Up to 20% off select tools
iPhone 8 Back Glass Replacement
Views: 62K
View statistics:
Past 24 Hours:
7
Past 7 Days:
75
Past 30 Days:
393
All Time:
62,114
Comments: 4
1 comment on steps, 3 guide comments.
Go to guide comments
Completed: 17
17 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide demonstrates a professional-level repair requiring advanced tools. With this special back glass separator, a broken iPhone 8/8P/X back glass can be removed in just 3 minutes. Residual glue can also be removed easily, which is convenient for subsequent attaching of a new back glass.
Video Overview
    1. iPhone 8 Back Glass Replacement, iPhone 8 Back Glass Replacement: step 1, image 1 of 1
      • Wire up the Back Glass Separator. Connect the Back Glass Separator with Air Compressor via an air pipe. Switch on the Air Compressor. Open the air compressor valve.
      • Switch on the Back Glass Separator. Rotate the pressure regulating valve and set the value as 0.4Mpa.
      Ask FixBot
    2. iPhone 8 Back Glass Replacement: step 2, image 1 of 2 iPhone 8 Back Glass Replacement: step 2, image 2 of 2
      • Place iPhone 8 back glass assembly into the corresponding mold. Press ‘Up’. With the temperature rising to 240℃, press ‘Start’. The back glass assembly is clamped tightly by the mold.
      • After 200 seconds of heating, mandril of the machine starts to work.
      Ask FixBot
    3. iPhone 8 Back Glass Replacement: step 3, image 1 of 1
      • Remove the back glass after 18 seconds. Remove glue residue on the back glass thoroughly.
      • iPhone 8 back glass separating has been completed successfully.
      • Attach a new back glass to the midframe in the end.
      Ask FixBot
Finish Line
17 other people completed this guide.
Author
with
Phryne
21,997 Reputation
18 Guides authored
3 Guide Comments
Where does it show the replacement I only see the removal?
ManDeen - Reply Share
Dar fata cum se monteaza
Sandu Solomon - Reply Share
@sandusolomon cum se montează geamul
Past 24 Hours: 7
Past 7 Days: 75
Past 30 Days: 393
All Time: 62,114
