Up to 20% off select tools
iPhone 7 Volume Control Buttons Replacement
Views: 64K
View statistics:
Past 24 Hours:
2
Past 7 Days:
44
Past 30 Days:
201
All Time:
63,658
Comments: 280
270 comments on steps, 10 guide comments.
Go to guide comments
Completed: 35
35 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes - 2 hours
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to remove or replace the volume button covers in your iPhone 7. This guide is for the physical buttons, and not the electronic switches beneath.
If you need to replace the volume control cable, follow this guide.
    1. iPhone 7 Volume Control Buttons Replacement, Pentalobe Screws: step 1, image 1 of 1
      • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
      • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
      Ask FixBot
    1. iPhone 7 Volume Control Buttons Replacement, Mark your opening picks: step 2, image 1 of 3 iPhone 7 Volume Control Buttons Replacement, Mark your opening picks: step 2, image 2 of 3 iPhone 7 Volume Control Buttons Replacement, Mark your opening picks: step 2, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone 7 Volume Control Buttons Replacement, Anti-Clamp instructions: step 3, image 1 of 3 iPhone 7 Volume Control Buttons Replacement, Anti-Clamp instructions: step 3, image 2 of 3 iPhone 7 Volume Control Buttons Replacement, Anti-Clamp instructions: step 3, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
      • Squeeze the cups together to apply suction to the desired area.
      • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      Ask FixBot
    2. iPhone 7 Volume Control Buttons Replacement: step 4, image 1 of 3 iPhone 7 Volume Control Buttons Replacement: step 4, image 2 of 3 iPhone 7 Volume Control Buttons Replacement: step 4, image 3 of 3
      • Pull the blue handle forwards to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Ask FixBot
    3. iPhone 7 Volume Control Buttons Replacement: step 5, image 1 of 2 iPhone 7 Volume Control Buttons Replacement: step 5, image 2 of 2
      • Heat an iOpener and thread it through the arms of the Anti-Clamp.
      • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
      • Fold the iOpener so it lays on the bottom edge of the iPhone.
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • Insert an opening pick into the gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next three steps.
      Ask FixBot
    4. iPhone 7 Volume Control Buttons Replacement, Heat the display: step 6, image 1 of 1
      • The next three steps show how to separate the screen using a suction cup.
      • Apply a heated iOpener to the bottom edge of the screen for two minutes. This softens the adhesive securing it.
      • Alternatively, you can use a hair dryer or heat gun to heat the bottom half of the screen until it’s slightly too hot to touch
      • Improper use of a heat gun can destroy the display and/or battery—review this guide for instructions. To prevent screen damage, keep your heat source moving rather than focused on one spot.
      • For tips on using a hair dryer to soften adhesive, check out this guide.
      Ask FixBot
    5. iPhone 7 Volume Control Buttons Replacement, Separate the display: step 7, image 1 of 2 iPhone 7 Volume Control Buttons Replacement, Separate the display: step 7, image 2 of 2
      • Apply a suction cup to the lower half of the front panel, just above the home button.
      • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
      Ask FixBot
    6. iPhone 7 Volume Control Buttons Replacement: step 8, image 1 of 3 iPhone 7 Volume Control Buttons Replacement: step 8, image 2 of 3 iPhone 7 Volume Control Buttons Replacement: step 8, image 3 of 3
      • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
      • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
      Ask FixBot
    7. iPhone 7 Volume Control Buttons Replacement: step 9, image 1 of 3 iPhone 7 Volume Control Buttons Replacement: step 9, image 2 of 3 iPhone 7 Volume Control Buttons Replacement: step 9, image 3 of 3
      • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
      • Stop near the top left corner of the display.
      • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
      Ask FixBot
    8. iPhone 7 Volume Control Buttons Replacement, Screen information: step 10, image 1 of 1
      • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
      Ask FixBot
    9. iPhone 7 Volume Control Buttons Replacement: step 11, image 1 of 3 iPhone 7 Volume Control Buttons Replacement: step 11, image 2 of 3 iPhone 7 Volume Control Buttons Replacement: step 11, image 3 of 3
      • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
      • Don't insert your pick more than 3 mm, as you may damage the display cables.
      Ask FixBot
    10. iPhone 7 Volume Control Buttons Replacement: step 12, image 1 of 2 iPhone 7 Volume Control Buttons Replacement: step 12, image 2 of 2
      • Gently pull up on the suction cup to lift up the bottom edge of the display.
      • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
      • Pull on the small nub on the suction cup to remove it from the front panel.
      Ask FixBot
    11. iPhone 7 Volume Control Buttons Replacement: step 13, image 1 of 3 iPhone 7 Volume Control Buttons Replacement: step 13, image 2 of 3 iPhone 7 Volume Control Buttons Replacement: step 13, image 3 of 3
      • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
      Ask FixBot
    12. iPhone 7 Volume Control Buttons Replacement: step 14, image 1 of 2 iPhone 7 Volume Control Buttons Replacement: step 14, image 2 of 2
      • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
      Ask FixBot
    13. iPhone 7 Volume Control Buttons Replacement: step 15, image 1 of 3 iPhone 7 Volume Control Buttons Replacement: step 15, image 2 of 3 iPhone 7 Volume Control Buttons Replacement: step 15, image 3 of 3
      • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
      • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
      • Lean the display against something to keep it propped up while you're working on the phone.
      Ask FixBot
    1. iPhone 7 Volume Control Buttons Replacement, Battery Disconnection: step 16, image 1 of 1
      Tri-point Y000 Screwdriver
      $5.99
      Buy
      Ask FixBot
    2. iPhone 7 Volume Control Buttons Replacement: step 17, image 1 of 1
      • Remove the lower connector bracket.
      Ask FixBot
    3. iPhone 7 Volume Control Buttons Replacement: step 18, image 1 of 3 iPhone 7 Volume Control Buttons Replacement: step 18, image 2 of 3 iPhone 7 Volume Control Buttons Replacement: step 18, image 3 of 3
      • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
      • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
      Ask FixBot
    1. iPhone 7 Volume Control Buttons Replacement, Display Assembly: step 19, image 1 of 3 iPhone 7 Volume Control Buttons Replacement, Display Assembly: step 19, image 2 of 3 iPhone 7 Volume Control Buttons Replacement, Display Assembly: step 19, image 3 of 3
      • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
      • Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
      • To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
      • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
      Ask FixBot
    2. iPhone 7 Volume Control Buttons Replacement: step 20, image 1 of 3 iPhone 7 Volume Control Buttons Replacement: step 20, image 2 of 3 iPhone 7 Volume Control Buttons Replacement: step 20, image 3 of 3
      • Remove the two 1.3 mm Phillips #000 screws securing the bracket over the front panel sensor assembly connector.
      • Some phones could be Y000. Apple started using Y000 for these at some point in the middle of the product's lifecycle.
      Ask FixBot
    3. iPhone 7 Volume Control Buttons Replacement: step 21, image 1 of 2 iPhone 7 Volume Control Buttons Replacement: step 21, image 2 of 2
      • Disconnect the front panel sensor assembly connector from its socket on the logic board.
      • This press connector should also be reconnected one end at a time to minimize the risk of bending.
      Ask FixBot
    4. iPhone 7 Volume Control Buttons Replacement: step 22, image 1 of 1
      Ask FixBot
    1. iPhone 7 Volume Control Buttons Replacement, SIM Card: step 23, image 1 of 3 iPhone 7 Volume Control Buttons Replacement, SIM Card: step 23, image 2 of 3 iPhone 7 Volume Control Buttons Replacement, SIM Card: step 23, image 3 of 3
      • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
      • Press to eject the tray.
      • This may require a significant amount of force. However, ensure the eject tool is properly aligned beforehand as to not damage the eject mechanism inside the phone.
      • Remove the SIM card tray assembly from the iPhone.
      • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
      Ask FixBot
    1. iPhone 7 Volume Control Buttons Replacement, Logic Board Connectors: step 24, image 1 of 2 iPhone 7 Volume Control Buttons Replacement, Logic Board Connectors: step 24, image 2 of 2
      • Use the flat end of a spudger to disconnect the rear-facing camera connector.
      Ask FixBot
    2. iPhone 7 Volume Control Buttons Replacement: step 25, image 1 of 2 iPhone 7 Volume Control Buttons Replacement: step 25, image 2 of 2
      • Remove the following Phillips screws securing the rear camera bracket to the rear case:
      • One 1.3 mm screw
      • One 2.5 mm screw
      Ask FixBot
    3. iPhone 7 Volume Control Buttons Replacement: step 26, image 1 of 1
      • Remove the bracket.
      Ask FixBot
    4. iPhone 7 Volume Control Buttons Replacement: step 27, image 1 of 2 iPhone 7 Volume Control Buttons Replacement: step 27, image 2 of 2
      • Use the pointed end of a spudger to pry up and disconnect the antenna bus connector, just left of the rear camera module.
      Ask FixBot
    5. iPhone 7 Volume Control Buttons Replacement: step 28, image 1 of 1
      • Remove the two 1.2 mm tri-point screws securing the upper cable bracket.
      Ask FixBot
    6. iPhone 7 Volume Control Buttons Replacement: step 29, image 1 of 2 iPhone 7 Volume Control Buttons Replacement: step 29, image 2 of 2
      • Remove the upper cable bracket.
      Ask FixBot
    7. iPhone 7 Volume Control Buttons Replacement: step 30, image 1 of 2 iPhone 7 Volume Control Buttons Replacement: step 30, image 2 of 2
      • Use the flat end of a spudger to disconnect the upper cable connector.
      Ask FixBot
    8. iPhone 7 Volume Control Buttons Replacement: step 31, image 1 of 2 iPhone 7 Volume Control Buttons Replacement: step 31, image 2 of 2
      • Remove the four Phillips screws securing the Wi-Fi antenna:
      • Three 1.2 mm screws
      • One 1.7 mm screw
      Ask FixBot
    9. iPhone 7 Volume Control Buttons Replacement: step 32, image 1 of 2 iPhone 7 Volume Control Buttons Replacement: step 32, image 2 of 2
      • Remove the top left antenna.
      Ask FixBot
    10. iPhone 7 Volume Control Buttons Replacement: step 33, image 1 of 1
      • Remove the following Phillips screws:
      • One 1.3 mm screw
      • One 2.2 mm screw
      Ask FixBot
    11. iPhone 7 Volume Control Buttons Replacement: step 34, image 1 of 2 iPhone 7 Volume Control Buttons Replacement: step 34, image 2 of 2
      Ask FixBot
    12. iPhone 7 Volume Control Buttons Replacement: step 35, image 1 of 1
      Standoff Screwdriver for iPhones
      $5.49
      Buy
      • Remove the 2.2 mm standoff screw from the grounding bracket.
      • Standoff screws are best removed using a standoff screwdriver or bit.
      • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
      Ask FixBot
    13. iPhone 7 Volume Control Buttons Replacement: step 36, image 1 of 2 iPhone 7 Volume Control Buttons Replacement: step 36, image 2 of 2
      Buy
      • Use tweezers to gently bend the logic board grounding bracket out of the way.
      Ask FixBot
    1. iPhone 7 Volume Control Buttons Replacement, Logic Board: step 37, image 1 of 3 iPhone 7 Volume Control Buttons Replacement, Logic Board: step 37, image 2 of 3 iPhone 7 Volume Control Buttons Replacement, Logic Board: step 37, image 3 of 3
      • Use the point of a spudger to lift the two antenna cable connectors up off of the sockets on the logic board.
      Ask FixBot
    2. iPhone 7 Volume Control Buttons Replacement: step 38, image 1 of 3 iPhone 7 Volume Control Buttons Replacement: step 38, image 2 of 3 iPhone 7 Volume Control Buttons Replacement: step 38, image 3 of 3
      Buy
      • Use tweezers to gently derout the antenna cables from the metal bracket on the logic board.
      Ask FixBot
    3. iPhone 7 Volume Control Buttons Replacement: step 39, image 1 of 2 iPhone 7 Volume Control Buttons Replacement: step 39, image 2 of 2
      • Use the point of a spudger to disconnect the lower cable connector.
      Ask FixBot
    4. iPhone 7 Volume Control Buttons Replacement: step 40, image 1 of 1
      $5.49
      Buy
      • Remove the following screws:
      • One 1.4 mm Phillips screw
      • Three 2.2 mm standoff screws
      • Standoff screws are best removed using a standoff driver.
      Ask FixBot
    5. iPhone 7 Volume Control Buttons Replacement: step 41, image 1 of 2 iPhone 7 Volume Control Buttons Replacement: step 41, image 2 of 2
      • Use the point of a spudger to move the SIM card eject plunger out of the logic board's way.
      Ask FixBot
    6. iPhone 7 Volume Control Buttons Replacement: step 42, image 1 of 2 iPhone 7 Volume Control Buttons Replacement: step 42, image 2 of 2
      • Use the flat end of a spudger to gently lift the battery connector end of the logic board up.
      • Make sure you're not pulling against any cables. If you feel resistance, check all cables, connectors, and components are clear of the board.
      Ask FixBot
    7. iPhone 7 Volume Control Buttons Replacement: step 43, image 1 of 3 iPhone 7 Volume Control Buttons Replacement: step 43, image 2 of 3 iPhone 7 Volume Control Buttons Replacement: step 43, image 3 of 3
      • Lift the battery connector end of the logic board and pull it up and out of the rear case.
      • Be careful not to snag the logic board on any cables.
      Ask FixBot
    1. iPhone 7 Volume Control Buttons Replacement, Rear Case Battery: step 44, image 1 of 2 iPhone 7 Volume Control Buttons Replacement, Rear Case Battery: step 44, image 2 of 2
      Buy
      • Use a pair of tweezers with blunt tips to peel back one of the adhesive strips on the lower edge of the battery.
      Ask FixBot
    2. iPhone 7 Volume Control Buttons Replacement: step 45, image 1 of 2 iPhone 7 Volume Control Buttons Replacement: step 45, image 2 of 2
      • Use a pair of tweezers with blunt tips to peel back the other adhesive strip on the lower edge of the battery.
      Ask FixBot
    3. iPhone 7 Volume Control Buttons Replacement: step 46, image 1 of 3 iPhone 7 Volume Control Buttons Replacement: step 46, image 2 of 3 iPhone 7 Volume Control Buttons Replacement: step 46, image 3 of 3
      • Try to keep the strips flat and unwrinkled during this procedure; wrinkled strips will stick together and break instead of pulling out cleanly.
      • Slowly pull one battery adhesive tab away from the battery, toward the bottom of the iPhone.
      • Pull steadily, maintaining constant tension on the strip until it slips out from between the battery and the rear case. For best results, pull the strip at a 60º angle or less.
      • The strip will stretch to many times its original length. Continue pulling and re-grab the strip near the battery if necessary.
      Ask FixBot
    4. iPhone 7 Volume Control Buttons Replacement: step 47, image 1 of 3 iPhone 7 Volume Control Buttons Replacement: step 47, image 2 of 3 iPhone 7 Volume Control Buttons Replacement: step 47, image 3 of 3
      • Repeat the previous step for the second strip.
      • Hold down the battery as you remove the second strip, or the strip may fling the battery when it separates from the case.
      • If you removed both adhesive strips successfully, skip the next step.
      • Otherwise, if either of the adhesive strips broke off underneath the battery and could not be retrieved, continue with the next step below.
      Ask FixBot
    5. iPhone 7 Volume Control Buttons Replacement: step 48, image 1 of 2 iPhone 7 Volume Control Buttons Replacement: step 48, image 2 of 2
      Plastic Cards
      $2.99
      Buy
      • If you successfully removed both adhesive strips, move on to the next step. Otherwise, you will need to pry the battery from the rear case.
      • Prepare an iOpener and apply it to the back of the rear case, directly over the battery. Alternatively, you can apply heat using a heat gun or hair dryer.
      • After about a minute, remove the iOpener, flip the phone over and use a plastic card to break up any remaining adhesive behind the battery.
      • Avoid bending the battery. Damage to the battery may release dangerous chemicals, and could start a fire.
      • Do not pry under the top third of the battery, you may damage the volume button ribbon cable.
      Ask FixBot
    6. iPhone 7 Volume Control Buttons Replacement: step 49, image 1 of 1
      • Remove the battery from the rear case.
      • When installing the battery, refer to this guide to replace your battery's adhesive strips.
      Ask FixBot
    1. iPhone 7 Volume Control Buttons Replacement, Power and Volume Control Cable: step 50, image 1 of 2 iPhone 7 Volume Control Buttons Replacement, Power and Volume Control Cable: step 50, image 2 of 2
      • Two 1.9 mm screws securing the power button.
      • Three 2.3 mm screws securing the volume buttons.
      Ask FixBot
    2. iPhone 7 Volume Control Buttons Replacement: step 51, image 1 of 2 iPhone 7 Volume Control Buttons Replacement: step 51, image 2 of 2
      • Remove the following 1.3 mm Phillips screws:
      • One screw beside the rear-facing camera
      • One screw on the rear case
      Ask FixBot
    3. iPhone 7 Volume Control Buttons Replacement: step 52, image 1 of 2 iPhone 7 Volume Control Buttons Replacement: step 52, image 2 of 2
      • From the outside of the phone, push the hold switch into the rear case with the point of a spudger.
      • This action will free the hold switch and gasket from the rear case.
      Ask FixBot
    4. iPhone 7 Volume Control Buttons Replacement: step 53, image 1 of 2 iPhone 7 Volume Control Buttons Replacement: step 53, image 2 of 2
      Buy
      • Use a pair of tweezers to remove the rear-facing camera.
      Ask FixBot
    5. iPhone 7 Volume Control Buttons Replacement: step 54, image 1 of 2 iPhone 7 Volume Control Buttons Replacement: step 54, image 2 of 2
      • Moving from power button side of the phone, use an opening pick to separate the adhesive holding the antenna flex cable to the rear case.
      Ask FixBot
    6. iPhone 7 Volume Control Buttons Replacement: step 55, image 1 of 2 iPhone 7 Volume Control Buttons Replacement: step 55, image 2 of 2
      • Slide the point of an opening pick underneath the antenna flex cable towards the top of the phone, separating the remaining adhesive.
      Ask FixBot
    7. iPhone 7 Volume Control Buttons Replacement: step 56, image 1 of 2 iPhone 7 Volume Control Buttons Replacement: step 56, image 2 of 2
      • Use tweezers to move the antenna flex cable away from the edge of the phone, freeing the screw bracket from the rear case.
      • Remove the antenna flex cable.
      Ask FixBot
    8. iPhone 7 Volume Control Buttons Replacement: step 57, image 1 of 1
      • Remove the 2.3 mm standoff screw securing the flash bracket to the rear case.
      • Standoff screws are best removed using an [linked product missing or disabled: IF145-343] and driver handle.
      Ask FixBot
    9. iPhone 7 Volume Control Buttons Replacement: step 58, image 1 of 2 iPhone 7 Volume Control Buttons Replacement: step 58, image 2 of 2
      • Remove the flash bracket.
      Ask FixBot
    10. iPhone 7 Volume Control Buttons Replacement: step 59, image 1 of 2 iPhone 7 Volume Control Buttons Replacement: step 59, image 2 of 2
      • Use the point of a spudger to gently unseat the flash module.
      Ask FixBot
    11. iPhone 7 Volume Control Buttons Replacement: step 60, image 1 of 2 iPhone 7 Volume Control Buttons Replacement: step 60, image 2 of 2
      Halberd Spudger
      $2.99
      Buy
      • Use the blade of a Halberd spudger to separate the adhesive holding the microphone to the rear case.
      Ask FixBot
    12. iPhone 7 Volume Control Buttons Replacement: step 61, image 1 of 2 iPhone 7 Volume Control Buttons Replacement: step 61, image 2 of 2
      • Gently fold the power button module from the edge of the rear case.
      Ask FixBot
    13. iPhone 7 Volume Control Buttons Replacement: step 62, image 1 of 3 iPhone 7 Volume Control Buttons Replacement: step 62, image 2 of 3 iPhone 7 Volume Control Buttons Replacement: step 62, image 3 of 3
      • Slide the blade of a halberd spudger under the power button end of the button cable to separate it from the adhesive on the rear case.
      • Continue to separate the adhesive by moving the blade towards the top of the phone.
      Ask FixBot
    14. iPhone 7 Volume Control Buttons Replacement: step 63, image 1 of 3 iPhone 7 Volume Control Buttons Replacement: step 63, image 2 of 3 iPhone 7 Volume Control Buttons Replacement: step 63, image 3 of 3
      • Continue to move the blade of the halberd spudger underneath the power and volume control cable.
      • Move slowly to make sure that the cable is not damaged during removal.
      Ask FixBot
    15. iPhone 7 Volume Control Buttons Replacement: step 64, image 1 of 3 iPhone 7 Volume Control Buttons Replacement: step 64, image 2 of 3 iPhone 7 Volume Control Buttons Replacement: step 64, image 3 of 3
      • Slide the halberd spudger under the volume control portion of the button cable.
      • Gently slide the blade underneath the cable towards the bottom of the phone, separating the remaining adhesive.
      Ask FixBot
    16. iPhone 7 Volume Control Buttons Replacement: step 65, image 1 of 1
      • Remove the power and volume control cable.
      Ask FixBot
    1. iPhone 7 Volume Control Buttons Replacement, Volume Buttons: step 66, image 1 of 2 iPhone 7 Volume Control Buttons Replacement, Volume Buttons: step 66, image 2 of 2
      • Pull the volume button clip towards the bottom of the phone to free it from the bracket.
      Ask FixBot
    2. iPhone 7 Volume Control Buttons Replacement: step 67, image 1 of 2 iPhone 7 Volume Control Buttons Replacement: step 67, image 2 of 2
      • Pull the clip towards the top of the phone to remove it.
      Ask FixBot
    3. iPhone 7 Volume Control Buttons Replacement: step 68, image 1 of 3 iPhone 7 Volume Control Buttons Replacement: step 68, image 2 of 3 iPhone 7 Volume Control Buttons Replacement: step 68, image 3 of 3
      Ask FixBot
    4. iPhone 7 Volume Control Buttons Replacement: step 69, image 1 of 2 iPhone 7 Volume Control Buttons Replacement: step 69, image 2 of 2
      • Slide the flat end of a spudger underneath the bottom edge of the volume button bracket.
      • Adjust the spudger so that it can move away from the rear case without contacting the protruding peg that is on the volume button.
      • Rotate the spudger to pop the bracket off of the peg on the volume button.
      Ask FixBot
    5. iPhone 7 Volume Control Buttons Replacement: step 70, image 1 of 2 iPhone 7 Volume Control Buttons Replacement: step 70, image 2 of 2
      • Pull the bracket from the rear case.
      Ask FixBot
    6. iPhone 7 Volume Control Buttons Replacement: step 71, image 1 of 3 iPhone 7 Volume Control Buttons Replacement: step 71, image 2 of 3 iPhone 7 Volume Control Buttons Replacement: step 71, image 3 of 3
      • Repeat the procedure to remove the second volume button bracket.
      Ask FixBot
    7. iPhone 7 Volume Control Buttons Replacement: step 72, image 1 of 3 iPhone 7 Volume Control Buttons Replacement: step 72, image 2 of 3 iPhone 7 Volume Control Buttons Replacement: step 72, image 3 of 3
      • Use the pointed end of a spudger to push each of the volume button covers out of the rear case.
      • Remove the volume button covers.
      Ask FixBot
35 other people completed this guide.
Author
with
Scott Havard
51,473 Reputation
31 Guides authored
10 Guide Comments
Removing the battery is excluded from this repair.
Josh M - Reply Share
R u able to fix water damage
alex - Reply Share
Hi r u able to fix water damage for iPhone 7
alex - Reply Share
Hi Alex, the repairability of water damage varies hugely depending on your unique circumstances, but this guide is a good place to start. If the damage is extensive you may want to take your phone to a local repair professional.
Adam O'Camb - Reply Share
Bonjour je voudrais savoir si vous avais la même explication mais pour iPhone 7+ s’il vous plaît ??
Lydia David - Reply Share
Past 24 Hours: 2
Past 7 Days: 44
Past 30 Days: 201
All Time: 63,658
