Up to 20% off select tools
iPod Nano 1st Generation Click Wheel Button Replacement
Views: 15K
View statistics:
Past 24 Hours:
5
Past 7 Days:
32
Past 30 Days:
131
All Time:
14,989
Comments: 21
21 comments on steps.
Completed: 11
11 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
The button in the click wheel.
    1. iPod Nano 1st Generation Click Wheel Button Replacement, Rear Panel: step 1, image 1 of 1
      • Before opening your iPod, ensure that the hold switch is in the locked position.
      Ask FixBot
    2. iPod Nano 1st Generation Click Wheel Button Replacement: step 2, image 1 of 1
      • The rear panel is secured to the front case by eleven clips permanently attached to the rear panel. These clips lock onto small tabs machined into the front case.
      • To free the tabs, they must be pushed down and away from the iPod's case. Note the location of all tabs on the rear panel. When using an iPod opening tool to free the rear panel, be sure to work the tool at the location of these clips.
      Ask FixBot
    3. iPod Nano 1st Generation Click Wheel Button Replacement: step 3, image 1 of 2 iPod Nano 1st Generation Click Wheel Button Replacement: step 3, image 2 of 2
      • Opening the iPod can be challenging. Don't get discouraged if it takes you a few tries before the iPod is opened.
      • Insert the large iPod opening tool into the seam between the front case and rear panel of the iPod, below the dock connector. Run the tool back and forth to create an opening. The tool's edge should point toward the rear panel to prevent any accidental scratching of the aluminum front case.
      Ask FixBot
    4. iPod Nano 1st Generation Click Wheel Button Replacement: step 4, image 1 of 1
      • Insert a small iPod opening tool into the seam on the Hold button side of the iPod, with the edge of the tool pointing toward the rear panel.
      Ask FixBot
    5. iPod Nano 1st Generation Click Wheel Button Replacement: step 5, image 1 of 1
      • The large iPod opening tool is no longer needed to gain access to the left side of the iPod.
      • Gently enlarge the existing gap by pressing/wiggling the small iPod opening tool into the gap near each of the two tabs attached to the rear case, pushing the clips toward the center of the iPod until both have been freed.
      Ask FixBot
    6. iPod Nano 1st Generation Click Wheel Button Replacement: step 6, image 1 of 3 iPod Nano 1st Generation Click Wheel Button Replacement: step 6, image 2 of 3 iPod Nano 1st Generation Click Wheel Button Replacement: step 6, image 3 of 3
      • Repeat the same procedure listed in the previous step to free the five clips along the headphone jack side of the iPod.
      Ask FixBot
    7. iPod Nano 1st Generation Click Wheel Button Replacement: step 7, image 1 of 1
      • After ensuring all tabs are free, separate the two halves of the iPod.
      • The rear panel is now free from the iPod.
      Ask FixBot
    1. iPod Nano 1st Generation Click Wheel Button Replacement, Battery & Logic Board: step 8, image 1 of 1
      • Remove any kapton tape over the screws, if necessary.
      • Remove the following 3 screws:
      • Two 3 mm Phillips screws near the dock connector.
      • One 4 mm Phillips screw along the edge of the logic board.
      • During reassembly, make sure to put back any tape or plastic you remove. This will prevent any shorts between the logic board and the rear panel. If your tape is unusable, kapton tape can be purchased online.
      Ask FixBot
    2. iPod Nano 1st Generation Click Wheel Button Replacement: step 9, image 1 of 1
      • Peel up the ground strap connecting the battery to the logic board.
      Ask FixBot
    3. iPod Nano 1st Generation Click Wheel Button Replacement: step 10, image 1 of 2 iPod Nano 1st Generation Click Wheel Button Replacement: step 10, image 2 of 2
      • Insert the flat end of a spudger between the battery and the headphone jack side of the front case to pry the battery up off the adhesive securing it to the front case.
      • Rotate the battery out of the iPod and lay it next to the iPod. The battery is still soldered to the logic board by three wires, so don't remove it entirely.
      Ask FixBot
    4. iPod Nano 1st Generation Click Wheel Button Replacement: step 11, image 1 of 1
      • Gently lift up on the dock connector end of the logic board to ensure the logic board is free.
      Ask FixBot
    5. iPod Nano 1st Generation Click Wheel Button Replacement: step 12, image 1 of 1
      • Grasp the end of the logic board near the battery connector with one hand, and hold onto the rest of the iPod with your other hand.
      • Make sure the logic board is lifted slightly above the white plastic notch on the battery side of the board. This notch prevents the board from sliding out in the next step.
      • Slide the logic board out of its holding brackets on the rear of the display.
      • The logic board is still connected to the iPod by two ribbon cables.
      Ask FixBot
    6. iPod Nano 1st Generation Click Wheel Button Replacement: step 13, image 1 of 1
      • Disconnecting the following two ribbon cables may be challenging. To prevent straining the cables or connectors, you can only separate the two halves of the iPod about 1/2 inch during the process.
      • Use a spudger to flip up the black plastic tab holding the orange display ribbon in place. The black tab will rotate up 90 degrees, releasing the ribbon cable.
      Ask FixBot
    7. iPod Nano 1st Generation Click Wheel Button Replacement: step 14, image 1 of 1
      • Use a spudger to slide the display ribbon out of its connector.
      Ask FixBot
    8. iPod Nano 1st Generation Click Wheel Button Replacement: step 15, image 1 of 1
      • Use a spudger to flip up the black plastic tab holding the orange click wheel ribbon in place. The black tab will rotate up 90 degrees, releasing the ribbon cable.
      Ask FixBot
    9. iPod Nano 1st Generation Click Wheel Button Replacement: step 16, image 1 of 1
      • Use a spudger to slide the click wheel ribbon out of its connector.
      Ask FixBot
    10. iPod Nano 1st Generation Click Wheel Button Replacement: step 17, image 1 of 1
      • The logic board and battery are now free from the iPod.
      Ask FixBot
    1. iPod Nano 1st Generation Click Wheel Button Replacement, Display: step 18, image 1 of 1
      • Use a spudger to carefully pry up the adhesive holding down the edge of the display.
      • Be careful not to slide the spudger in too far to prevent scratching the display.
      Ask FixBot
    2. iPod Nano 1st Generation Click Wheel Button Replacement: step 19, image 1 of 1
      • Gently lift up on one corner of the display to separate the adhesive holding the display in place.
      • Lift up on the other corner of the display in the same manner.
      Ask FixBot
    3. iPod Nano 1st Generation Click Wheel Button Replacement: step 20, image 1 of 1
      • Lift the display up and out of the iPod.
      Ask FixBot
    4. iPod Nano 1st Generation Click Wheel Button Replacement: step 21, image 1 of 1
      • The display is now free from the iPod.
      Ask FixBot
    1. iPod Nano 1st Generation Click Wheel Button Replacement, Click Wheel Cover: step 22, image 1 of 1
      • Lift up on the click wheel cover and carefully thread the orange click wheel ribbon through the slot in the click wheel cover.
      • Lift the click wheel cover out of the iPod.
      Ask FixBot
    1. iPod Nano 1st Generation Click Wheel Button Replacement, Click Wheel Button: step 23, image 1 of 1
      • Push the click wheel button through from the front side of the iPod and lift it out of the iPod.
      Ask FixBot
11 other people completed this guide.
iRobot
1 Reputation
632 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 32
Past 30 Days: 131
All Time: 14,989
