iPod 1st Generation Scroll Wheel Replacement
    1. iPod 1st Generation Scroll Wheel Replacement, Turn on the Hold switch: step 1, image 1 of 1
      • Before beginning, be sure to activate the iPod's Hold switch to prevent the device from accidentally turning on.
      Ask FixBot
    2. iPod 1st Generation Scroll Wheel Replacement, Cut a Strip of Tape: step 2, image 1 of 1
      • Cut a strip of tape, preferably duct tape, about 6-8 inches long. Make sure it's wide enough to be able to cover the entire surface area of the Scroll Wheel
      • It is possible to use other types of tapes, like packing tape or stitched Scotch tape side-by-side, although it may take a few extra attempts in later steps.
      Ask FixBot
    3. iPod 1st Generation Scroll Wheel Replacement, Prepping the iPod: step 3, image 1 of 3 iPod 1st Generation Scroll Wheel Replacement, Prepping the iPod: step 3, image 2 of 3 iPod 1st Generation Scroll Wheel Replacement, Prepping the iPod: step 3, image 3 of 3
      • Lay the iPod flat on a solid table, then lay the strip of tape flat onto the Scroll Wheel, then press down on the entire surface of the Scroll Wheel & center Select button.
      Ask FixBot
      • With one hand firmly grasping the iPod, pull the strip of tape upwards with your other to remove the Scroll Wheel from it's housing.
      • Be sure beforehand to slowly peel the tape off of the other buttons to prevent them from being pulled off as well, notably the Play/Pause button & the Menu button
      Ask FixBot
    4. iPod 1st Generation Scroll Wheel Replacement, Remove Wheel parts from tape: step 5, image 1 of 3 iPod 1st Generation Scroll Wheel Replacement, Remove Wheel parts from tape: step 5, image 2 of 3 iPod 1st Generation Scroll Wheel Replacement, Remove Wheel parts from tape: step 5, image 3 of 3
      • Simply peel off the Scroll Wheel & it's Select button from the strip of tape
      Ask FixBot
    5. iPod 1st Generation Scroll Wheel Replacement, Done: step 6, image 1 of 1
      • Congratulations! You've successfully removed the Scroll Wheel from your iPod 1st Gen.
      Ask FixBot
To reassemble your device, put the main Scroll Wheel mechanism back in first, followed by the center Select button.
edoogg
133 Reputation
1 Guide authored
2 Guide Comments
Very brutal and very effective.
Montary - Reply Share
Made me laugh of how rudimental it is but how effective it is, is like making a depilation to the iPod
Foxy the dj - Reply Share
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 114
All Time: 1,350
