iPhone SE 2022 LCD and Digitizer Replacement
    1. iPhone SE 2022 LCD and Digitizer Replacement, Remove the pentalobe screws: step 1, image 1 of 2 iPhone SE 2022 LCD and Digitizer Replacement, Remove the pentalobe screws: step 1, image 2 of 2
      • Power off your phone before beginning disassembly.
      • Remove the two 3.4 mm P2 pentalobe screws on the bottom edge of the iPhone.
      Ask FixBot
    1. iPhone SE 2022 LCD and Digitizer Replacement, Mark your opening picks: step 2, image 1 of 3 iPhone SE 2022 LCD and Digitizer Replacement, Mark your opening picks: step 2, image 2 of 3 iPhone SE 2022 LCD and Digitizer Replacement, Mark your opening picks: step 2, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone SE 2022 LCD and Digitizer Replacement, Tape over any cracks: step 3, image 1 of 3 iPhone SE 2022 LCD and Digitizer Replacement, Tape over any cracks: step 3, image 2 of 3 iPhone SE 2022 LCD and Digitizer Replacement, Tape over any cracks: step 3, image 3 of 3
      • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
      • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
      • If all else fails, you can superglue the suction cup to the screen.
      Ask FixBot
    2. iPhone SE 2022 LCD and Digitizer Replacement, Anti-Clamp instructions: step 4, image 1 of 3 iPhone SE 2022 LCD and Digitizer Replacement, Anti-Clamp instructions: step 4, image 2 of 3 iPhone SE 2022 LCD and Digitizer Replacement, Anti-Clamp instructions: step 4, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
      • Squeeze the cups together to apply suction to the desired area.
      • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      Ask FixBot
    3. iPhone SE 2022 LCD and Digitizer Replacement: step 5, image 1 of 3 iPhone SE 2022 LCD and Digitizer Replacement: step 5, image 2 of 3 iPhone SE 2022 LCD and Digitizer Replacement: step 5, image 3 of 3
      • Pull the blue handle forwards to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Ask FixBot
    4. iPhone SE 2022 LCD and Digitizer Replacement: step 6, image 1 of 3 iPhone SE 2022 LCD and Digitizer Replacement: step 6, image 2 of 3 iPhone SE 2022 LCD and Digitizer Replacement: step 6, image 3 of 3
      • Heat an iOpener and thread it through the arms of the Anti-Clamp.
      • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
      • Fold the iOpener so it lays on the bottom edge of the iPhone.
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • Insert an opening pick under the screen's plastic bezel, not the screen itself.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next two steps.
      Ask FixBot
    5. iPhone SE 2022 LCD and Digitizer Replacement, Heat the front panel adhesive: step 7, image 1 of 1
      • If you're using a suction handle, follow the next two steps to loosen the rear glass.
      • Prepare an iOpener and apply it to the screen for at least two minutes to loosen the adhesive underneath.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    6. iPhone SE 2022 LCD and Digitizer Replacement, Insert an opening pick: step 8, image 1 of 3 iPhone SE 2022 LCD and Digitizer Replacement, Insert an opening pick: step 8, image 2 of 3 iPhone SE 2022 LCD and Digitizer Replacement, Insert an opening pick: step 8, image 3 of 3
      • Secure a suction handle to the lower half of the front panel, as close to the home button as possible.
      • Lift the front panel with the suction handle to create a small gap between the front panel and the frame.
      • If you have trouble creating a gap, apply more heat to the bottom half of the screen to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Insert an opening pick into the gap under the screen's plastic bezel.
      Ask FixBot
    7. iPhone SE 2022 LCD and Digitizer Replacement, Slice the adhesive: step 9, image 1 of 3 iPhone SE 2022 LCD and Digitizer Replacement, Slice the adhesive: step 9, image 2 of 3 iPhone SE 2022 LCD and Digitizer Replacement, Slice the adhesive: step 9, image 3 of 3
      • Slide the opening pick to the bottom right corner to slice the front panel adhesive.
      • Insert a second opening pick at the bottom edge of your phone.
      • Slide the opening pick to the bottom left corner to slice the adhesive.
      • Leave the opening picks in place to prevent the adhesive from resealing.
      Ask FixBot
    8. iPhone SE 2022 LCD and Digitizer Replacement, Slice the adhesive: step 10, image 1 of 3 iPhone SE 2022 LCD and Digitizer Replacement, Slice the adhesive: step 10, image 2 of 3 iPhone SE 2022 LCD and Digitizer Replacement, Slice the adhesive: step 10, image 3 of 3
      • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for two to three minutes to reheat it.
      • Slide the bottom left opening pick along the left edge of your phone to slice the adhesive.
      • Stop near the top left corner of the display.
      • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
      Ask FixBot
    9. iPhone SE 2022 LCD and Digitizer Replacement: step 11, image 1 of 3 iPhone SE 2022 LCD and Digitizer Replacement: step 11, image 2 of 3 iPhone SE 2022 LCD and Digitizer Replacement: step 11, image 3 of 3
      • Slide the bottom right opening pick along the right edge of your phone to slice the adhesive.
      • Don't insert your pick more than 3 mm, as you may damage internal components.
      • Stop near the top right corner of the display.
      Ask FixBot
    10. iPhone SE 2022 LCD and Digitizer Replacement, Lift the screen: step 12, image 1 of 2 iPhone SE 2022 LCD and Digitizer Replacement, Lift the screen: step 12, image 2 of 2
      • Remove the opening picks.
      • Gently pull up on the suction handle to lift up the bottom edge of the display.
      • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
      • Remove the suction handle.
      Ask FixBot
    11. iPhone SE 2022 LCD and Digitizer Replacement, Slice the remaining adhesive: step 13, image 1 of 3 iPhone SE 2022 LCD and Digitizer Replacement, Slice the remaining adhesive: step 13, image 2 of 3 iPhone SE 2022 LCD and Digitizer Replacement, Slice the remaining adhesive: step 13, image 3 of 3
      • Slide an opening pick underneath the top left corner of the display.
      • Slide the opening pick around the top left corner and along the top edge of the phone to slice the remaining adhesive.
      Ask FixBot
    12. iPhone SE 2022 LCD and Digitizer Replacement, Disengage the front panel clips: step 14, image 1 of 2 iPhone SE 2022 LCD and Digitizer Replacement, Disengage the front panel clips: step 14, image 2 of 2
      • Slide the display assembly slightly down in direction of the charging port to disengage the clips holding it to the rear case.
      Ask FixBot
    13. iPhone SE 2022 LCD and Digitizer Replacement, Lift up the display: step 15, image 1 of 3 iPhone SE 2022 LCD and Digitizer Replacement, Lift up the display: step 15, image 2 of 3 iPhone SE 2022 LCD and Digitizer Replacement, Lift up the display: step 15, image 3 of 3
      • Open the phone by swinging the display up from the left side, like the back cover of a book.
      • Don't try to fully separate the display from the phone assembly yet, as several fragile ribbon cables still connect it to the logic board.
      • Lean the display against something to keep it propped up while you're working on the phone.
      Ask FixBot
    1. iPhone SE 2022 LCD and Digitizer Replacement, Unfasten the lower display cable bracket screws: step 16, image 1 of 1
      Magnetic Project Mat
      $19.95
      Buy
      • Remove the four Phillips screws securing the lower display cable bracket:
      • Two 1.2 mm-long screws
      • Two 2.8 mm-long screws
      • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
      Ask FixBot
    2. iPhone SE 2022 LCD and Digitizer Replacement, Remove the lower display cable bracket: step 17, image 1 of 2 iPhone SE 2022 LCD and Digitizer Replacement, Remove the lower display cable bracket: step 17, image 2 of 2
      Buy
      • Use a pair of tweezers to carefully remove the lower display cable bracket.
      Ask FixBot
    3. iPhone SE 2022 LCD and Digitizer Replacement, Disconnect the battery: step 18, image 1 of 2 iPhone SE 2022 LCD and Digitizer Replacement, Disconnect the battery: step 18, image 2 of 2
      • Use the pointed end of a spudger to disconnect the battery by prying the connector straight up from its socket.
      Ask FixBot
    1. iPhone SE 2022 LCD and Digitizer Replacement, Disconnect the display and digitizer cables: step 19, image 1 of 3 iPhone SE 2022 LCD and Digitizer Replacement, Disconnect the display and digitizer cables: step 19, image 2 of 3 iPhone SE 2022 LCD and Digitizer Replacement, Disconnect the display and digitizer cables: step 19, image 3 of 3
      • The display and digitizer cables run on top of each other. To avoid cable damage always start by disconnecting the upper cable first and never try to disconnect both at the same time.
      • Use the pointed end of a spudger to disconnect the bottom two display cables by prying the connectors straight up from their sockets.
      • To re-attach press connectors like this, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
      Ask FixBot
    2. iPhone SE 2022 LCD and Digitizer Replacement, Unfasten the front sensor assembly bracket screws: step 20, image 1 of 1
      • Use a Phillips screwdriver to remove the three 1.2 mm-long screws securing the front sensor assembly bracket.
      Ask FixBot
    3. iPhone SE 2022 LCD and Digitizer Replacement, Remove the front sensor assembly bracket: step 21, image 1 of 2 iPhone SE 2022 LCD and Digitizer Replacement, Remove the front sensor assembly bracket: step 21, image 2 of 2
      Buy
      • Use a pair of tweezers to carefully remove the front sensor assembly bracket.
      Ask FixBot
    4. iPhone SE 2022 LCD and Digitizer Replacement, Disconnect the front sensor assembly cable: step 22, image 1 of 2 iPhone SE 2022 LCD and Digitizer Replacement, Disconnect the front sensor assembly cable: step 22, image 2 of 2
      • Use the pointed end of a spudger to disconnect the front sensor assembly by prying the connector straight up from its socket.
      Ask FixBot
    5. iPhone SE 2022 LCD and Digitizer Replacement, Remove the display assembly: step 23, image 1 of 2 iPhone SE 2022 LCD and Digitizer Replacement, Remove the display assembly: step 23, image 2 of 2
      • Remove the display assembly.
      • During reassembly, follow this guide to apply adhesive and install your display assembly.
      Ask FixBot
    1. iPhone SE 2022 LCD and Digitizer Replacement, Unfasten the home/Touch ID sensor bracket screws: step 24, image 1 of 1
      • Remove the four screws securing the home/Touch ID sensor bracket:
      • Three 1.2 mm-long Y000 screws
      • One 1.1 mm-long Y000 screw
      Ask FixBot
    2. iPhone SE 2022 LCD and Digitizer Replacement, Remove the home/Touch ID sensor bracket: step 25, image 1 of 2 iPhone SE 2022 LCD and Digitizer Replacement, Remove the home/Touch ID sensor bracket: step 25, image 2 of 2
      Buy
      • Use a pair of tweezers to carefully remove the home/Touch ID sensor bracket.
      Ask FixBot
    3. iPhone SE 2022 LCD and Digitizer Replacement, Disconnect the home/Touch ID sensor: step 26, image 1 of 3 iPhone SE 2022 LCD and Digitizer Replacement, Disconnect the home/Touch ID sensor: step 26, image 2 of 3 iPhone SE 2022 LCD and Digitizer Replacement, Disconnect the home/Touch ID sensor: step 26, image 3 of 3
      • Use an opening tool to pry under the left edge of the home/Touch ID sensor cable connector to disconnect it from its socket.
      • If the entire connector begins to flip up without separating, press down on the cable at the top edge of the connector with the flat end of a spudger, while simultaneously prying up the left edge of the connector. Be very careful not to damage the cable or connector, or you will permanently disable the sensor.
      Ask FixBot
    4. iPhone SE 2022 LCD and Digitizer Replacement, Heat the home/Touch ID sensor cable adhesive: step 27, image 1 of 1
      • Prepare an iOpener and apply it to the screen where the home/Touch ID button is located for at least two minutes to loosen the adhesive underneath its cable.
      Ask FixBot
    5. iPhone SE 2022 LCD and Digitizer Replacement, Free the home/Touch ID sensor cable: step 28, image 1 of 3 iPhone SE 2022 LCD and Digitizer Replacement, Free the home/Touch ID sensor cable: step 28, image 2 of 3 iPhone SE 2022 LCD and Digitizer Replacement, Free the home/Touch ID sensor cable: step 28, image 3 of 3
      • Carefully slide an opening pick underneath the home/Touch ID sensor cable and separate it from the back side of the display panel.
      • Avoid damaging the cable connector during this procedure. The home/Touch ID sensor cable is wrapped around it and abrupt movements might tear the connector cable. Try to fold the connector up in direction of the selfie camera and out of the cables way instead.
      Ask FixBot
    6. iPhone SE 2022 LCD and Digitizer Replacement, Remove the home/Touch ID sensor assembly: step 29, image 1 of 3 iPhone SE 2022 LCD and Digitizer Replacement, Remove the home/Touch ID sensor assembly: step 29, image 2 of 3 iPhone SE 2022 LCD and Digitizer Replacement, Remove the home/Touch ID sensor assembly: step 29, image 3 of 3
      • Use a pair of tweezers to remove the home/Touch ID sensor assembly by lifting it through the front side of the display.
      • To reinstall, first feed the cable through the hole in the front of the display as shown.
      • Your replacement part may come with extra Y000 screws already installed near the Home Button. Remove the unnecessary screws so that you can reinstall the home button bracket.
      Ask FixBot
    1. iPhone SE 2022 LCD and Digitizer Replacement, Unfasten the earpiece speaker bracket screws: step 30, image 1 of 1
      • Unfasten the three screws securing the earpiece speaker bracket:
      • Two 2.6 mm-long Phillips screws
      • One 1.6 mm-long Phillips screw
      Ask FixBot
    2. iPhone SE 2022 LCD and Digitizer Replacement, Remove the earpiece speaker bracket: step 31, image 1 of 2 iPhone SE 2022 LCD and Digitizer Replacement, Remove the earpiece speaker bracket: step 31, image 2 of 2
      Buy
      • Use a pair of tweezers to carefully remove the earpiece speaker bracket.
      Ask FixBot
    3. iPhone SE 2022 LCD and Digitizer Replacement, Free the earpiece speaker: step 32, image 1 of 2 iPhone SE 2022 LCD and Digitizer Replacement, Free the earpiece speaker: step 32, image 2 of 2
      • Use a pair of tweezers to lift the front facing camera out of its socket and swing it to the left to get free access to the earpiece speaker.
      • Avoid straining the front camera cable during this procedure.
      Ask FixBot
    4. iPhone SE 2022 LCD and Digitizer Replacement, Unfasten the earpiece speaker screws: step 33, image 1 of 1
      • Unfasten the two screws securing the earpiece speaker:
      • One 1.8 mm-long Phillips screw
      • One 2.3 mm-long Phillips screw
      Ask FixBot
    5. iPhone SE 2022 LCD and Digitizer Replacement, Remove the earpiece speaker: step 34, image 1 of 2 iPhone SE 2022 LCD and Digitizer Replacement, Remove the earpiece speaker: step 34, image 2 of 2
      • Use a pair of tweezers to remove the earpiece speaker.
      Ask FixBot
    1. iPhone SE 2022 LCD and Digitizer Replacement, Loosen the front camera and sensor assembly adhesive: step 35, image 1 of 1
      • Apply a heated iOpener to the top edge of the screen to loosen the adhesive securing the front camera and sensor assembly. Apply the iOpener for at least 2 minutes.
      Ask FixBot
    2. iPhone SE 2022 LCD and Digitizer Replacement, Pry up the proximity sensor: step 36, image 1 of 2 iPhone SE 2022 LCD and Digitizer Replacement, Pry up the proximity sensor: step 36, image 2 of 2
      • Use the pointed end of a spudger to carefully pry the proximity sensor out of its recess on the front panel.
      • Try to get your tool all the way underneath the sensor to pry it up. If you pry only against the cable, the sensor may separate from the cable assembly and will need replacement. However, this doesn't matter If you're replacing the sensor/cable assembly anyway.
      Ask FixBot
    3. iPhone SE 2022 LCD and Digitizer Replacement, Pry up the ambient light sensor: step 37, image 1 of 2 iPhone SE 2022 LCD and Digitizer Replacement, Pry up the ambient light sensor: step 37, image 2 of 2
      • Use the pointed of a spudger to carefully pry the ambient light sensor out of its recess on the front panel.
      Ask FixBot
    4. iPhone SE 2022 LCD and Digitizer Replacement, Separate the front camera and sensor assembly flex cable: step 38, image 1 of 3 iPhone SE 2022 LCD and Digitizer Replacement, Separate the front camera and sensor assembly flex cable: step 38, image 2 of 3 iPhone SE 2022 LCD and Digitizer Replacement, Separate the front camera and sensor assembly flex cable: step 38, image 3 of 3
      • Slide an opening pick underneath the front camera and sensor cable assembly to separate it from the front panel.
      • If you're struggling the separate the cable from the front panel, reapply a heated iOpener to the top edge of the screen to further loosen the adhesive. Apply the iOpener for at least one minute.
      Ask FixBot
    5. iPhone SE 2022 LCD and Digitizer Replacement, Remove the front camera and sensor assembly cable: step 39, image 1 of 2 iPhone SE 2022 LCD and Digitizer Replacement, Remove the front camera and sensor assembly cable: step 39, image 2 of 2
      Buy
      • Use a pair of tweezers to remove the front camera and sensor assembly cable.
      Ask FixBot
    1. iPhone SE 2022 LCD and Digitizer Replacement, Unfasten the LCD and digitizer bracket screws: step 40, image 1 of 2 iPhone SE 2022 LCD and Digitizer Replacement, Unfasten the LCD and digitizer bracket screws: step 40, image 2 of 2
      • Use a screwdriver to remove the three 1.1 mm-long Y000 screws securing the LCD and digitizer brackets.
      Ask FixBot
    2. iPhone SE 2022 LCD and Digitizer Replacement, Remove the top LCD and digitizer bracket: step 41, image 1 of 2 iPhone SE 2022 LCD and Digitizer Replacement, Remove the top LCD and digitizer bracket: step 41, image 2 of 2
      • Use a pair of tweezer to remove the top LCD and digitizer bracket.
      Ask FixBot
    3. iPhone SE 2022 LCD and Digitizer Replacement, Loosen the LCD and digitizer bracket adhesive: step 42, image 1 of 1
      • Prepare an iOpener and apply it to the bottom LCD and digitizer bracket for at least two minutes to loosen the adhesive underneath.
      Ask FixBot
    4. iPhone SE 2022 LCD and Digitizer Replacement, Separate the bottom LCD and digitizer bracket: step 43, image 1 of 2 iPhone SE 2022 LCD and Digitizer Replacement, Separate the bottom LCD and digitizer bracket: step 43, image 2 of 2
      • The LCD and digitizer cable is split into five cables underneath the bracket. Avoid tearing them when separating the bracket from the screen.
      • Carefully slide an opening pick underneath the right edge of the LCD and digitizer bracket to separate it from the screen.
      Ask FixBot
    5. iPhone SE 2022 LCD and Digitizer Replacement: step 44, image 1 of 2 iPhone SE 2022 LCD and Digitizer Replacement: step 44, image 2 of 2
      • Carefully slide an opening pick underneath the left edge of the LCD and digitizer bracket to separate it from the screen.
      Ask FixBot
    6. iPhone SE 2022 LCD and Digitizer Replacement, Remove the bottom LCD and digitizer bracket: step 45, image 1 of 2 iPhone SE 2022 LCD and Digitizer Replacement, Remove the bottom LCD and digitizer bracket: step 45, image 2 of 2
      Buy
      • Use a pair of tweezers to remove the bottom LCD and digitizer bracket.
      • Only the LCD and digitizer remain.
      Ask FixBot
If possible, turn on your device and test your repair before installing new adhesive and resealing.
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the frame and place the screen back in its original position.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
9 other people completed this guide.
Dominik Schnabelrauch
263,413 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
123 Members
82,057 Guides authored
4 Guide Comments
Hi I would like to ask if LCD for iPhone SE 2020/ iPhone 8 is compatible with new iPhone SE 3.gen 2022?
Second question is if after replacement there is notification about non genuine LCD like have new iPhones?
Ondřej Hnyk - Reply Share
Probably late for you, but for the next bloke, the 3rd part screen that worked for the iPhone 8/SE2020 WILL NOT work on the iPhone SE 3rd gen 2022.
An original screen for the SE2020 or a 3rd party LCD specifically designed for the SE2022 will work.
Felipe Leal - Reply Share
Where can I buy the replacement LCD/digitizer, or a replacement screen?
AIDEN DEJONG - Reply Share
AliExpress or your local parts dealer :)
Past 24 Hours: 16
Past 7 Days: 109
Past 30 Days: 436
All Time: 20,362
