Up to 20% off select tools
iPhone Camera Repair
Views: 34K
View statistics:
Past 24 Hours:
18
Past 7 Days:
111
Past 30 Days:
508
All Time:
34,417
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 hour
Difficulty: Very difficult
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Community-Contributed Guide
Parts
Tools
Video Overview
    1. iPhone Camera Repair, main camera: step 1, image 1 of 2 iPhone Camera Repair, main camera: step 1, image 2 of 2
      • Today, REWA LAB will share with you a repair case of an iPhone camera and walk you through some knowledge of iPhone camera repair.
      • Open the phone camera. When taking photos with the wide-angle camera, cracks appear. The ultra-wide camera works fine. We can judge that the optical filter of the wide-angle camera is damaged.
      Ask FixBot
    2. iPhone Camera Repair: step 2, image 1 of 3 iPhone Camera Repair: step 2, image 2 of 3 iPhone Camera Repair: step 2, image 3 of 3
      • We can judge that the optical filter of the wide-angle camera is damaged. Then we disassemble the phone and try to repair the camera. First of all, put the camera on the specialized Heating Platform at 100 °C.
      • When the temperature reaches 100 °C, remove black adhesive around the camera with a Sculpture Knife. Then pry up the wide-angle camera.
      • Attach the camera to the specialized holder. Before repair, apply protection tape to the camera.
      Ask FixBot
    3. iPhone Camera Repair: step 3, image 1 of 3 iPhone Camera Repair: step 3, image 2 of 3 iPhone Camera Repair: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Separate the camera edges with a Sculpture Knife. Next, remove the metal cover with Hot Air Gun at 120 °C.
      • Keep heating with Hot Air Gun at 120 °C. Remove black adhesive with Tweezers. Apply some Paste Flux.
      • Separate the motor from the CMOS with ultrathin Soldering Iron at 380 °C
      Ask FixBot
    4. iPhone Camera Repair: step 4, image 1 of 2 iPhone Camera Repair: step 4, image 2 of 2
      • It can be seen that the optical filter is broken while the motor and blue lens are good. If the motor is damaged, the camera will fail to focus or shake. A motor replacement can help you solve the problem.
      • The middle part of the motor is the blue lens. If the blue lens is damaged, the camera will become blurry. The solution is to replace the blue lens.
      • Then we replace the cracked optical filter with a new one.
      Ask FixBot
    5. iPhone Camera Repair: step 5, image 1 of 3 iPhone Camera Repair: step 5, image 2 of 3 iPhone Camera Repair: step 5, image 3 of 3
      • Apply some UV adhesive to the broken optical filter.
      • Put the new optical filter in position.
      • Solidify with a UV Lamp.
      Ask FixBot
    6. iPhone Camera Repair: step 6, image 1 of 3 iPhone Camera Repair: step 6, image 2 of 3 iPhone Camera Repair: step 6, image 3 of 3
      • Remove side adhesive with Hot Air Gun.
      • Then push the cracked optical filter out with the specialized holder.
      • Remove residual shards and black adhesive with Hot Air Gun.
      Ask FixBot
    7. iPhone Camera Repair: step 7, image 1 of 3 iPhone Camera Repair: step 7, image 2 of 3 iPhone Camera Repair: step 7, image 3 of 3
      • Then remove dust spots with a specialized swab. Please be extremely careful not to damage the CMOS during operation. If the CMOS is damaged, the camera will be unrepairable.
      • Then apply some UV adhesive and a new optical filter. Solidify with UV Lamp.
      Ask FixBot
    8. iPhone Camera Repair: step 8, image 1 of 3 iPhone Camera Repair: step 8, image 2 of 3 iPhone Camera Repair: step 8, image 3 of 3
      • Then we assemble the camera. Apply some Paste Flux around the motor. Solder the motor with the CMOS with Soldering Iron. Clean the camera with alcohol.
      • Next, we install the wide-angle camera for testing. The camera works fine. Apply B7000 to fix the wide-angle camera. That’s all for the optical filter replacement of iPhone camera.
      Ask FixBot
9 other people completed this guide.
Author
with
REWA
19,811 Reputation
55 Guides authored
2 Guide Comments
Good job! But, the cost of labor and material is not economical. It is still wise to buy the whole camera module as a replacement. Easier and more practical.
On the other hand, if the viewer opted to do the filter replacement, this is a great reference since Rewa is a reputable company. Thank you for sharing this useful guide.
Jojo - Reply Share
Incrível! Parabéns!!
Daan.ll - Reply Share
Past 24 Hours: 18
Past 7 Days: 111
Past 30 Days: 508
All Time: 34,417
