Up to 20% off select tools
iPhone Air Screen Replacement
Views: 13K
View statistics:
Past 24 Hours:
30
Past 7 Days:
213
Past 30 Days:
1,009
All Time:
12,692
Comments: 0
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
  • iPhone Air Screen
Parts
  • iPhone Air Screen
Tools
Introduction
Go to step 1 ↓
Use this guide to replace a broken, cracked, or non‑responsive screen on an iPhone Air.
Note: Since you can't disconnect the battery during this repair, make sure your phone stays powered down, don't use metal prying tools, and be careful not to touch exposed contacts.
After a screen replacement, True Tone and auto‑brightness may be disabled. Calibrate replacement screens using Apple's Repair Assistant to restore this functionality.
You'll need replacement screen adhesive to complete this repair.
    1. iPhone Air Screen Replacement, Prepare your phone for disassembly: step 1, image 1 of 2 iPhone Air Screen Replacement, Prepare your phone for disassembly: step 1, image 2 of 2
      • Before you begin:
      • Back up your data.
      • Discharge the phone's battery drain below 25%. A charged lithium‑ion battery can catch fire if accidentally damaged.
      • Unplug any cables, and remove all cases, covers, and accessories (like portable chargers).
      • Hold the power and either volume button and slide to power off your phone.
      Ask FixBot
    2. iPhone Air Screen Replacement, Mark your opening picks: step 2, image 1 of 3 iPhone Air Screen Replacement, Mark your opening picks: step 2, image 2 of 3 iPhone Air Screen Replacement, Mark your opening picks: step 2, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone Air Screen Replacement, Cracked glass preparation: step 3, image 1 of 1
      • Glass shards can complicate disassembly—or worse, cause injury. If your phone has a cracked screen:
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      • Apply strips of packing tape to the cracked glass until the whole screen is covered—this will help keep the glass contained and allow the suction cup to stick to the screen.
      • Make sure there's a single strip (not overlapping) of tape across the bottom edge, big enough for a suction cup to fit on.
      • Only cover the glass itself—don't stick any tape to the frame.
      Ask FixBot
    2. iPhone Air Screen Replacement, Remove the pentalobe screws: step 4, image 1 of 1
      • Opening the phone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble it without replacing the seals.
      • Use a P2 pentalobe driver to remove the two 4.9 mm-long screws on either side of the USB-C port.
      Ask FixBot
    3. iPhone Air Screen Replacement, Heat the bottom edge: step 5, image 1 of 1
      • Use a hair dryer or heat gun to heat the bottom half of the screen until it’s slightly too hot to touch. This softens the adhesive securing it.
      • Improper use of a heat gun can destroy the display and/or battery—review this guide for instructions. To prevent screen damage, keep your heat source moving rather than focused on one spot.
      • For tips on using a hair dryer to soften adhesive, check out this guide.
      Ask FixBot
    4. iPhone Air Screen Replacement, Insert an opening pick: step 6, image 1 of 3 iPhone Air Screen Replacement, Insert an opening pick: step 6, image 2 of 3 iPhone Air Screen Replacement, Insert an opening pick: step 6, image 3 of 3
      • Apply a suction handle to the bottom edge of the screen.
      • Pull up on the suction handle with firm, constant pressure to create a gap under the screen’s plastic bezel.
      • The adhesive holding the screen in place is very strong. If you're having a hard time, be patient, apply more heat, and try again.
      • Insert the tip of an opening pick into the gap.
      Ask FixBot
    5. iPhone Air Screen Replacement, Screen information: step 7, image 1 of 1
      • As you slice the adhesive securing the screen in the following steps, don't insert your pick deeper than 3 mm to avoid damaging the following areas:
      • The screen and ambient light sensor cables, located near the Action button
      • Delicate spring contacts around the perimeter of the phone
      • There are multiple clips around the iPhone. You may hear and feel these release as you slide past them.
      • Since you can't disconnect the battery during this repair, don't use metal prying tools and make sure your phone stays powered down.
      Ask FixBot
    6. iPhone Air Screen Replacement, Slice the bottom edge adhesive: step 8, image 1 of 3 iPhone Air Screen Replacement, Slice the bottom edge adhesive: step 8, image 2 of 3 iPhone Air Screen Replacement, Slice the bottom edge adhesive: step 8, image 3 of 3
      • Slide the opening pick along the bottom edge to release the adhesive.
      • If you’re having trouble, apply more heat—not more force.
      • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
      Ask FixBot
    7. iPhone Air Screen Replacement, Heat the left edge: step 9, image 1 of 1
      • Heat the left edge of the phone (the edge with the volume buttons) until the screen is slightly too hot to touch.
      Ask FixBot
    8. iPhone Air Screen Replacement, Separate the left edge adhesive: step 10, image 1 of 3 iPhone Air Screen Replacement, Separate the left edge adhesive: step 10, image 2 of 3 iPhone Air Screen Replacement, Separate the left edge adhesive: step 10, image 3 of 3
      • Don't insert your pick deeper than 3 mm to avoid damaging the ribbon cables.
      • Insert a second opening pick in the bottom left corner, next to the existing pick.
      • Slide the opening pick up the left edge of the screen to separate the adhesive and release the metal clip.
      • You may hear and feel the metal clip release as you pass it.
      • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    9. iPhone Air Screen Replacement, Separate the remaining adhesives: step 11, image 1 of 3 iPhone Air Screen Replacement, Separate the remaining adhesives: step 11, image 2 of 3 iPhone Air Screen Replacement, Separate the remaining adhesives: step 11, image 3 of 3
      • Repeat the heating and sliding procedure along the remaining screen edges to separate the adhesive and release the clips.
      Ask FixBot
    10. iPhone Air Screen Replacement, Lift open the screen: step 12, image 1 of 3 iPhone Air Screen Replacement, Lift open the screen: step 12, image 2 of 3 iPhone Air Screen Replacement, Lift open the screen: step 12, image 3 of 3
      • Don't try to remove the screen yet, as two fragile ribbon cables still connect it to the iPhone. Take care not to strain the cables as you work.
      • At this point, the screen should be free from the frame. If the screen feels stuck, go back around the perimeter with your pick and separate missed sections of adhesive or stuck clips.
      • Carefully lift the screen upwards until the clips along the long edges clear the frame.
      • Open the iPhone by swinging the screen up from the [left/right] edge, like the [back] cover of a book.
      • Lean the screen against something to keep it propped up while you're working on the phone.
      • If you don't have anything at hand to lean the screen against, the suction handle can do the trick.
      Ask FixBot
    11. iPhone Air Screen Replacement, Protect the front cameras: step 13, image 1 of 2 iPhone Air Screen Replacement, Protect the front cameras: step 13, image 2 of 2
      • We recommend using polyimide (aka kapton) tape to keep the front cameras clean. You may skip this step, but be extra careful not to touch the cameras.
      • Install a strip of polyimide tape over the front camera assembly by pressing the tape down on either side of it. Don't press down on the assembly itself.
      Ask FixBot
    12. iPhone Air Screen Replacement, Remove the connector cover: step 14, image 1 of 1
      • Use a tri-point Y000 driver to remove the 1.1 mm‑long screw securing the front sensor and display connector cover.
      Ask FixBot
    13. iPhone Air Screen Replacement: step 15, image 1 of 3 iPhone Air Screen Replacement: step 15, image 2 of 3 iPhone Air Screen Replacement: step 15, image 3 of 3
      • Use tweezers or your fingers to lift the front sensor cover to a 45-degree angle and remove it.
      • During reassembly, insert each cover at a 45-degree angle to re-engage the hook before laying it flat against the press connector.
      Ask FixBot
    14. iPhone Air Screen Replacement, Disconnect the screen: step 16, image 1 of 3 iPhone Air Screen Replacement, Disconnect the screen: step 16, image 2 of 3 iPhone Air Screen Replacement, Disconnect the screen: step 16, image 3 of 3
      • Use the tip of a spudger to pry up and disconnect the front sensor and screen press connectors.
      • During reassembly, align each connector carefully over its socket and press down with your fingertip or flat end of a spudger—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      Ask FixBot
    15. iPhone Air Screen Replacement, Remove the screen: step 17, image 1 of 1
      • Remove the screen.
      • Follow this guide to reapply adhesive and install the new screen.
      • Be careful not to damage any of the spring contacts as you clean the frame.
      Ask FixBot
To reassemble your phone, follow this guide to reapply adhesive and install your screen.
After your repair, calibrate a genuine replacement screen using Apple's Repair Assistant. Navigate to Settings → General → About → Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone Air Answers Community for help.
6 other people completed this guide.
Author
with
Nick Schultz
71,397 Reputation
363 Guides authored
0 Guide Comments
Past 24 Hours: 30
Past 7 Days: 213
Past 30 Days: 1,009
All Time: 12,692
