iPhone 8 Speaker Replacement
    1. iPhone 8 Speaker Replacement, Speaker: step 1, image 1 of 1
      • Sim card tray removal. This step is necessary as seen in Step 7.
      • Let the battery drain below 25% and power off the device before starting the repair.
      Ask FixBot
    2. iPhone 8 Speaker Replacement: step 2, image 1 of 2 iPhone 8 Speaker Replacement: step 2, image 2 of 2
      • Remove the two bottom screws using the P2 bit in the Pro Tech Tool Kit.
      Ask FixBot
    3. iPhone 8 Speaker Replacement: step 3, image 1 of 3 iPhone 8 Speaker Replacement: step 3, image 2 of 3 iPhone 8 Speaker Replacement: step 3, image 3 of 3
      • Insert the Jimmy into the right side of the phone. Putting the Jimmy in the middle could crack the glass and/or break the home button. Also, don't put the Jimmy into the left side because you could break the home button cable. Use a small box to prop up the display as shown in picture 3.
      Ask FixBot
    4. iPhone 8 Speaker Replacement: step 4, image 1 of 3 iPhone 8 Speaker Replacement: step 4, image 2 of 3 iPhone 8 Speaker Replacement: step 4, image 3 of 3
      • Before we disconnect the display, we need to unplug the battery connector. If you don't unplug the battery first, you could damage the back light on the screen.
      Ask FixBot
    5. iPhone 8 Speaker Replacement: step 5, image 1 of 2 iPhone 8 Speaker Replacement: step 5, image 2 of 2
      • Now to remove the display. There are 3 more screws that we need to remove, then we can disconnect the 3 cables.
      • Remove the display from the housing.
      Ask FixBot
    6. iPhone 8 Speaker Replacement: step 6, image 1 of 1
      • Now we need to remove this bracket. The screw next to the Taptic Engine is a Y000.
      Ask FixBot
    7. iPhone 8 Speaker Replacement: step 7, image 1 of 2 iPhone 8 Speaker Replacement: step 7, image 2 of 2
      • Disconnect the marked flex cables, then push the sim pin ejector into the frame. Now remove the 3 screws holding the speaker in place. Lift the speaker up and remove it as shown in picture 2.
      Ask FixBot
3 other people completed this guide.
CubicBuilder9
566 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 35
Past 30 Days: 183
All Time: 4,232
