Up to 20% off select tools
iPod 2nd Generation Battery Replacement
Views: 36K
View statistics:
Past 24 Hours:
13
Past 7 Days:
67
Past 30 Days:
364
All Time:
36,391
Comments: 5
2 comments on steps, 3 guide comments.
Go to guide comments
Completed: 21
21 people have marked this guide "completed." Will you be next?
Favorites: 9
9 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
Battery not lasting long? Swap it out.
    1. iPod 2nd Generation Battery Replacement, Rear Panel: step 1, image 1 of 1
      • Before opening your iPod, ensure that the hold switch is in the locked position.
      Ask FixBot
    2. iPod 2nd Generation Battery Replacement: step 2, image 1 of 1
      • Opening the iPod can be challenging. Don't get discouraged if it takes a few tries before the iPod is opened.
      • Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
      Ask FixBot
    3. iPod 2nd Generation Battery Replacement: step 3, image 1 of 1
      • Continue to run the opening tool along the side of the case until all five tabs have been released.
      Ask FixBot
    4. iPod 2nd Generation Battery Replacement: step 4, image 1 of 1
      • Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
      Ask FixBot
    5. iPod 2nd Generation Battery Replacement: step 5, image 1 of 1
      • Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
      Ask FixBot
    6. iPod 2nd Generation Battery Replacement: step 6, image 1 of 1
      • Lift the rear panel away from the iPod, making sure it doesn't catch on the headphone jack.
      Ask FixBot
    1. iPod 2nd Generation Battery Replacement, Battery: step 7, image 1 of 1
      • Peel up the metallic tape attached to the top of the battery.
      Ask FixBot
    2. iPod 2nd Generation Battery Replacement: step 8, image 1 of 1
      • Lift the battery up from the hard drive and lay it next the the iPod (it is still connected to the logic board).
      Ask FixBot
    3. iPod 2nd Generation Battery Replacement: step 9, image 1 of 1
      • Lift up the end of the hard drive near the Firewire port to allow easy access to the battery connector.
      Ask FixBot
    4. iPod 2nd Generation Battery Replacement: step 10, image 1 of 1
      • Carefully disconnect the white battery connector from the logic board. Be sure to pull only on the connector itself and not on the cables.
      Ask FixBot
21 other people completed this guide.
Author
with
iRobot
1 Reputation
632 Guides authored
3 Guide Comments
Nice easy fix. Modern batteries are twice the capacity too. These old gen iPods are great. Nice to have an apple product not made in China.
peter barker - Reply Share
For my 2nd Generation iPod A1019 I found the batteries linked to at the beginning of this tutorial to be too thick to close the iPod without considerable force that actually seemed to bend and distort the display. Side by side they are nearly twice the thickness of the original battery. I bought both the 2200 mAh version, then also the 1600 mAh version hoping it would be thinner. All these batteries are manufactured by Cameron Sino. I am hoping to be able to find the actual Sony item and my search continues.
Kupe - Reply Share
In Step 4 "holding the iPod together near the dock connector": this iPod didn't get a dock connector. They came with later models. First charging: "Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery until it goes to sleep due to low battery. Wait at least 5 hours, then charge uninterrupted to 100%". If iFixit recommends it for laptops, why not for iPods?
jens wessel - Reply Share
Past 24 Hours: 13
Past 7 Days: 67
Past 30 Days: 364
All Time: 36,391
