Up to 20% off select tools
iPod Nano 4th Generation Display Replacement
Views: 17K
View statistics:
Past 24 Hours:
0
Past 7 Days:
7
Past 30 Days:
50
All Time:
16,702
Comments: 74
73 comments on steps, 1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Difficult
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace a broken display.
    1. iPod Nano 4th Generation Display Replacement, Glass Panel: step 1, image 1 of 2 iPod Nano 4th Generation Display Replacement, Glass Panel: step 1, image 2 of 2
      • Insert the edge of an iPod opening tool into the gap between the outer case and the top bezel.
      • Pry the top bezel off the adhesive securing it to the display retainer.
      • At this point the hold switch slider is free and may fall. Be careful not to lose it.
      Ask FixBot
    2. iPod Nano 4th Generation Display Replacement: step 2, image 1 of 1
      • Remove the hold switch slider from the top of the Nano.
      Ask FixBot
    3. iPod Nano 4th Generation Display Replacement: step 3, image 1 of 1
      • Remove the two angled Phillips screws from the two corners of the display retainer.
      • These screw heads are extremely small and easily stripped.
      Ask FixBot
    4. iPod Nano 4th Generation Display Replacement: step 4, image 1 of 1
      • Insert an iPod opening tool between the outer case and the display retainer.
      • Use the tool to slide the display assembly out of the case slightly.
      • Do not rotate the display retainer about the top edge of the display, as it is attached to a thin steel bracket that is easily broken.
      • Do not forcefully remove the display retainer, as the hold switch cable is liable to snap.
      Ask FixBot
    5. iPod Nano 4th Generation Display Replacement: step 5, image 1 of 1
      • Slide the display out of the Nano. It will move about .5" until the display data cable limits its travel.
      • Do not put unnecessary tension on the very thin display data cable.
      Ask FixBot
    6. iPod Nano 4th Generation Display Replacement: step 6, image 1 of 2 iPod Nano 4th Generation Display Replacement: step 6, image 2 of 2
      • With the display pulled out of the case as much as possible, gently press on the lower edge of the glass panel until it pops in slightly (~1 mm).
      • Use your thumbs on the lower edge of the glass panel to slide the glass down and into the case until the top edge pops up out of the case.
      Ask FixBot
    7. iPod Nano 4th Generation Display Replacement: step 7, image 1 of 1
      • Lift the glass panel out of the Nano.
      • Before reinstalling the glass panel, be sure to clean the face of the display and the inside of the panel as any dust or fingerprints will be annoyingly visible when the Nano is turned on.
      Ask FixBot
    1. iPod Nano 4th Generation Display Replacement, Display: step 8, image 1 of 1
      • Use the edge of an iPod opening tool to separate the hold switch from the adhesive securing it to the top edge of the display.
      • The hold switch ribbon cable is extremely fragile and easily broken. Work gently.
      Ask FixBot
    2. iPod Nano 4th Generation Display Replacement: step 9, image 1 of 1
      • Peel back the Kapton tape covering the display data cable socket.
      Ask FixBot
    3. iPod Nano 4th Generation Display Replacement: step 10, image 1 of 1
      • While holding the light colored socket down with one finger, use the tip of a spudger to flip the ZIF cable lock up toward the bottom of the Nano.
      Ask FixBot
    4. iPod Nano 4th Generation Display Replacement: step 11, image 1 of 1
      • Use an iPod opening tool to peel the display data cable off the thin metal plate attached to the display.
      • Be careful not to rip the display data cable.
      Ask FixBot
    5. iPod Nano 4th Generation Display Replacement: step 12, image 1 of 1
      • Pull the display out of the Nano, minding the hold switch cable that may get caught.
      • As you pull the display out of the case, be careful not to break the hold switch cable.
      Ask FixBot
5 other people completed this guide.
Author
with
Walter Galan
712,031 Reputation
1,203 Guides authored
1 Guide Comment
I followed all the directions carefully, using the correct tools, and viola...I now have a working iPod. Thanks iFixIt! :)
deesouth3 - Reply Share
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 50
All Time: 16,702
