iPod Nano 5th Generation Click Wheel Replacement
    1. iPod Nano 5th Generation Click Wheel Replacement, Click Wheel: step 1, image 1 of 3 iPod Nano 5th Generation Click Wheel Replacement, Click Wheel: step 1, image 2 of 3 iPod Nano 5th Generation Click Wheel Replacement, Click Wheel: step 1, image 3 of 3
      • Use a heat gun to soften the adhesive underneath the plastic bezel at the bottom of the iPod.
      • Use a low heat setting and do not hold the heat gun in place for too long to avoid melting the plastic bezel.
      • Use a plastic opening tool to pry the bezel from the case of the iPod and remove it.
      Ask FixBot
    2. iPod Nano 5th Generation Click Wheel Replacement: step 2, image 1 of 3 iPod Nano 5th Generation Click Wheel Replacement: step 2, image 2 of 3 iPod Nano 5th Generation Click Wheel Replacement: step 2, image 3 of 3
      • Unscrew two screws from the metal retainer at the bottom of the iPod:
      • 4.4 mm angled Phillips screw
      • 5.4 mm Phillips screw.
      • Even if they are loose, the screws may not come out on their own. Be sure not to lose the screws when removing the retainer.
      • Use a plastic opening tool to pry the metal retainer out from the bottom of the iPod and remove it.
      Ask FixBot
    3. iPod Nano 5th Generation Click Wheel Replacement: step 3, image 1 of 2 iPod Nano 5th Generation Click Wheel Replacement: step 3, image 2 of 2
      • Insert a metal spudger into the slot at the bottom of the iPod just above the dock connector.
      • Use the metal spudger to pry up the bottom edge of the click wheel.
      Ask FixBot
    4. iPod Nano 5th Generation Click Wheel Replacement: step 4, image 1 of 2 iPod Nano 5th Generation Click Wheel Replacement: step 4, image 2 of 2
      • Place a guitar pick between the click wheel and the case of the Nano and remove the metal spudger.
      • Pry up the edges of the click wheel with the guitar pick until the click wheel comes free from the case.
      • Do not try to completely remove the click wheel yet, as it is still held in place by a ribbon cable.
      Ask FixBot
    5. iPod Nano 5th Generation Click Wheel Replacement: step 5, image 1 of 2 iPod Nano 5th Generation Click Wheel Replacement: step 5, image 2 of 2
      • Lift the click wheel out of the way with one hand and use a plastic opening tool to pry the click wheel ribbon cable connector off its socket on the logic board.
      • Remove the click wheel.
      Ask FixBot
45 other people completed this guide.
David Hodson
156,748 Reputation
127 Guides authored
14 Guide Comments
I just replaced the click wheel on my iPod Nano 5th Gen and I found that this guide could be better. The reason is that the bottom edge of the click wheel is held in place by the same metal bracket that surrounds the connector port at the bottom of the iPod. So, before you remove the click wheel I recommend performing the following three steps:
1. Remove the plastic cover at the bottom of the iPod
2. Unscrew the two screws on either side of the connector port. Of the three screws at the bottom of the iPod, these are the middle and right hand screws as you look at the front of the iPod.
3. Remove the metal bracket that surrounds the connector port of the iPod.
After replacing the click wheel, perform the above three steps in reverse order. Make sure that when the metal bracket is re-inserted that it secures the click wheel and prevents it from falling out as some people have experienced after replacing the click wheel.
slith - Reply Share
I discovered the same solution after having destroyed one wheel by trying to pry it out without taking out that bottom bezel.That should definitely be the first step in this guide.
garyvirago - Reply Share
PLEASE READ slith's comment, it's extremely important, or you will not be able to get the click wheel installed. There are notches on the click wheel that have to go in at the top and bottom, but the bottom notch is PART OF THE GREY METAL BRACKET that you take out of the bottom of the iPod. DO NOT re-install the grey bracket at the bottom until you have installed the replacement click wheel, otherwise the wheel will not go in.
Thanks slith, I just wanted to emphasize this because I screwed up quite a few of these click wheels before I read your comment.
no way - Reply Share
Agreed. I ended up breaking 3 of my six tabs. It works but the wheel isn't quite flush now. Wish I'd looked at the tear down instructions first. That should be at the top of the list as well. This description just isn't at all complete.
mwm1962 - Reply Share
I agree with the other notes please see step 3 BEFORE 1&2
Keith - Reply Share
Past 24 Hours: 2
Past 7 Days: 34
Past 30 Days: 175
All Time: 72,693
