Introduction
Use this guide to remove, transfer, or replace the home/touch ID sensor a.k.a the home button in an iPhone SE 2022.
This guide was performed on the A2783 (international) model.
The iPhone SE 2022’s home “button” is actually a solid-state sensor, which also includes Touch ID (fingerprint recognition) capability.
Most replacement home buttons won’t work, so check carefully before starting your repair. Your iPhone’s original home button is uniquely paired to the logic board at the factory—and without Apple’s proprietary calibration process, even a genuine replacement home button from another iPhone won’t work. To fix a broken home button, you should install a specially-made, universal-style home button. Note that these replacements only work as a button and you'll loose Touch ID functionality.
If you are only replacing a broken screen, you can use this guide to carefully remove and transfer your working original home button to a new screen, preserving all functions, including Touch ID.
Note: This guide instructs you to fully detach and remove the display assembly; this is highly recommended for easier handling and to prevent damage to the display cables. If you feel comfortable removing the Home/Touch ID Sensor while keeping the display cables attached, you can skip the steps for disconnecting the display.
If you do not replace the adhesive seals when reassembling, your device will function normally, but will most likely lose its water protection.
You’ll need replacement adhesive to reattach components when reassembling the device.
Power off your phone before beginning disassembly.
Remove the two 3.4 mm P2 pentalobe screws on the bottom edge of the iPhone.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
Tool used on this step:Clampy - Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Heat an iOpener and thread it through the arms of the Anti-Clamp.
Fold the iOpener so it lays on the bottom edge of the iPhone.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick under the screen's plastic bezel, not the screen itself.
Skip the next two steps.
Prepare an iOpener and apply it to the screen for at least two minutes to loosen the adhesive underneath.
Secure a suction handle to the lower half of the front panel, as close to the home button as possible.
Lift the front panel with the suction handle to create a small gap between the front panel and the frame.
Insert an opening pick into the gap under the screen's plastic bezel.
Slide the opening pick to the bottom right corner to slice the front panel adhesive.
Insert a second opening pick at the bottom edge of your phone.
Slide the opening pick to the bottom left corner to slice the adhesive.
Leave the opening picks in place to prevent the adhesive from resealing.
Slide the bottom left opening pick along the left edge of your phone to slice the adhesive.
Stop near the top left corner of the display.
Remove the opening picks.
Gently pull up on the suction handle to lift up the bottom edge of the display.
Remove the suction handle.
Slide an opening pick underneath the top left corner of the display.
Slide the opening pick around the top left corner and along the top edge of the phone to slice the remaining adhesive.
Slide the display assembly slightly down in direction of the charging port to disengage the clips holding it to the rear case.
Open the phone by swinging the display up from the left side, like the back cover of a book.
Lean the display against something to keep it propped up while you're working on the phone.
Tool used on this step:Magnetic Project Mat$19.95
Remove the four Phillips screws securing the lower display cable bracket:
Two 1.2 mm-long screws
Two 2.8 mm-long screws
Tool used on this step:Tweezers$4.99
Use a pair of tweezers to carefully remove the lower display cable bracket.
Use the pointed end of a spudger to disconnect the battery by prying the connector straight up from its socket.
Use the pointed end of a spudger to disconnect the bottom two display cables by prying the connectors straight up from their sockets.
Use a Phillips screwdriver to remove the three 1.2 mm-long screws securing the front sensor assembly bracket.
Use a pair of tweezers to carefully remove the front sensor assembly bracket.
Use the pointed end of a spudger to disconnect the front sensor assembly by prying the connector straight up from its socket.
Remove the four screws securing the home/Touch ID sensor bracket:
Three 1.2 mm-long Y000 screws
One 1.1 mm-long Y000 screw
Use a pair of tweezers to carefully remove the home/Touch ID sensor bracket.
Use an opening tool to pry under the left edge of the home/Touch ID sensor cable connector to disconnect it from its socket.
Prepare an iOpener and apply it to the screen where the home/Touch ID button is located for at least two minutes to loosen the adhesive underneath its cable.
Carefully slide an opening pick underneath the home/Touch ID sensor cable and separate it from the back side of the display panel.
Use a pair of tweezers to remove the home/Touch ID sensor assembly by lifting it through the front side of the display.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
12 other people completed this guide.
5 Guide Comments
So where can I buy one of these specially-made, universal-style home buttons? I'm on an SE 2nd Generation (A2296).
I'm in the same boat, a lot of the ones on Amazon and such either say they won't work at all and are purely cosmetic or don't specify anything related to functionality. Really makes it difficult to fix it and get whatever resale value might be left over afterward. If I was to reset the phone, I don't think I'd be able to even get into Settings to turn on Assistive Touch because the method I used was to use random notifications from the Settings app and enable it that way, how would I even make it past the pressing home to begin the iPhone setup process. Great design Apple.
I have 3rd gen and cannot buy the sensor at any phone repairer. An eBay ad suggested they had one for SE. I bought that but more suitable to iPhone 7 and under. So at this stage it’s assistive touch only which is a real pain.
u guys realy need to start carrying this i replaced the battery in my 2022 se i damage absolutely nothing and now the home button stopped working
