iPod Nano 2nd Generation Top Bezel Replacement
    1. iPod Nano 2nd Generation Top Bezel Replacement, Top Bezel: step 1, image 1 of 1
      • Before opening your iPod, ensure that the hold switch is in the locked position.
      Ask FixBot
    2. iPod Nano 2nd Generation Top Bezel Replacement: step 2, image 1 of 1
      • Carefully insert an iPod opening tool in the seam between the metal casing and white plastic top.
      • Lift the top bezel off the iPod. It's glued on using a mild adhesive, so some force may be required.
      Ask FixBot
12 other people completed this guide.
iRobot
1 Reputation
632 Guides authored
2 Guide Comments
But how do I install it on? Do I just push it back? I want to fix mine but it doesn't even have the top part anymore, or the hold switch
luis - Reply Share
I would recommend that you put some new adhesive on there. All you have to do is put the switch in its place and put on a new top and push it down.
Ad123re - Reply Share
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 62
All Time: 20,057
