iPhone XS Max Rear-Facing Cameras Replacement
    1. iPhone XS Max Rear-Facing Cameras Replacement, Pentalobe Screws: step 1, image 1 of 2 iPhone XS Max Rear-Facing Cameras Replacement, Pentalobe Screws: step 1, image 2 of 2
      • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 6.9 mm-long pentalobe screws at the bottom edge of the iPhone.
      • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
      Ask FixBot
    1. iPhone XS Max Rear-Facing Cameras Replacement, Mark your opening picks: step 2, image 1 of 3 iPhone XS Max Rear-Facing Cameras Replacement, Mark your opening picks: step 2, image 2 of 3 iPhone XS Max Rear-Facing Cameras Replacement, Mark your opening picks: step 2, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone XS Max Rear-Facing Cameras Replacement, Tape over any cracks: step 3, image 1 of 3 iPhone XS Max Rear-Facing Cameras Replacement, Tape over any cracks: step 3, image 2 of 3 iPhone XS Max Rear-Facing Cameras Replacement, Tape over any cracks: step 3, image 3 of 3
      • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
      • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
      • If all else fails, you can superglue the suction cup to the screen.
      Ask FixBot
    2. iPhone XS Max Rear-Facing Cameras Replacement, Anti-Clamp instructions: step 4, image 1 of 3 iPhone XS Max Rear-Facing Cameras Replacement, Anti-Clamp instructions: step 4, image 2 of 3 iPhone XS Max Rear-Facing Cameras Replacement, Anti-Clamp instructions: step 4, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
      • Squeeze the cups together to apply suction to the desired area.
      • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      Ask FixBot
    3. iPhone XS Max Rear-Facing Cameras Replacement: step 5, image 1 of 3 iPhone XS Max Rear-Facing Cameras Replacement: step 5, image 2 of 3 iPhone XS Max Rear-Facing Cameras Replacement: step 5, image 3 of 3
      • Pull the blue handle forward to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Ask FixBot
    4. iPhone XS Max Rear-Facing Cameras Replacement: step 6, image 1 of 3 iPhone XS Max Rear-Facing Cameras Replacement: step 6, image 2 of 3 iPhone XS Max Rear-Facing Cameras Replacement: step 6, image 3 of 3
      • Heat an iOpener and thread it through the arms of the Anti-Clamp.
      • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
      • Fold the iOpener so it lays on the bottom edge of the iPhone.
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next three steps.
      Ask FixBot
    5. iPhone XS Max Rear-Facing Cameras Replacement: step 7, image 1 of 1
      • Heating the lower edge of the iPhone helps soften the adhesive securing the display, making it easier to open.
      • Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
      Ask FixBot
    6. iPhone XS Max Rear-Facing Cameras Replacement: step 8, image 1 of 2 iPhone XS Max Rear-Facing Cameras Replacement: step 8, image 2 of 2
      • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
      Ask FixBot
    7. iPhone XS Max Rear-Facing Cameras Replacement: step 9, image 1 of 3 iPhone XS Max Rear-Facing Cameras Replacement: step 9, image 2 of 3 iPhone XS Max Rear-Facing Cameras Replacement: step 9, image 3 of 3
      • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
      • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
      Ask FixBot
    8. iPhone XS Max Rear-Facing Cameras Replacement: step 10, image 1 of 3 iPhone XS Max Rear-Facing Cameras Replacement: step 10, image 2 of 3 iPhone XS Max Rear-Facing Cameras Replacement: step 10, image 3 of 3
      • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
      • Don't insert your pick more than 3 mm, as you may damage the internal components.
      Ask FixBot
    9. iPhone XS Max Rear-Facing Cameras Replacement, Screen information: step 11, image 1 of 1
      • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
      Ask FixBot
    10. iPhone XS Max Rear-Facing Cameras Replacement: step 12, image 1 of 3 iPhone XS Max Rear-Facing Cameras Replacement: step 12, image 2 of 3 iPhone XS Max Rear-Facing Cameras Replacement: step 12, image 3 of 3
      • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
      • Don't insert your pick more than 3 mm, as you may damage the display cables.
      Ask FixBot
    11. iPhone XS Max Rear-Facing Cameras Replacement: step 13, image 1 of 3 iPhone XS Max Rear-Facing Cameras Replacement: step 13, image 2 of 3 iPhone XS Max Rear-Facing Cameras Replacement: step 13, image 3 of 3
      • The top edge of the display is secured with both glue and clips.
      • Slide the opening pick around the top corner of the display, while gently pulling or wiggling the display down in the direction of the Lightning port.
      • The clips will break if you use too much force. Work carefully and be patient.
      • Don't insert your pick more than 3 mm, as you may damage the front panel sensor array.
      • Slide the pick to the opposite corner and cut any remaining adhesive securing the display.
      Ask FixBot
    12. iPhone XS Max Rear-Facing Cameras Replacement: step 14, image 1 of 1
      • Pull on the small nub on the suction cup to remove it from the front panel.
      Ask FixBot
    13. iPhone XS Max Rear-Facing Cameras Replacement: step 15, image 1 of 3 iPhone XS Max Rear-Facing Cameras Replacement: step 15, image 2 of 3 iPhone XS Max Rear-Facing Cameras Replacement: step 15, image 3 of 3
      • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
      • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
      • Lean the display against something to keep it propped up while you're working on the phone.
      • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
      Ask FixBot
    1. iPhone XS Max Rear-Facing Cameras Replacement, Display Assembly: step 16, image 1 of 2 iPhone XS Max Rear-Facing Cameras Replacement, Display Assembly: step 16, image 2 of 2
      Magnetic Project Mat
      $19.95
      Buy
      • Remove four Y000 screws securing the logic board cover bracket, of the following lengths:
      • Two 1.1 mm screws
      • One 1.5 mm screw
      • One 3.7 mm screw
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
      Ask FixBot
    2. iPhone XS Max Rear-Facing Cameras Replacement: step 17, image 1 of 1
      • Remove the bracket.
      • The bracket may be lightly adhered in place. Lift gently but firmly to separate it.
      • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
      Ask FixBot
    3. iPhone XS Max Rear-Facing Cameras Replacement: step 18, image 1 of 2 iPhone XS Max Rear-Facing Cameras Replacement: step 18, image 2 of 2
      • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
      • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
      • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
      Ask FixBot
    4. iPhone XS Max Rear-Facing Cameras Replacement: step 19, image 1 of 2 iPhone XS Max Rear-Facing Cameras Replacement: step 19, image 2 of 2
      • Remove the three Y000 screws securing the display connector bracket:
      • Two 1.5 mm screws
      • One 1.1 mm screw
      Ask FixBot
    5. iPhone XS Max Rear-Facing Cameras Replacement: step 20, image 1 of 1
      Ask FixBot
    6. iPhone XS Max Rear-Facing Cameras Replacement: step 21, image 1 of 2 iPhone XS Max Rear-Facing Cameras Replacement: step 21, image 2 of 2
      • Use the point of a spudger or a fingernail to disconnect the front panel sensor assembly connector.
      Ask FixBot
    7. iPhone XS Max Rear-Facing Cameras Replacement: step 22, image 1 of 2 iPhone XS Max Rear-Facing Cameras Replacement: step 22, image 2 of 2
      • Use a spudger or a fingernail to disconnect the OLED panel cable connector.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    8. iPhone XS Max Rear-Facing Cameras Replacement: step 23, image 1 of 2 iPhone XS Max Rear-Facing Cameras Replacement: step 23, image 2 of 2
      • Use a spudger or fingernail to pry the digitizer cable connector up from its socket.
      • If any part of your screen doesn't respond to touch after your repair, disconnect the battery and then re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
      Ask FixBot
    9. iPhone XS Max Rear-Facing Cameras Replacement: step 24, image 1 of 3 iPhone XS Max Rear-Facing Cameras Replacement: step 24, image 2 of 3 iPhone XS Max Rear-Facing Cameras Replacement: step 24, image 3 of 3
      • The front panel sensor assembly flex cable is lightly adhered in place.
      • Carefully lift the cable until the adhesive separates.
      Ask FixBot
    10. iPhone XS Max Rear-Facing Cameras Replacement: step 25, image 1 of 1
      Ask FixBot
    1. iPhone XS Max Rear-Facing Cameras Replacement, Rear-Facing Cameras: step 26, image 1 of 2 iPhone XS Max Rear-Facing Cameras Replacement, Rear-Facing Cameras: step 26, image 2 of 2
      • Remove the two 1.8 mm Phillips screws securing the rear camera cover.
      Ask FixBot
    2. iPhone XS Max Rear-Facing Cameras Replacement: step 27, image 1 of 3 iPhone XS Max Rear-Facing Cameras Replacement: step 27, image 2 of 3 iPhone XS Max Rear-Facing Cameras Replacement: step 27, image 3 of 3
      • Lift the camera cover from the edge closest to the battery, and remove it.
      • To reinstall the camera cover, follow the images exactly in reverse: first, lower the outside edge until the two protruding tabs on the cover are slotted securely into the bracket on the outer edge of the camera module. Then, hinge the cover closed.
      • If the two tabs are not seated correctly, the cover will not lay flat.
      Ask FixBot
    3. iPhone XS Max Rear-Facing Cameras Replacement: step 28, image 1 of 3 iPhone XS Max Rear-Facing Cameras Replacement: step 28, image 2 of 3 iPhone XS Max Rear-Facing Cameras Replacement: step 28, image 3 of 3
      • Use an iFixit opening tool or a fingernail to disconnect the two camera cable connectors by prying them straight up from their sockets.
      Ask FixBot
    4. iPhone XS Max Rear-Facing Cameras Replacement: step 29, image 1 of 2 iPhone XS Max Rear-Facing Cameras Replacement: step 29, image 2 of 2
      Buy
      • Insert both tips of your tweezers or a pointed pry tool at the bottom right corner of the camera, between the camera assembly and the iPhone's frame.
      • Gently pry up to lever the camera out of the iPhone.
      • The camera assembly is not glued down, but it is firmly press-fit into place. A spudger or plastic pry tool may not be strong enough to lever it out.
      Ask FixBot
    5. iPhone XS Max Rear-Facing Cameras Replacement: step 30, image 1 of 1
      • Remove the rear-facing camera assembly.
      Ask FixBot
35 other people completed this guide.
Jeff Suovanen
455,054 Reputation
259 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
4 Guide Comments
Hi I was wondering if the rear facing camera class is broken is there a way to replace the glass?
hughes - Reply Share
I’m replacing it now by myself :) There’s nothing complicated. (except screws and reminding where they come from)
Zared - Reply Share
Yes you can buy it on Amazon for around $8. It is very easy, no heat gun required
Bruce Linn - Reply Share
After being quoted over $500 at various repairers to replace these rear-facing cameras, I decided to purchase the part for $100 and complete the repair myself. The instructions were detailed and easy to follow, and the different screws being colour coded on the instructions really helped with reassembling. My camera now works perfectly, and I saved myself over $400 by doing the repair myself. I also replaced the adhesive water resistant seal, which was much easier than I anticipated. All in all, 10/10 repair guide, thank you so much!
Meg Gunst - Reply Share
Past 24 Hours: 11
Past 7 Days: 61
Past 30 Days: 279
All Time: 53,573
