Up to 20% off select tools
iPhone 7 Rear Case Replacement
Views: 179K
View statistics:
Past 24 Hours:
9
Past 7 Days:
48
Past 30 Days:
340
All Time:
179,105
Comments: 361
351 comments on steps, 10 guide comments.
Go to guide comments
Completed: 73
73 people have marked this guide "completed." Will you be next?
Favorites: 9
9 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 - 3 hours
Difficulty: Difficult
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to remove all components from the rear case of your iPhone 7. This guide will show you how to remove speaker vents, button cables, and button covers so you can replace a dented or bent cover.
    1. iPhone 7 Rear Case Replacement, Pentalobe Screws: step 1, image 1 of 1
      • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
      • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
      Ask FixBot
    1. iPhone 7 Rear Case Replacement, Mark your opening picks: step 2, image 1 of 3 iPhone 7 Rear Case Replacement, Mark your opening picks: step 2, image 2 of 3 iPhone 7 Rear Case Replacement, Mark your opening picks: step 2, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone 7 Rear Case Replacement, Anti-Clamp instructions: step 3, image 1 of 3 iPhone 7 Rear Case Replacement, Anti-Clamp instructions: step 3, image 2 of 3 iPhone 7 Rear Case Replacement, Anti-Clamp instructions: step 3, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
      • Squeeze the cups together to apply suction to the desired area.
      • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      Ask FixBot
    2. iPhone 7 Rear Case Replacement: step 4, image 1 of 3 iPhone 7 Rear Case Replacement: step 4, image 2 of 3 iPhone 7 Rear Case Replacement: step 4, image 3 of 3
      • Pull the blue handle forwards to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Ask FixBot
    3. iPhone 7 Rear Case Replacement: step 5, image 1 of 2 iPhone 7 Rear Case Replacement: step 5, image 2 of 2
      • Heat an iOpener and thread it through the arms of the Anti-Clamp.
      • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
      • Fold the iOpener so it lays on the bottom edge of the iPhone.
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • Insert an opening pick into the gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next three steps.
      Ask FixBot
    4. iPhone 7 Rear Case Replacement, Heat the display: step 6, image 1 of 1
      • The next three steps show how to separate the screen using a suction cup.
      • Apply a heated iOpener to the bottom edge of the screen for two minutes. This softens the adhesive securing it.
      • Alternatively, you can use a hair dryer or heat gun to heat the bottom half of the screen until it’s slightly too hot to touch
      • Improper use of a heat gun can destroy the display and/or battery—review this guide for instructions. To prevent screen damage, keep your heat source moving rather than focused on one spot.
      • For tips on using a hair dryer to soften adhesive, check out this guide.
      Ask FixBot
    5. iPhone 7 Rear Case Replacement, Separate the display: step 7, image 1 of 2 iPhone 7 Rear Case Replacement, Separate the display: step 7, image 2 of 2
      • Apply a suction cup to the lower half of the front panel, just above the home button.
      • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
      Ask FixBot
    6. iPhone 7 Rear Case Replacement: step 8, image 1 of 3 iPhone 7 Rear Case Replacement: step 8, image 2 of 3 iPhone 7 Rear Case Replacement: step 8, image 3 of 3
      • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
      • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
      Ask FixBot
    7. iPhone 7 Rear Case Replacement: step 9, image 1 of 3 iPhone 7 Rear Case Replacement: step 9, image 2 of 3 iPhone 7 Rear Case Replacement: step 9, image 3 of 3
      • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
      • Stop near the top left corner of the display.
      • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
      Ask FixBot
    8. iPhone 7 Rear Case Replacement, Screen information: step 10, image 1 of 1
      • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
      Ask FixBot
    9. iPhone 7 Rear Case Replacement: step 11, image 1 of 3 iPhone 7 Rear Case Replacement: step 11, image 2 of 3 iPhone 7 Rear Case Replacement: step 11, image 3 of 3
      • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
      • Don't insert your pick more than 3 mm, as you may damage the display cables.
      Ask FixBot
    10. iPhone 7 Rear Case Replacement: step 12, image 1 of 2 iPhone 7 Rear Case Replacement: step 12, image 2 of 2
      • Gently pull up on the suction cup to lift up the bottom edge of the display.
      • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
      • Pull on the small nub on the suction cup to remove it from the front panel.
      Ask FixBot
    11. iPhone 7 Rear Case Replacement: step 13, image 1 of 3 iPhone 7 Rear Case Replacement: step 13, image 2 of 3 iPhone 7 Rear Case Replacement: step 13, image 3 of 3
      • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
      Ask FixBot
    12. iPhone 7 Rear Case Replacement: step 14, image 1 of 2 iPhone 7 Rear Case Replacement: step 14, image 2 of 2
      • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
      Ask FixBot
    13. iPhone 7 Rear Case Replacement: step 15, image 1 of 3 iPhone 7 Rear Case Replacement: step 15, image 2 of 3 iPhone 7 Rear Case Replacement: step 15, image 3 of 3
      • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
      • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
      • Lean the display against something to keep it propped up while you're working on the phone.
      Ask FixBot
    1. iPhone 7 Rear Case Replacement, Battery Disconnection: step 16, image 1 of 1
      Tri-point Y000 Screwdriver
      $5.99
      Buy
      Ask FixBot
    2. iPhone 7 Rear Case Replacement: step 17, image 1 of 1
      • Remove the lower connector bracket.
      Ask FixBot
    3. iPhone 7 Rear Case Replacement: step 18, image 1 of 3 iPhone 7 Rear Case Replacement: step 18, image 2 of 3 iPhone 7 Rear Case Replacement: step 18, image 3 of 3
      • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
      • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
      Ask FixBot
    1. iPhone 7 Rear Case Replacement, Display Assembly: step 19, image 1 of 3 iPhone 7 Rear Case Replacement, Display Assembly: step 19, image 2 of 3 iPhone 7 Rear Case Replacement, Display Assembly: step 19, image 3 of 3
      • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
      • Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
      • To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
      • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
      Ask FixBot
    2. iPhone 7 Rear Case Replacement: step 20, image 1 of 3 iPhone 7 Rear Case Replacement: step 20, image 2 of 3 iPhone 7 Rear Case Replacement: step 20, image 3 of 3
      • Remove the two 1.3 mm Phillips #000 screws securing the bracket over the front panel sensor assembly connector.
      • Some phones could be Y000. Apple started using Y000 for these at some point in the middle of the product's lifecycle.
      Ask FixBot
    3. iPhone 7 Rear Case Replacement: step 21, image 1 of 2 iPhone 7 Rear Case Replacement: step 21, image 2 of 2
      • Disconnect the front panel sensor assembly connector from its socket on the logic board.
      • This press connector should also be reconnected one end at a time to minimize the risk of bending.
      Ask FixBot
    4. iPhone 7 Rear Case Replacement: step 22, image 1 of 1
      Ask FixBot
    1. iPhone 7 Rear Case Replacement, Barometric Vent: step 23, image 1 of 1
      • Remove the two 1.9 mm Phillips screws securing the barometric vent to the rear case.
      Ask FixBot
    2. iPhone 7 Rear Case Replacement: step 24, image 1 of 2 iPhone 7 Rear Case Replacement: step 24, image 2 of 2
      • Remove the vent.
      Ask FixBot
    1. iPhone 7 Rear Case Replacement, Taptic Engine: step 25, image 1 of 2 iPhone 7 Rear Case Replacement, Taptic Engine: step 25, image 2 of 2
      • Use the flat end of a spudger to disconnect the Taptic Engine connector from its socket on the logic board.
      Ask FixBot
    2. iPhone 7 Rear Case Replacement: step 26, image 1 of 1
      • Remove the three 1.6 mm Phillips screws securing the Taptic Engine to the rear case.
      Ask FixBot
    3. iPhone 7 Rear Case Replacement: step 27, image 1 of 2 iPhone 7 Rear Case Replacement: step 27, image 2 of 2
      • Remove the Taptic Engine.
      Ask FixBot
    1. iPhone 7 Rear Case Replacement, Speaker Assembly: step 28, image 1 of 1
      • Remove the Phillips screw securing the Wi-Fi diversity antenna to the rear case:
      • One 3.2 mm screw
      Ask FixBot
    2. iPhone 7 Rear Case Replacement: step 29, image 1 of 1
      • Remove the following three Phillips screws securing the speaker to the rear case:
      • Two 1.3 mm screws
      • One 2.0 mm screw
      Ask FixBot
    3. iPhone 7 Rear Case Replacement: step 30, image 1 of 3 iPhone 7 Rear Case Replacement: step 30, image 2 of 3 iPhone 7 Rear Case Replacement: step 30, image 3 of 3
      • Use the point of a spudger to lift the two antenna cable connectors up off of the sockets on the logic board.
      Ask FixBot
    4. iPhone 7 Rear Case Replacement: step 31, image 1 of 2 iPhone 7 Rear Case Replacement: step 31, image 2 of 2
      Buy
      • Use tweezers to derout the antenna cables from their bracket on the logic board.
      Ask FixBot
    5. iPhone 7 Rear Case Replacement: step 32, image 1 of 2 iPhone 7 Rear Case Replacement: step 32, image 2 of 2
      • Use tweezers to remove the antenna cables from the clip on the speaker.
      • Make sure to grasp the cable near the clip in order to avoid damaging the cable.
      Ask FixBot
    6. iPhone 7 Rear Case Replacement: step 33, image 1 of 2 iPhone 7 Rear Case Replacement: step 33, image 2 of 2
      • Use the tip of a spudger to slide the speaker assembly towards the logic board and off of the rear case.
      Ask FixBot
    7. iPhone 7 Rear Case Replacement: step 34, image 1 of 1
      • Remove the speaker.
      Ask FixBot
    1. iPhone 7 Rear Case Replacement, SIM Card: step 35, image 1 of 3 iPhone 7 Rear Case Replacement, SIM Card: step 35, image 2 of 3 iPhone 7 Rear Case Replacement, SIM Card: step 35, image 3 of 3
      • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
      • Press to eject the tray.
      • This may require a significant amount of force. However, ensure the eject tool is properly aligned beforehand as to not damage the eject mechanism inside the phone.
      • Remove the SIM card tray assembly from the iPhone.
      • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
      Ask FixBot
    1. iPhone 7 Rear Case Replacement, Logic Board Connectors: step 36, image 1 of 2 iPhone 7 Rear Case Replacement, Logic Board Connectors: step 36, image 2 of 2
      • Use the flat end of a spudger to disconnect the rear-facing camera connector.
      Ask FixBot
    2. iPhone 7 Rear Case Replacement: step 37, image 1 of 2 iPhone 7 Rear Case Replacement: step 37, image 2 of 2
      • Remove the following Phillips screws securing the rear camera bracket to the rear case:
      • One 1.3 mm screw
      • One 2.5 mm screw
      Ask FixBot
    3. iPhone 7 Rear Case Replacement: step 38, image 1 of 1
      • Remove the bracket.
      Ask FixBot
    4. iPhone 7 Rear Case Replacement: step 39, image 1 of 2 iPhone 7 Rear Case Replacement: step 39, image 2 of 2
      • Use the pointed end of a spudger to pry up and disconnect the antenna bus connector, just left of the rear camera module.
      Ask FixBot
    5. iPhone 7 Rear Case Replacement: step 40, image 1 of 1
      • Remove the two 1.2 mm tri-point screws securing the upper cable bracket.
      Ask FixBot
    6. iPhone 7 Rear Case Replacement: step 41, image 1 of 2 iPhone 7 Rear Case Replacement: step 41, image 2 of 2
      • Remove the upper cable bracket.
      Ask FixBot
    7. iPhone 7 Rear Case Replacement: step 42, image 1 of 2 iPhone 7 Rear Case Replacement: step 42, image 2 of 2
      • Use the flat end of a spudger to disconnect the upper cable connector.
      Ask FixBot
    8. iPhone 7 Rear Case Replacement: step 43, image 1 of 2 iPhone 7 Rear Case Replacement: step 43, image 2 of 2
      • Remove the four Phillips screws securing the Wi-Fi antenna:
      • Three 1.2 mm screws
      • One 1.7 mm screw
      Ask FixBot
    9. iPhone 7 Rear Case Replacement: step 44, image 1 of 2 iPhone 7 Rear Case Replacement: step 44, image 2 of 2
      • Remove the top left antenna.
      Ask FixBot
    10. iPhone 7 Rear Case Replacement: step 45, image 1 of 1
      • Remove the following Phillips screws:
      • One 1.3 mm screw
      • One 2.2 mm screw
      Ask FixBot
    11. iPhone 7 Rear Case Replacement: step 46, image 1 of 2 iPhone 7 Rear Case Replacement: step 46, image 2 of 2
      Ask FixBot
    12. iPhone 7 Rear Case Replacement: step 47, image 1 of 1
      Standoff Screwdriver for iPhones
      $5.49
      Buy
      • Remove the 2.2 mm standoff screw from the grounding bracket.
      • Standoff screws are best removed using a standoff screwdriver or bit.
      • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
      Ask FixBot
    13. iPhone 7 Rear Case Replacement: step 48, image 1 of 2 iPhone 7 Rear Case Replacement: step 48, image 2 of 2
      Buy
      • Use tweezers to gently bend the logic board grounding bracket out of the way.
      Ask FixBot
    1. iPhone 7 Rear Case Replacement, Lightning Connector Assembly: step 49, image 1 of 2 iPhone 7 Rear Case Replacement, Lightning Connector Assembly: step 49, image 2 of 2
      • Use the point of a spudger to disconnect the lower cable connector.
      Ask FixBot
    2. iPhone 7 Rear Case Replacement: step 50, image 1 of 1
      $5.49
      Buy
      • Remove the following screws:
      • One 1.4 mm Phillips screw
      • Three 2.2 mm standoff screws
      Ask FixBot
    3. iPhone 7 Rear Case Replacement: step 51, image 1 of 2 iPhone 7 Rear Case Replacement: step 51, image 2 of 2
      • Use the point of a spudger to move the SIM card eject plunger out of the logic board's way.
      Ask FixBot
    4. iPhone 7 Rear Case Replacement: step 52, image 1 of 2 iPhone 7 Rear Case Replacement: step 52, image 2 of 2
      • Use the flat end of a spudger to gently lift the battery connector end of the logic board up.
      • Make sure you're not pulling against any cables. If you feel resistance, check all cables, connectors, and components are clear of the board.
      Ask FixBot
    5. iPhone 7 Rear Case Replacement: step 53, image 1 of 3 iPhone 7 Rear Case Replacement: step 53, image 2 of 3 iPhone 7 Rear Case Replacement: step 53, image 3 of 3
      • Lift the battery connector end of the logic board and pull it up and out of the rear case.
      • Be careful not to snag the logic board on any cables.
      Ask FixBot
    6. iPhone 7 Rear Case Replacement: step 54, image 1 of 1
      • Remove the 2.9 mm Phillips screw from the lightning connector.
      Ask FixBot
    7. iPhone 7 Rear Case Replacement: step 55, image 1 of 2 iPhone 7 Rear Case Replacement: step 55, image 2 of 2
      • Remove the spring contact from the lightning connector.
      Ask FixBot
    8. iPhone 7 Rear Case Replacement: step 56, image 1 of 1
      • Remove the two 1.6 mm Phillips screws securing the lightning connector cable in place.
      Ask FixBot
    9. iPhone 7 Rear Case Replacement: step 57, image 1 of 3 iPhone 7 Rear Case Replacement: step 57, image 2 of 3 iPhone 7 Rear Case Replacement: step 57, image 3 of 3
      • Remove the two stickers covering the screws that secure the lightning connector to the bottom of the rear case.
      Ask FixBot
    10. iPhone 7 Rear Case Replacement: step 58, image 1 of 1
      • Remove the two 1.3 mm Phillips screws from the rear case.
      Ask FixBot
    11. iPhone 7 Rear Case Replacement: step 59, image 1 of 2 iPhone 7 Rear Case Replacement: step 59, image 2 of 2
      • Use the pointed end of a spudger to separate the two microphones from the bottom of the rear case.
      Ask FixBot
    12. iPhone 7 Rear Case Replacement: step 60, image 1 of 1
      • Heating the lower edge of the iPhone will help soften the adhesive securing Lightning connector cable, making it easier to remove.
      • Use a hairdryer or reheat your iOpener to heat the lower edge of the phone.
      • Wait for about a minute, allowing the adhesive to warm up before proceeding to the next step.
      Ask FixBot
    13. iPhone 7 Rear Case Replacement: step 61, image 1 of 3 iPhone 7 Rear Case Replacement: step 61, image 2 of 3 iPhone 7 Rear Case Replacement: step 61, image 3 of 3
      • Starting from the middle of the phone, slide an opening pick underneath the lightning connector to separate it from the rear case.
      Ask FixBot
    14. iPhone 7 Rear Case Replacement: step 62, image 1 of 3 iPhone 7 Rear Case Replacement: step 62, image 2 of 3 iPhone 7 Rear Case Replacement: step 62, image 3 of 3
      • Continue to slide the pick towards the lightning connector to further separate the assembly from the rear case.
      Ask FixBot
    15. iPhone 7 Rear Case Replacement: step 63, image 1 of 2 iPhone 7 Rear Case Replacement: step 63, image 2 of 2
      • Continue to slide the pick underneath the lightning connecter assembly.
      • Stop sliding the pick once it passes the battery.
      Ask FixBot
    16. iPhone 7 Rear Case Replacement: step 64, image 1 of 3 iPhone 7 Rear Case Replacement: step 64, image 2 of 3 iPhone 7 Rear Case Replacement: step 64, image 3 of 3
      • Starting at the corner of the phone, slide the pick underneath the assembly towards the lightning connector.
      • Stop sliding the pick when it reaches the lightning connector.
      Ask FixBot
    17. iPhone 7 Rear Case Replacement: step 65, image 1 of 2 iPhone 7 Rear Case Replacement: step 65, image 2 of 2
      • Gently pull the lightning connector out of its hole on the rear case.
      Ask FixBot
    18. iPhone 7 Rear Case Replacement: step 66, image 1 of 2 iPhone 7 Rear Case Replacement: step 66, image 2 of 2
      • Slide a pick below the lightning connector to further separate the lightning connector assembly from the rear case.
      • Continue to slide the pick until the lightning connector assembly is no longer adhered to the rear case.
      Ask FixBot
    19. iPhone 7 Rear Case Replacement: step 67, image 1 of 3 iPhone 7 Rear Case Replacement: step 67, image 2 of 3 iPhone 7 Rear Case Replacement: step 67, image 3 of 3
      • Remove the lightning connector assembly.
      • Before installing or replacing the Lightning connector assembly:
      • Use a plastic tool to scour any bits of adhesive residue from the rear case.
      • Make sure the Lightning connector assembly is correctly positioned so that the two white dots on the iPhone's rear case show through the two circular cutouts in the Lightning flex cable. If they don't, the flex cable will remain misaligned and you won't be able to reconnect it to its socket on the logic board.
      Ask FixBot
    20. iPhone 7 Rear Case Replacement: step 68, image 1 of 3 iPhone 7 Rear Case Replacement: step 68, image 2 of 3 iPhone 7 Rear Case Replacement: step 68, image 3 of 3
      • A rubber gasket on the bottom of the Lightning connector protects your iPhone from liquid and dust intrusion. If you are installing a new Lightning connector assembly, you may need to carefully remove and transfer the gasket to the new part.
      • The small adhesive patch on the bottom of each microphone also protects your iPhone from liquid and dust intrusion. For best results, replace the two adhesive patches before installing your Lightning connector assembly.
      Ask FixBot
    1. iPhone 7 Rear Case Replacement, Rear Case Battery: step 69, image 1 of 2 iPhone 7 Rear Case Replacement, Rear Case Battery: step 69, image 2 of 2
      Buy
      • Use a pair of tweezers with blunt tips to peel back one of the adhesive strips on the lower edge of the battery.
      Ask FixBot
    2. iPhone 7 Rear Case Replacement: step 70, image 1 of 2 iPhone 7 Rear Case Replacement: step 70, image 2 of 2
      • Use a pair of tweezers with blunt tips to peel back the other adhesive strip on the lower edge of the battery.
      Ask FixBot
    3. iPhone 7 Rear Case Replacement: step 71, image 1 of 3 iPhone 7 Rear Case Replacement: step 71, image 2 of 3 iPhone 7 Rear Case Replacement: step 71, image 3 of 3
      • Try to keep the strips flat and unwrinkled during this procedure; wrinkled strips will stick together and break instead of pulling out cleanly.
      • Slowly pull one battery adhesive tab away from the battery, toward the bottom of the iPhone.
      • Pull steadily, maintaining constant tension on the strip until it slips out from between the battery and the rear case. For best results, pull the strip at a 60º angle or less.
      • The strip will stretch to many times its original length. Continue pulling and re-grab the strip near the battery if necessary.
      Ask FixBot
    4. iPhone 7 Rear Case Replacement: step 72, image 1 of 3 iPhone 7 Rear Case Replacement: step 72, image 2 of 3 iPhone 7 Rear Case Replacement: step 72, image 3 of 3
      • Repeat the previous step for the second strip.
      • Hold down the battery as you remove the second strip, or the strip may fling the battery when it separates from the case.
      • If you removed both adhesive strips successfully, skip the next step.
      • Otherwise, if either of the adhesive strips broke off underneath the battery and could not be retrieved, continue with the next step below.
      Ask FixBot
    5. iPhone 7 Rear Case Replacement: step 73, image 1 of 2 iPhone 7 Rear Case Replacement: step 73, image 2 of 2
      Plastic Cards
      $2.99
      Buy
      • If you successfully removed both adhesive strips, move on to the next step. Otherwise, you will need to pry the battery from the rear case.
      • Prepare an iOpener and apply it to the back of the rear case, directly over the battery. Alternatively, you can apply heat using a heat gun or hair dryer.
      • After about a minute, remove the iOpener, flip the phone over and use a plastic card to break up any remaining adhesive behind the battery.
      • Avoid bending the battery. Damage to the battery may release dangerous chemicals, and could start a fire.
      • Do not pry under the top third of the battery, you may damage the volume button ribbon cable.
      Ask FixBot
    6. iPhone 7 Rear Case Replacement: step 74, image 1 of 1
      • Remove the battery from the rear case.
      • When installing the battery, refer to this guide to replace your battery's adhesive strips.
      Ask FixBot
    1. iPhone 7 Rear Case Replacement, Power and Volume Control Cable: step 75, image 1 of 2 iPhone 7 Rear Case Replacement, Power and Volume Control Cable: step 75, image 2 of 2
      • Two 1.9 mm screws securing the power button.
      • Three 2.3 mm screws securing the volume buttons.
      Ask FixBot
    2. iPhone 7 Rear Case Replacement: step 76, image 1 of 2 iPhone 7 Rear Case Replacement: step 76, image 2 of 2
      • Remove the following 1.3 mm Phillips screws:
      • One screw beside the rear-facing camera
      • One screw on the rear case
      Ask FixBot
    3. iPhone 7 Rear Case Replacement: step 77, image 1 of 2 iPhone 7 Rear Case Replacement: step 77, image 2 of 2
      • From the outside of the phone, push the hold switch into the rear case with the point of a spudger.
      • This action will free the hold switch and gasket from the rear case.
      Ask FixBot
    4. iPhone 7 Rear Case Replacement: step 78, image 1 of 2 iPhone 7 Rear Case Replacement: step 78, image 2 of 2
      Buy
      • Use a pair of tweezers to remove the rear-facing camera.
      Ask FixBot
    5. iPhone 7 Rear Case Replacement: step 79, image 1 of 2 iPhone 7 Rear Case Replacement: step 79, image 2 of 2
      • Moving from power button side of the phone, use an opening pick to separate the adhesive holding the antenna flex cable to the rear case.
      Ask FixBot
    6. iPhone 7 Rear Case Replacement: step 80, image 1 of 2 iPhone 7 Rear Case Replacement: step 80, image 2 of 2
      • Slide the point of an opening pick underneath the antenna flex cable towards the top of the phone, separating the remaining adhesive.
      Ask FixBot
    7. iPhone 7 Rear Case Replacement: step 81, image 1 of 2 iPhone 7 Rear Case Replacement: step 81, image 2 of 2
      • Use tweezers to move the antenna flex cable away from the edge of the phone, freeing the screw bracket from the rear case.
      • Remove the antenna flex cable.
      Ask FixBot
    8. iPhone 7 Rear Case Replacement: step 82, image 1 of 1
      • Remove the 2.3 mm standoff screw securing the flash bracket to the rear case.
      • Standoff screws are best removed using an [linked product missing or disabled: IF145-343] and driver handle.
      Ask FixBot
    9. iPhone 7 Rear Case Replacement: step 83, image 1 of 2 iPhone 7 Rear Case Replacement: step 83, image 2 of 2
      • Remove the flash bracket.
      Ask FixBot
    10. iPhone 7 Rear Case Replacement: step 84, image 1 of 2 iPhone 7 Rear Case Replacement: step 84, image 2 of 2
      • Use the point of a spudger to gently unseat the flash module.
      Ask FixBot
    11. iPhone 7 Rear Case Replacement: step 85, image 1 of 2 iPhone 7 Rear Case Replacement: step 85, image 2 of 2
      Halberd Spudger
      $2.99
      Buy
      • Use the blade of a Halberd spudger to separate the adhesive holding the microphone to the rear case.
      Ask FixBot
    12. iPhone 7 Rear Case Replacement: step 86, image 1 of 2 iPhone 7 Rear Case Replacement: step 86, image 2 of 2
      • Gently fold the power button module from the edge of the rear case.
      Ask FixBot
    13. iPhone 7 Rear Case Replacement: step 87, image 1 of 3 iPhone 7 Rear Case Replacement: step 87, image 2 of 3 iPhone 7 Rear Case Replacement: step 87, image 3 of 3
      • Slide the blade of a halberd spudger under the power button end of the button cable to separate it from the adhesive on the rear case.
      • Continue to separate the adhesive by moving the blade towards the top of the phone.
      Ask FixBot
    14. iPhone 7 Rear Case Replacement: step 88, image 1 of 3 iPhone 7 Rear Case Replacement: step 88, image 2 of 3 iPhone 7 Rear Case Replacement: step 88, image 3 of 3
      • Continue to move the blade of the halberd spudger underneath the power and volume control cable.
      • Move slowly to make sure that the cable is not damaged during removal.
      Ask FixBot
    15. iPhone 7 Rear Case Replacement: step 89, image 1 of 3 iPhone 7 Rear Case Replacement: step 89, image 2 of 3 iPhone 7 Rear Case Replacement: step 89, image 3 of 3
      • Slide the halberd spudger under the volume control portion of the button cable.
      • Gently slide the blade underneath the cable towards the bottom of the phone, separating the remaining adhesive.
      Ask FixBot
    16. iPhone 7 Rear Case Replacement: step 90, image 1 of 1
      • Remove the power and volume control cable.
      Ask FixBot
    1. iPhone 7 Rear Case Replacement, Power Button: step 91, image 1 of 2 iPhone 7 Rear Case Replacement, Power Button: step 91, image 2 of 2
      • Pull the clip towards the bottom of the phone and lift up to free it from the bracket.
      Ask FixBot
    2. iPhone 7 Rear Case Replacement: step 92, image 1 of 2 iPhone 7 Rear Case Replacement: step 92, image 2 of 2
      • Remove the clip from the rear case.
      Ask FixBot
    3. iPhone 7 Rear Case Replacement: step 93, image 1 of 2 iPhone 7 Rear Case Replacement: step 93, image 2 of 2
      • Push the lower end of the power button bracket up off of peg securing it.
      Ask FixBot
    4. iPhone 7 Rear Case Replacement: step 94, image 1 of 2 iPhone 7 Rear Case Replacement: step 94, image 2 of 2
      • Pull the bracket from the rear case.
      Ask FixBot
    5. iPhone 7 Rear Case Replacement: step 95, image 1 of 2 iPhone 7 Rear Case Replacement: step 95, image 2 of 2
      • Use the pointed end of a spudger to push the power button cover out of the rear case.
      • Remove the power button cover.
      Ask FixBot
    1. iPhone 7 Rear Case Replacement, Volume Buttons: step 96, image 1 of 2 iPhone 7 Rear Case Replacement, Volume Buttons: step 96, image 2 of 2
      • Pull the volume button clip towards the bottom of the phone to free it from the bracket.
      Ask FixBot
    2. iPhone 7 Rear Case Replacement: step 97, image 1 of 2 iPhone 7 Rear Case Replacement: step 97, image 2 of 2
      • Pull the clip towards the top of the phone to remove it.
      Ask FixBot
    3. iPhone 7 Rear Case Replacement: step 98, image 1 of 3 iPhone 7 Rear Case Replacement: step 98, image 2 of 3 iPhone 7 Rear Case Replacement: step 98, image 3 of 3
      Ask FixBot
    4. iPhone 7 Rear Case Replacement: step 99, image 1 of 2 iPhone 7 Rear Case Replacement: step 99, image 2 of 2
      • Slide the flat end of a spudger underneath the bottom edge of the volume button bracket.
      • Adjust the spudger so that it can move away from the rear case without contacting the protruding peg that is on the volume button.
      • Rotate the spudger to pop the bracket off of the peg on the volume button.
      Ask FixBot
    5. iPhone 7 Rear Case Replacement: step 100, image 1 of 2 iPhone 7 Rear Case Replacement: step 100, image 2 of 2
      Ask FixBot
    6. iPhone 7 Rear Case Replacement: step 101, image 1 of 3 iPhone 7 Rear Case Replacement: step 101, image 2 of 3 iPhone 7 Rear Case Replacement: step 101, image 3 of 3
      • Repeat the procedure to remove the second volume button bracket.
      Ask FixBot
    7. iPhone 7 Rear Case Replacement: step 102, image 1 of 3 iPhone 7 Rear Case Replacement: step 102, image 2 of 3 iPhone 7 Rear Case Replacement: step 102, image 3 of 3
      • Use the pointed end of a spudger to push each of the volume button covers out of the rear case.
      • Remove the volume button covers.
      Ask FixBot
    1. iPhone 7 Rear Case Replacement, Rear Case: step 103, image 1 of 3 iPhone 7 Rear Case Replacement, Rear Case: step 103, image 2 of 3 iPhone 7 Rear Case Replacement, Rear Case: step 103, image 3 of 3
      • Use the point of a spudger to push the left rubber speaker vent out of the rear case.
      Ask FixBot
    2. iPhone 7 Rear Case Replacement: step 104, image 1 of 1
      • Remove the right rubber speaker vent from the rear case.
      Ask FixBot
    3. iPhone 7 Rear Case Replacement: step 105, image 1 of 1
      • Remove the 1.5 mm Phillips screw securing the grounding bracket.
      Ask FixBot
    4. iPhone 7 Rear Case Replacement: step 106, image 1 of 1
      • Remove the grounding bracket.
      Ask FixBot
    5. iPhone 7 Rear Case Replacement: step 107, image 1 of 1
      • Only the rear case remains.
      Ask FixBot
73 other people completed this guide.
Author
with
Scott Havard
51,476 Reputation
31 Guides authored
10 Guide Comments
Great manual. I was successful in this repair but bought a rear case with small parts. Safes up a lot of work and time :)
Dreetn - Reply Share
Great Guide!
There are some components that may need to be transferred to your new case, which are not in this guide:
1 speaker screens
2 screen mounting catches
3 put the SIM card tray ejector pin back in BEFORE the logic board. I inserted it before mounting the logic board, otherwise the pin may fall out.
Mike - Reply Share
Hello everyone!
Has anyone had problems with reception, especially the 4G network, after replacing the body with a non-original one?
thank you and sorry for my terrible english!
Giovanni Fasoli - Reply Share
Merci tres bon tutoriel tout c’est bien passé
jean.dujardin - Reply Share
HIW much cost to changing it
ishfaqbhat11 - Reply Share
Past 24 Hours: 9
Past 7 Days: 48
Past 30 Days: 340
All Time: 179,105
