Up to 20% off select tools
iPhone 8 Disassembly
Views: 3.2K
View statistics:
Past 24 Hours:
9
Past 7 Days:
94
Past 30 Days:
481
All Time:
3,199
Comments: 1
1 guide comment.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 hour
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Community-Contributed Guide
Introduction
Go to step 1 ↓
In this detailed guide you see how to transfer your iPhone 8 into a new case. Your old one is worn or perhaps you just want a different color, as examples.
    1. iPhone 8 Disassembly, Power Off: step 1, image 1 of 1
      • First turn off the device to avoid any damage during disassembly.
      Ask FixBot
    2. iPhone 8 Disassembly, Unscrew: step 2, image 1 of 1
      • Remove the two screws to the left and right of the charging/headphone jack with a suitable screwdriver
      Ask FixBot
    3. iPhone 8 Disassembly, Loosen the display: step 3, image 1 of 2 iPhone 8 Disassembly, Loosen the display: step 3, image 2 of 2
      • Work your way around the iphone with a pick (or fingernail). Start in one corner, to loosen the adhesive and retaining tabs. After that, the display should lay loosely with a gap of about 2mm on the phone.
      • Warning: pry carefully at the top of the screen. Here the display is not yet freed from the case!
      Ask FixBot
    4. iPhone 8 Disassembly, Open the cell phone: step 4, image 1 of 1
      • Now you can open the display to the left. Attention: no further than 90⁰, otherwise the ribbon cables of the display will break off.
      Ask FixBot
    5. iPhone 8 Disassembly, Detach the display cable: step 5, image 1 of 2 iPhone 8 Disassembly, Detach the display cable: step 5, image 2 of 2
      • Under this sheet metal are all the important cables of the phone. This sheet is fastened with four small Phillips screws. After removing the sheet, carefully lift the two display cable connectors with your fingernail until they unplug from the board.
      Ask FixBot
    6. iPhone 8 Disassembly, Detach the second display cable: step 6, image 1 of 1
      • Under this sheet are the cable for the speaker/front camera and the cable for the main camera. First, loosen the cable for the front camera to remove the display completely.
      Ask FixBot
    7. iPhone 8 Disassembly, Remove Camera and Bluetooth Antenna: step 7, image 1 of 2 iPhone 8 Disassembly, Remove Camera and Bluetooth Antenna: step 7, image 2 of 2
      • The camera sits under this sheet metal. The sheet metal is held in place by two screws. After removing the sheet metal, unplug the camera cable and remove the camera.
      • The Bluetooth antenna is curved into the corner of the phone. It is secured to the housing with a screw and to the circuit board with another screw
      Ask FixBot
    8. iPhone 8 Disassembly, Removing the rear microphone: step 8, image 1 of 1
      • The microphone is attached to the housing with a screw and to the back panel with a screw. Both screws must be removed and when doing so note that the microphone is also glued.
      Ask FixBot
    9. iPhone 8 Disassembly, Remove NFC Cover: step 9, image 1 of 1
      • Now remove the cover of the NFC device. After removing the cover, the board is only held in place by three screws.
      Ask FixBot
Finish Line
6 other people completed this guide.
Special thanks to these translators:
de en
100%
Juan Garcia is helping us fix the world! Want to contribute?
Start translating ›
Author
with
Jan Phönix
439 Reputation
1 Guide authored
1 Guide Comment
This guide appears to be incomplete and could do with revision
Chayant Gonsalves - Reply Share
Past 24 Hours: 9
Past 7 Days: 94
Past 30 Days: 481
All Time: 3,199
