB port.
      Ask FixBot
    2. iPod Shuffle 1st Generation Battery & Logic Board Replacement: step 4, image 1 of 1
      • The following step can be challenging and time consuming. Be sure to go slowly and have patience to prevent damaging your iPod.
      • Use an Exacto knife to separate the glue holding the USB port on the iPod. Run the knife along the seam between the two sections of the iPod until the glue is separated. Expect to run the knife along this edge 20-30 times before the glue will be entirely freed.
      Ask FixBot
    3. iPod Shuffle 1st Generation Battery & Logic Board Replacement: step 5, image 1 of 1
      • Continue to run the knife around all four edges of the USB port until the glue is released. You may be able to gently wiggle the knife from side to side to help release the glue.
      Ask FixBot
    4. iPod Shuffle 1st Generation Battery & Logic Board Replacement: step 6, image 1 of 1
      • Use a spudger to push on the headphone jack and slide the USB port out of its housing.
      • If the USB port doesn't come free, check to make sure all the glue holding the USB port in place has been released. Pulling on the USB port itself is not recommended as there is a fragile ribbon cable that can be ripped if the USB port suddenly comes free.
      Ask FixBot
    5. iPod Shuffle 1st Generation Battery & Logic Board Replacement: step 7, image 1 of 1
      • After the USB port comes free, carefully slide it out of its housing. Don't pull it out too far because there's still a ribbon cable connecting it to the logic board.
      Ask FixBot
    6. iPod Shuffle 1st Generation Battery & Logic Board Replacement: step 8, image 1 of 1
      • Continue to slide the iPod out of its casing by using a spudger to push on the logic board near the headphone jack.
      Ask FixBot
    7. iPod Shuffle 1st Generation Battery & Logic Board Replacement: step 9, image 1 of 1
      • Turn the iPod so that the click wheel is facing up. This will prevent the battery indicator from falling out.
      • If the battery indicator does fall out, don't forget to replace it prior to reassembling the iPod. Getting the battery indicator back in place can be tricky. You'll have to slide it in from the end of the iPod's casing and get it to fall into its slot in the casing.
      • Slide the iPod out of its casing.
      Ask FixBot
    1. iPod Shuffle 1st Generation Battery & Logic Board Replacement, USB Port: step 10, image 1 of 1
      • Use a spudger to flip up the black plastic tab holding the USB port ribbon in place. The black tab will rotate up 90 degrees, releasing the ribbon cable.
      Ask FixBot
    2. iPod Shuffle 1st Generation Battery & Logic Board Replacement: step 11, image 1 of 1
      • Carefully peel the yellow USB ribbon up from the battery.
      Ask FixBot
    3. iPod Shuffle 1st Generation Battery & Logic Board Replacement: step 12, image 1 of 1
      • Slide the USB ribbon out of its connector.
      • Lift the USB port and detached ribbon cable out of the iPod.
      Ask FixBot
    1. iPod Shuffle 1st Generation Battery & Logic Board Replacement, Battery & Logic Board: step 13, image 1 of 1
      • Gently pull back the white plastic framework to free the left edge of the logic board. Pull up on the logic board slightly to prevent the logic board from falling back into place.
      Ask FixBot
    2. iPod Shuffle 1st Generation Battery & Logic Board Replacement: step 14, image 1 of 1
      • Repeat the same procedure on the opposite side to free the logic board from the white plastic casing.
      Ask FixBot
    3. iPod Shuffle 1st Generation Battery & Logic Board Replacement: step 15, image 1 of 1
      • Lift the logic board up to disconnect it from the memory board beneath. Don't remove the logic board from the iPod yet, because it's still connected to the battery.
      Ask FixBot
    4. iPod Shuffle 1st Generation Battery & Logic Board Replacement: step 16, image 1 of 1
      • Turn the iPod over and use your finger to push the battery through the hole in the casing. The battery is attached to the plastic framework with a mild adhesive.
      • Lift the battery and logic board out of the iPod.
      Ask FixBot
50 other people completed this guide.
iRobot
1 Reputation
632 Guides authored
5 Guide Comments
It would be helpful if the board images of the soldering process were included for these procedures. I have not tried the removal process and installation of the battery. And, why can’t we see an Ipod mini shuffle Gen 2? I can send you the one I own..
Jose - Reply Share
Not hard,i believe in u
Ryan Meyer - Reply Share
Can you add images of the soldering process for this Ipod Shuffle Gen 2 battery replacement? I can send you my device. I live and work in SLO.
Jose - Reply Share
Thanks, for this guide
Ben Capehart - Reply Share
Toll, die Anleitung erklärt nur 2/3 des Weges hin zu einer neuen Batterie.
Sehr anschaulich aber völlig wertlos. Jetzt habe ich einen säuberlich
zerlegten iPod und weiß nicht weiter.
Michael Beckers - Reply Share
Past 24 Hours: 17
Past 7 Days: 123
Past 30 Days: 574
All Time: 150,631
