Up to 20% off select tools
iPhone Motherboard Repair Tips
Views: 8K
View statistics:
Past 24 Hours:
10
Past 7 Days:
73
Past 30 Days:
346
All Time:
8,039
Comments: 1
1 guide comment.
Go to guide comments
Completed: 16
16 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Community-Contributed Guide
Video Overview
    1. iPhone Motherboard Repair Tips, iPhone Motherboard Repair Tips: step 1, image 1 of 2 iPhone Motherboard Repair Tips, iPhone Motherboard Repair Tips: step 1, image 2 of 2
      • A hot air gun is one of the most frequently used tools in phone repair, and the technical requirements for technicians are also very high. Both soldering and desoldering of motherboard components require a hot air gun.
      • Today, we will walk you through some basic steps to using a hot air gun for phone repair. First, let’s take a look at the types of hot air guns.
      Ask FixBot
    2. iPhone Motherboard Repair Tips: step 2, image 1 of 3 iPhone Motherboard Repair Tips: step 2, image 2 of 3 iPhone Motherboard Repair Tips: step 2, image 3 of 3
      • Hot air guns can be divided into the helical wind and vertical wind types. The helical wind type is mainly used to solder and desolder connectors, NAND, CPU, WiFi modules, and other relatively large chips.
      • The vertical wind type is mainly used to solder and desolder small components like resistors and capacitors.
      • The helical wind type features gentle airflow and low heat, while the vertical wind type has concentrated airflow and high heat.
      Ask FixBot
    3. iPhone Motherboard Repair Tips: step 3, image 1 of 3 iPhone Motherboard Repair Tips: step 3, image 2 of 3 iPhone Motherboard Repair Tips: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Correct use of the hot air gun can enhance repair efficiency, while incorrect use can damage the phone.
      • The temperature and airflow of the hot air gun must meet special requirements in different scenarios. The component can’t be removed, or the soldering will be defective. If the temperature is set too low, components and the PCB board will be damaged under high temperatures.
      • What’s more, components will get blown away if the airflow is set too high. Therefore, proper use of the hot air gun is the key to phone repair. Then we will show you how to use a hot air gun properly for phone repair. First of all, let’s take a look at how to desolder small components.
      • A vertical wind hot air gun is used to desolder these kinds of components. The temperature should be set around 330 °C-365 °C, and the airflow around 1-3. Because the vertical wind hot air gun heats up so quickly, please wait to begin working until the temperature is stable after starting up.
      • In addition, the nozzle should be kept vertical from the component with a distance of 3-6 mm. You should heat evenly above the component for about 13-18 seconds. Then remove the component with tweezers.
      Ask FixBot
    4. iPhone Motherboard Repair Tips: step 4, image 1 of 3 iPhone Motherboard Repair Tips: step 4, image 2 of 3 iPhone Motherboard Repair Tips: step 4, image 3 of 3
      • For soldering, the soldering method is the same as the desoldering method. You need to put the component in position first and pay attention to the temperature as well as airflow.
      • Next, let’s see how to desolder large chips with a hot air gun. Corner adhesive needs to be removed when we use a hot air gun to desolder large chips like NAND. A helical wind hot air gun is used to desolder these kinds of large chips. Please apply high-temperature tape around the component to protect surrounding components.
      • The temperature should be set around 365 °C-400 °C, and the airflow around 45-65. The nozzle should be kept vertical from the component with a distance of 6-8 mm.
      • You should heat evenly above the component for about 40 seconds. Then pry up the component with a pry blade.
      • In summary, the nozzle of the hot air gun should be kept vertical from the soldering surface at a suitable distance. Other than that, the temperature and airflow of the hot air gun must be set properly according to the actual repair circumstances.
      Ask FixBot
    5. iPhone Motherboard Repair Tips: step 5, image 1 of 2 iPhone Motherboard Repair Tips: step 5, image 2 of 2
      • Please note that the temperature sometimes has to be adjusted according to the type of fixture. The synthetic stone fixture dissipates heat slowly, and the temperature can be lower.
      • The iron fixture dissipates heat quickly, and the temperature should be set higher.
      Ask FixBot
16 other people completed this guide.
Author
with
REWA
19,811 Reputation
55 Guides authored
1 Guide Comment
Très intéressant
Barbu - Reply Share
Past 24 Hours: 10
Past 7 Days: 73
Past 30 Days: 346
All Time: 8,039
