iPod Nano 6th Generation Outer Case Replacement
    1. iPod Nano 6th Generation Outer Case Replacement, Front Panel Assembly: step 1, image 1 of 1
      • Use a heat gun or hair dryer to soften the adhesive securing the perimeter of the front panel assembly to the outer case.
      • Be careful not to overheat the front panel assembly, as it may result in damage to the LCD.
      Ask FixBot
    2. iPod Nano 6th Generation Outer Case Replacement: step 2, image 1 of 1
      • While the front panel is still warm, use the edge of an opening tool to pry it from the headphone jack side of the front panel assembly out of the Nano.
      • Do not attempt to pry out the front panel assembly from, or insert the opening tool into the left side of the display, as the display data cable is right underneath and may be damaged in the process.
      • Continue prying the perimeter of the front panel assembly out of the outer casing, being careful not to damage the display data cable held under its left edge.
      • If the front panel is excessively difficult to lift out of the outer case, reheat the area and try again.
      Ask FixBot
    3. iPod Nano 6th Generation Outer Case Replacement: step 3, image 1 of 2 iPod Nano 6th Generation Outer Case Replacement: step 3, image 2 of 2
      • Lift the front panel assembly from the headphone jack side of the Nano.
      • Pull the front panel assembly slightly away from the left side of the Nano to clear the display data cable.
      • The front panel assembly is still attached to the Nano by two cables.
      Ask FixBot
    4. iPod Nano 6th Generation Outer Case Replacement: step 4, image 1 of 1
      • Lay the front panel assembly next to the Nano.
      • Remove the following two screws:
      • One 2.3 mm Phillips screw
      • One 2.6 mm shouldered Phillips screw
      Ask FixBot
    5. iPod Nano 6th Generation Outer Case Replacement: step 5, image 1 of 2 iPod Nano 6th Generation Outer Case Replacement: step 5, image 2 of 2
      • Use an opening tool to pry the steel shield out of the Nano by its upper right corner.
      • Remove the steel shield from the Nano.
      Ask FixBot
    6. iPod Nano 6th Generation Outer Case Replacement: step 6, image 1 of 2 iPod Nano 6th Generation Outer Case Replacement: step 6, image 2 of 2
      • Use an opening tool to disconnect the display data and digitizer cable connectors up from their sockets on the logic board.
      Ask FixBot
    7. iPod Nano 6th Generation Outer Case Replacement: step 7, image 1 of 1
      • Remove the front panel assembly, minding its two cables that may get caught.
      • To reassemble, you can use the double-sided tape found here.
      Ask FixBot
    1. iPod Nano 6th Generation Outer Case Replacement, Logic Board Assembly: step 8, image 1 of 1
      • Use an iPod opening tool to lift the headphone jack assembly connector up and out of its socket on the logic board.
      Ask FixBot
    2. iPod Nano 6th Generation Outer Case Replacement: step 9, image 1 of 1
      • Remove the single 1.9 mm Phillips screw securing the logic board to the outer case.
      Ask FixBot
    3. iPod Nano 6th Generation Outer Case Replacement: step 10, image 1 of 2 iPod Nano 6th Generation Outer Case Replacement: step 10, image 2 of 2
      • Use an iPod opening tool to gently pry the battery up from the adhesive securing it to the outer case.
      • The adhesive is very strong. Work carefully and slowly, making sure to not slip and break any fragile components.
      • Use your thumb to pull the battery toward the left side of the Nano as you pry the battery's other edge out of the outer case.
      Ask FixBot
    4. iPod Nano 6th Generation Outer Case Replacement: step 11, image 1 of 1
      • Use an iPod opening tool to gently pry the logic board off the adhesive holding it against the outer case.
      • Do not excessively pry the logic board upward.
      Ask FixBot
    5. iPod Nano 6th Generation Outer Case Replacement: step 12, image 1 of 2 iPod Nano 6th Generation Outer Case Replacement: step 12, image 2 of 2
      • Use your iPod opening tool to gently push the dock connector toward the center of the Nano.
      • Remove the logic board assembly from the Nano, being careful not to damage the headphone jack assembly cable.
      Ask FixBot
    1. iPod Nano 6th Generation Outer Case Replacement, Headphone Jack Assembly: step 13, image 1 of 1
      • Remove the following five screws:
      • One 1.7 mm Phillips screw
      • Four 3.9 mm Phillips screws.
      Ask FixBot
    2. iPod Nano 6th Generation Outer Case Replacement: step 14, image 1 of 2 iPod Nano 6th Generation Outer Case Replacement: step 14, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers to carefully pull the headphone jack toward the center of the Nano.
      • Avoid pulling on the cable, as it is very thin and delicate. The plastic mounting ear is a safer area to pull on.
      Ask FixBot
    3. iPod Nano 6th Generation Outer Case Replacement: step 15, image 1 of 2 iPod Nano 6th Generation Outer Case Replacement: step 15, image 2 of 2
      • Very carefully pull the headphone jack assembly ribbon cable toward the dock connector to separate the sleep and volume buttons from the outer case.
      • Remove the headphone jack assembly.
      Ask FixBot
    1. iPod Nano 6th Generation Outer Case Replacement, Outer Case: step 16, image 1 of 1
      • Remove the following three screws:
      • One black 1.8 mm Phillips screw
      • Two 1.7 mm Phillips screws
      Ask FixBot
    2. iPod Nano 6th Generation Outer Case Replacement: step 17, image 1 of 1
      • Remove the clip from the outer case.
      • Outer case remains.
      • When reinstalling the clip, it is necessary to squeeze the base of the clip very tightly against the outer case as you insert the first screw.
      Ask FixBot
14 other people completed this guide.
2 Guide Comments
Step 9: This screw was missing on my iPod. It has been replaced by a rivet.
dave - Reply Share
Where can I buy a housing in any color (other than pink) for my ipod nano?
Tate Stevenson-House - Reply Share
Past 24 Hours: 0
Past 7 Days: 21
Past 30 Days: 116
All Time: 51,210
