Up to 20% off select tools
iPod 1st Generation Battery Replacement
Views: 53K
View statistics:
Past 24 Hours:
8
Past 7 Days:
82
Past 30 Days:
437
All Time:
53,304
Comments: 8
5 comments on steps, 3 guide comments.
Go to guide comments
Completed: 34
34 people have marked this guide "completed." Will you be next?
Favorites: 15
15 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 40 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
Battery not lasting long? Swap it out.
    1. iPod 1st Generation Battery Replacement, Rear Panel: step 1, image 1 of 1
      • Before opening your iPod, ensure that the hold switch is in the locked position.
      Ask FixBot
    2. iPod 1st Generation Battery Replacement: step 2, image 1 of 1
      • Opening the iPod can be challenging; don't get discouraged if it takes you a few tries to get the iPod to open.
      • Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. It helps to hold the iPod at top and bottom as shown and squeeze to help pop out the edge. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
      Ask FixBot
    3. iPod 1st Generation Battery Replacement: step 3, image 1 of 1
      • Continue to run the opening tool along the side of the case until all five tabs have been released.
      Ask FixBot
    4. iPod 1st Generation Battery Replacement: step 4, image 1 of 1
      • Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
      Ask FixBot
    5. iPod 1st Generation Battery Replacement: step 5, image 1 of 1
      • Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
      • Lift the rear panel away from the iPod.
      Ask FixBot
    1. iPod 1st Generation Battery Replacement, Battery: step 6, image 1 of 1
      • Lift the battery up from the adhesive holding it to the iPod.
      • Lay the battery next to the iPod (it is still connected to the logic board).
      Ask FixBot
    2. iPod 1st Generation Battery Replacement: step 7, image 1 of 1
      • Lift up the end of the hard drive near the Firewire port to allow easy access to the battery connector.
      Ask FixBot
    3. iPod 1st Generation Battery Replacement: step 8, image 1 of 1
      • Carefully disconnect the white battery connector from the logic board. Be sure to pull only on the connector itself and not on the cables.
      Ask FixBot
34 other people completed this guide.
Author
with
iRobot
1 Reputation
632 Guides authored
3 Guide Comments
There are so many iPods, it's confusing as to what battery to buy. I have 3 of these old bricks and sure it's battery time. Can you please provide a link to the specific battery for this (above) iPod?
caseyhales - Reply Share
The iPod that I,m trying to resssurect has a connection that has 50t pin connection. I ordered the battery shown in the picture and now have to exchange it
drich92346 - Reply Share
In Step 4 "holding the iPod together near the dock connector": this iPod didn't get a dock connector. They came with later models. First charging: "Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery until it goes to sleep due to low battery. Wait at least 5 hours, then charge uninterrupted to 100%". If iFixit recommends it for laptops, why not for iPods?
jens wessel - Reply Share
Past 24 Hours: 8
Past 7 Days: 82
Past 30 Days: 437
All Time: 53,304
