Introduction
Use this guide to remove and replace the rear cameras in the iPhone XS. The rear camera assembly consists of two individual modules: one wide-angle camera and one telephoto camera. Both modules are replaced as a single unit.
Both iPhone XS and XS Max use the same camera; the part can be swapped freely between the two models.
Note: This guide instructs you to completely detach the display cables and remove the display assembly in order to better access the rear cameras—however, it's possible to remove and replace the rear cameras with the display cables still connected. Advanced readers may skip disconnecting the display in order to save time, as long as the display is properly supported and the display cables are not damaged.
Power off your iPhone before beginning disassembly.
Remove the two 6.9 mm-long pentalobe screws at the bottom edge of the iPhone.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
Tool used on this step:Clampy - Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Heat an iOpener and thread it through the arms of the Anti-Clamp.
Fold the iOpener so it lays on the bottom edge of the iPhone.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
Skip the next three steps.
Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
Tool used on this step:Magnetic Project Mat$19.95
Remove five screws securing the logic board connector bracket, of the following lengths:
Three 1.0 mm Y000 screws
One 1.3 mm Y000 screw
One 3.7 mm Phillips screw
Remove the two screws securing the rear camera cover:
One 1.4 mm Y000 screw
One 2.0 mm Phillips screw
31 other people completed this guide.
2 Guide Comments
I have some dark spots on my main camera and i notice some dust behind the lens cover, do you think it as to do with it?
Thank you
hola, les hago una consulta a los técnicos. Tengo un Xs que empezó con un problema de cámara, el problema es que algunas veces enfoca y otras no. Yo abro la cámara y la principal (1x) si no está muy cerca el objeto que quiero no lo enfoca. Que puede ser? Tengo q cambiarle la cámara?
