Up to 20% off select tools
iPod 2nd Generation Hard Drive Replacement
Views: 20K
View statistics:
Past 24 Hours:
4
Past 7 Days:
27
Past 30 Days:
141
All Time:
20,068
Comments: 2
2 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
Upgrade your storage with a new hard drive.
    1. iPod 2nd Generation Hard Drive Replacement, Rear Panel: step 1, image 1 of 1
      • Before opening your iPod, ensure that the hold switch is in the locked position.
      Ask FixBot
    2. iPod 2nd Generation Hard Drive Replacement: step 2, image 1 of 1
      • Opening the iPod can be challenging. Don't get discouraged if it takes a few tries before the iPod is opened.
      • Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
      Ask FixBot
    3. iPod 2nd Generation Hard Drive Replacement: step 3, image 1 of 1
      • Continue to run the opening tool along the side of the case until all five tabs have been released.
      Ask FixBot
    4. iPod 2nd Generation Hard Drive Replacement: step 4, image 1 of 1
      • Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
      Ask FixBot
    5. iPod 2nd Generation Hard Drive Replacement: step 5, image 1 of 1
      • Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
      Ask FixBot
    6. iPod 2nd Generation Hard Drive Replacement: step 6, image 1 of 1
      • Lift the rear panel away from the iPod, making sure it doesn't catch on the headphone jack.
      Ask FixBot
    1. iPod 2nd Generation Hard Drive Replacement, Hard Drive: step 7, image 1 of 1
      • Peel up the metallic tape attached to the top of the battery.
      Ask FixBot
    2. iPod 2nd Generation Hard Drive Replacement: step 8, image 1 of 1
      • Lift the battery up from the hard drive and lay it next the the iPod (it is still connected to the logic board).
      Ask FixBot
    3. iPod 2nd Generation Hard Drive Replacement: step 9, image 1 of 1
      • Carefully disconnect the orange ribbon cable from the hard drive.
      • If the cable doesn't come free easily, it may be helpful to gently wiggle the cable from side to side.
      • Lift the hard drive out of the iPod.
      Ask FixBot
2 other people completed this guide.
Author
with
iRobot
1 Reputation
632 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 141
All Time: 20,068
