Up to 20% off select tools
iPhone SE 2020 Taptic Engine Replacement
Views: 17K
View statistics:
Past 24 Hours:
9
Past 7 Days:
54
Past 30 Days:
292
All Time:
16,860
Comments: 270
270 comments on steps.
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 40 minutes - 1 hour
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
The Taptic Engine produces your iPhone's vibration and haptic feedback functions. Use this guide to remove and/or replace the Taptic Engine in an iPhone SE 2020.
Note: This guide instructs you to fully detach and remove the display assembly; this is intended to make the phone easier to work with and to prevent accidental damage to the display cables. If you feel comfortable removing the Taptic Engine while keeping the display cables attached, you can skip the steps for disconnecting the display.
    1. iPhone SE 2020 Taptic Engine Replacement, Remove the pentalobe screws: step 1, image 1 of 1
      • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 3.5 mm pentalobe screws on the bottom edge of the iPhone.
      • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
      Ask FixBot
    1. iPhone SE 2020 Taptic Engine Replacement, Mark your opening picks: step 2, image 1 of 3 iPhone SE 2020 Taptic Engine Replacement, Mark your opening picks: step 2, image 2 of 3 iPhone SE 2020 Taptic Engine Replacement, Mark your opening picks: step 2, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone SE 2020 Taptic Engine Replacement, Anti-Clamp instructions: step 3, image 1 of 3 iPhone SE 2020 Taptic Engine Replacement, Anti-Clamp instructions: step 3, image 2 of 3 iPhone SE 2020 Taptic Engine Replacement, Anti-Clamp instructions: step 3, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
      • Squeeze the cups together to apply suction to the desired area.
      • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      Ask FixBot
    2. iPhone SE 2020 Taptic Engine Replacement: step 4, image 1 of 3 iPhone SE 2020 Taptic Engine Replacement: step 4, image 2 of 3 iPhone SE 2020 Taptic Engine Replacement: step 4, image 3 of 3
      • Pull the blue handle forwards to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Ask FixBot
    3. iPhone SE 2020 Taptic Engine Replacement: step 5, image 1 of 2 iPhone SE 2020 Taptic Engine Replacement: step 5, image 2 of 2
      • Heat an iOpener and thread it through the arms of the Anti-Clamp.
      • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
      • Fold the iOpener so it lays on the bottom edge of the iPhone.
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • Insert an opening pick into the gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next three steps.
      Ask FixBot
    4. iPhone SE 2020 Taptic Engine Replacement, Heat the display: step 6, image 1 of 1
      • The next three steps show how to separate the screen using a suction cup.
      • Apply a heated iOpener to the bottom edge of the screen for two minutes. This softens the adhesive securing it.
      • Alternatively, you can use a hair dryer or heat gun to heat the bottom half of the screen until it’s slightly too hot to touch
      • Improper use of a heat gun can destroy the display and/or battery—review this guide for instructions. To prevent screen damage, keep your heat source moving rather than focused on one spot.
      • For tips on using a hair dryer to soften adhesive, check out this guide.
      Ask FixBot
    5. iPhone SE 2020 Taptic Engine Replacement, Separate the display: step 7, image 1 of 2 iPhone SE 2020 Taptic Engine Replacement, Separate the display: step 7, image 2 of 2
      • Apply a suction cup to the lower half of the front panel, just above the home button.
      • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
      Ask FixBot
    6. iPhone SE 2020 Taptic Engine Replacement: step 8, image 1 of 3 iPhone SE 2020 Taptic Engine Replacement: step 8, image 2 of 3 iPhone SE 2020 Taptic Engine Replacement: step 8, image 3 of 3
      • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
      • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
      Ask FixBot
    7. iPhone SE 2020 Taptic Engine Replacement: step 9, image 1 of 3 iPhone SE 2020 Taptic Engine Replacement: step 9, image 2 of 3 iPhone SE 2020 Taptic Engine Replacement: step 9, image 3 of 3
      • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
      • Stop near the top left corner of the display.
      • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
      Ask FixBot
    8. iPhone SE 2020 Taptic Engine Replacement, Screen information: step 10, image 1 of 1
      • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
      Ask FixBot
    9. iPhone SE 2020 Taptic Engine Replacement: step 11, image 1 of 3 iPhone SE 2020 Taptic Engine Replacement: step 11, image 2 of 3 iPhone SE 2020 Taptic Engine Replacement: step 11, image 3 of 3
      • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
      • Don't insert your pick more than 3 mm, as you may damage the display cables.
      Ask FixBot
    10. iPhone SE 2020 Taptic Engine Replacement: step 12, image 1 of 2 iPhone SE 2020 Taptic Engine Replacement: step 12, image 2 of 2
      • Gently pull up on the suction cup to lift up the bottom edge of the display.
      • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
      • Pull on the small nub on the suction cup to remove it from the front panel.
      Ask FixBot
    11. iPhone SE 2020 Taptic Engine Replacement: step 13, image 1 of 3 iPhone SE 2020 Taptic Engine Replacement: step 13, image 2 of 3 iPhone SE 2020 Taptic Engine Replacement: step 13, image 3 of 3
      • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
      Ask FixBot
    12. iPhone SE 2020 Taptic Engine Replacement: step 14, image 1 of 2 iPhone SE 2020 Taptic Engine Replacement: step 14, image 2 of 2
      • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
      Ask FixBot
    13. iPhone SE 2020 Taptic Engine Replacement: step 15, image 1 of 3 iPhone SE 2020 Taptic Engine Replacement: step 15, image 2 of 3 iPhone SE 2020 Taptic Engine Replacement: step 15, image 3 of 3
      • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
      • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
      • Lean the display against something to keep it propped up while you're working on the phone.
      Ask FixBot
    1. iPhone SE 2020 Taptic Engine Replacement, Disconnect the battery: step 16, image 1 of 2 iPhone SE 2020 Taptic Engine Replacement, Disconnect the battery: step 16, image 2 of 2
      Magnetic Project Mat
      $16.96
      Buy
      • Remove four Phillips screws securing the lower display cable bracket to the logic board, of the following lengths:
      • Two 1.3 mm screws
      • Two 2.8 mm screws
      • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
      • Remove the bracket.
      Ask FixBot
    2. iPhone SE 2020 Taptic Engine Replacement: step 17, image 1 of 2 iPhone SE 2020 Taptic Engine Replacement: step 17, image 2 of 2
      • Use the point of a spudger to pry the battery connector out of its socket in the logic board.
      • Don't pry against the logic board, or you may damage the charging circuitry.
      • Bend the battery connector cable slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
      Ask FixBot
    1. iPhone SE 2020 Taptic Engine Replacement, Disconnect the display and digitizer: step 18, image 1 of 2 iPhone SE 2020 Taptic Engine Replacement, Disconnect the display and digitizer: step 18, image 2 of 2
      • Use the point of a spudger to pry the lower display connector out of its socket.
      • To re-attach press connectors like this one, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
      Ask FixBot
    2. iPhone SE 2020 Taptic Engine Replacement: step 19, image 1 of 2 iPhone SE 2020 Taptic Engine Replacement: step 19, image 2 of 2
      • Use the point of a spudger to disconnect the second lower display cable.
      Ask FixBot
    3. iPhone SE 2020 Taptic Engine Replacement: step 20, image 1 of 2 iPhone SE 2020 Taptic Engine Replacement: step 20, image 2 of 2
      • Remove the three 1.3 mm Phillips screws securing the bracket over the front panel sensor assembly connector.
      Ask FixBot
    4. iPhone SE 2020 Taptic Engine Replacement: step 21, image 1 of 2 iPhone SE 2020 Taptic Engine Replacement: step 21, image 2 of 2
      • Use the point of a spudger to disconnect the front panel sensor assembly connector.
      Ask FixBot
    5. iPhone SE 2020 Taptic Engine Replacement, Remove the display assembly: step 22, image 1 of 1
      Ask FixBot
    1. iPhone SE 2020 Taptic Engine Replacement, Remove the Wi-Fi diversity antenna: step 23, image 1 of 1
      • Remove the three screws securing the bracket next to the Taptic Engine:
      • One 1.3 mm Y000 screw
      • One 2.7 mm Phillips screw
      • One 2.9 mm Phillips screw
      Ask FixBot
    2. iPhone SE 2020 Taptic Engine Replacement: step 24, image 1 of 1
      Ask FixBot
    3. iPhone SE 2020 Taptic Engine Replacement: step 25, image 1 of 3 iPhone SE 2020 Taptic Engine Replacement: step 25, image 2 of 3 iPhone SE 2020 Taptic Engine Replacement: step 25, image 3 of 3
      • Gently slide an opening pick between the antenna flex cable and the top of the speaker.
      • This portion of the flex cable is lightly adhered in place. If necessary, apply a little heat from an iOpener or hair dryer to soften the adhesive. This will make it easier to separate the flex cable safely.
      Ask FixBot
    4. iPhone SE 2020 Taptic Engine Replacement: step 26, image 1 of 2 iPhone SE 2020 Taptic Engine Replacement: step 26, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the diversity antenna flex cable from the logic board.
      Ask FixBot
    5. iPhone SE 2020 Taptic Engine Replacement: step 27, image 1 of 3 iPhone SE 2020 Taptic Engine Replacement: step 27, image 2 of 3 iPhone SE 2020 Taptic Engine Replacement: step 27, image 3 of 3
      Buy
      • Slide an opening pick under the antenna flex cable to hold the socket down.
      • Use the point of your spudger to pry up and disconnect the antenna flex cable from its socket, using the opening pick to hold the socket down.
      • Reconnecting this cable can be tricky. Make it easier by using your tweezers to hold the flex cable so the connector aligns with its socket. Then, gently press straight down on the connector with the flat of your spudger until it clicks into place.
      Ask FixBot
    6. iPhone SE 2020 Taptic Engine Replacement: step 28, image 1 of 1
      • Remove the Wi-Fi diversity antenna.
      Ask FixBot
    1. iPhone SE 2020 Taptic Engine Replacement, Remove the Taptic Engine: step 29, image 1 of 1
      Standoff Screwdriver for iPhones
      $5.49
      Buy
      • Remove the two screws securing the Taptic Engine:
      • One 2.1 mm Phillips screw
      • One 2.1 mm standoff screw
      • Standoff screws are best removed using a standoff screwdriver or bit.
      • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
      Ask FixBot
    2. iPhone SE 2020 Taptic Engine Replacement: step 30, image 1 of 2 iPhone SE 2020 Taptic Engine Replacement: step 30, image 2 of 2
      • Use the point of your spudger to pry the antenna cable socket up and away from the connector below it.
      Ask FixBot
    3. iPhone SE 2020 Taptic Engine Replacement: step 31, image 1 of 2 iPhone SE 2020 Taptic Engine Replacement: step 31, image 2 of 2
      • Use the point of your spudger to pry up and disconnect the Taptic Engine flex cable.
      Ask FixBot
    4. iPhone SE 2020 Taptic Engine Replacement: step 32, image 1 of 1
      • Remove the Taptic Engine.
      • Be careful removing Taptic Engine flex cable as it may be glued to the antenna flex cable.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Don't forget to reapply the display adhesive before reinstalling the display.
Repair didn’t go as planned? Check out our iPhone SE 2020 Answers community for troubleshooting help.
10 other people completed this guide.
Author
with
Adam O'Camb
226,699 Reputation
415 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 54
Past 30 Days: 292
All Time: 16,860
