iPhone 7 Plus Rear-Facing Cameras Replacement
    1. iPhone 7 Plus Rear-Facing Cameras Replacement, Pentalobe Screws: step 1, image 1 of 1
      • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 3.4 mm pentalobe screws at the bottom edge of the iPhone (using a P2 screw bit, if you have a set of bits).
      • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
      Ask FixBot
    1. iPhone 7 Plus Rear-Facing Cameras Replacement, Mark your opening picks: step 2, image 1 of 3 iPhone 7 Plus Rear-Facing Cameras Replacement, Mark your opening picks: step 2, image 2 of 3 iPhone 7 Plus Rear-Facing Cameras Replacement, Mark your opening picks: step 2, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone 7 Plus Rear-Facing Cameras Replacement, Anti-Clamp instructions: step 3, image 1 of 3 iPhone 7 Plus Rear-Facing Cameras Replacement, Anti-Clamp instructions: step 3, image 2 of 3 iPhone 7 Plus Rear-Facing Cameras Replacement, Anti-Clamp instructions: step 3, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
      • Squeeze the cups together to apply suction to the desired area.
      • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      Ask FixBot
    2. iPhone 7 Plus Rear-Facing Cameras Replacement: step 4, image 1 of 3 iPhone 7 Plus Rear-Facing Cameras Replacement: step 4, image 2 of 3 iPhone 7 Plus Rear-Facing Cameras Replacement: step 4, image 3 of 3
      • Pull the blue handle forwards to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Ask FixBot
    3. iPhone 7 Plus Rear-Facing Cameras Replacement: step 5, image 1 of 2 iPhone 7 Plus Rear-Facing Cameras Replacement: step 5, image 2 of 2
      • Heat an iOpener and thread it through the arms of the Anti-Clamp.
      • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
      • Fold the iOpener so it lays on the bottom edge of the iPhone.
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • Insert an opening pick into the gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next three steps.
      Ask FixBot
    4. iPhone 7 Plus Rear-Facing Cameras Replacement, Heat the display: step 6, image 1 of 1
      • The next three steps show how to separate the screen using a suction cup.
      • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
      • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
      Ask FixBot
    5. iPhone 7 Plus Rear-Facing Cameras Replacement, Separate the display: step 7, image 1 of 2 iPhone 7 Plus Rear-Facing Cameras Replacement, Separate the display: step 7, image 2 of 2
      • Apply a suction cup to the lower half of the front panel, just above the home button.
      • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
      Ask FixBot
    6. iPhone 7 Plus Rear-Facing Cameras Replacement: step 8, image 1 of 3 iPhone 7 Plus Rear-Facing Cameras Replacement: step 8, image 2 of 3 iPhone 7 Plus Rear-Facing Cameras Replacement: step 8, image 3 of 3
      • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
      • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
      Ask FixBot
    7. iPhone 7 Plus Rear-Facing Cameras Replacement: step 9, image 1 of 3 iPhone 7 Plus Rear-Facing Cameras Replacement: step 9, image 2 of 3 iPhone 7 Plus Rear-Facing Cameras Replacement: step 9, image 3 of 3
      • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
      • Stop near the top left corner of the display.
      • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
      Ask FixBot
    8. iPhone 7 Plus Rear-Facing Cameras Replacement, Screen information: step 10, image 1 of 1
      • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
      Ask FixBot
    9. iPhone 7 Plus Rear-Facing Cameras Replacement: step 11, image 1 of 3 iPhone 7 Plus Rear-Facing Cameras Replacement: step 11, image 2 of 3 iPhone 7 Plus Rear-Facing Cameras Replacement: step 11, image 3 of 3
      • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
      • Don't insert your pick more than 3 mm, as you may damage the display cables.
      Ask FixBot
    10. iPhone 7 Plus Rear-Facing Cameras Replacement: step 12, image 1 of 2 iPhone 7 Plus Rear-Facing Cameras Replacement: step 12, image 2 of 2
      • Gently pull up on the suction cup to lift up the bottom edge of the display.
      • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
      • Pull on the small nub on the suction cup to remove it from the front panel.
      Ask FixBot
    11. iPhone 7 Plus Rear-Facing Cameras Replacement: step 13, image 1 of 3 iPhone 7 Plus Rear-Facing Cameras Replacement: step 13, image 2 of 3 iPhone 7 Plus Rear-Facing Cameras Replacement: step 13, image 3 of 3
      • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
      Ask FixBot
    12. iPhone 7 Plus Rear-Facing Cameras Replacement: step 14, image 1 of 2 iPhone 7 Plus Rear-Facing Cameras Replacement: step 14, image 2 of 2
      • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
      Ask FixBot
    13. iPhone 7 Plus Rear-Facing Cameras Replacement: step 15, image 1 of 3 iPhone 7 Plus Rear-Facing Cameras Replacement: step 15, image 2 of 3 iPhone 7 Plus Rear-Facing Cameras Replacement: step 15, image 3 of 3
      • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
      • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
      • Lean the display against something to keep it propped up while you're working on the phone.
      Ask FixBot
    1. iPhone 7 Plus Rear-Facing Cameras Replacement, Battery Disconnection: step 16, image 1 of 1
      • Remove the following four tri-point Y000 screws securing the lower display cable bracket to the logic board:
      • Three 1.2 mm screws
      • One 2.6 mm screw
      Ask FixBot
    2. iPhone 7 Plus Rear-Facing Cameras Replacement: step 17, image 1 of 2 iPhone 7 Plus Rear-Facing Cameras Replacement: step 17, image 2 of 2
      • Remove the lower display cable bracket.
      Ask FixBot
    3. iPhone 7 Plus Rear-Facing Cameras Replacement: step 18, image 1 of 3 iPhone 7 Plus Rear-Facing Cameras Replacement: step 18, image 2 of 3 iPhone 7 Plus Rear-Facing Cameras Replacement: step 18, image 3 of 3
      • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
      • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
      Ask FixBot
    1. iPhone 7 Plus Rear-Facing Cameras Replacement, Display Assembly: step 19, image 1 of 3 iPhone 7 Plus Rear-Facing Cameras Replacement, Display Assembly: step 19, image 2 of 3 iPhone 7 Plus Rear-Facing Cameras Replacement, Display Assembly: step 19, image 3 of 3
      • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
      • Use the flat end of a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
      • To re-attach press connectors, press down on one end until it clicks into place, then repeat on the other end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
      • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
      Ask FixBot
    2. iPhone 7 Plus Rear-Facing Cameras Replacement: step 20, image 1 of 3 iPhone 7 Plus Rear-Facing Cameras Replacement: step 20, image 2 of 3 iPhone 7 Plus Rear-Facing Cameras Replacement: step 20, image 3 of 3
      • Remove the three tri-point Y000 screws securing the bracket over the front panel sensor assembly connector:
      • One 1.3 mm screw
      • Two 1.0 mm screws
      • Remove the bracket.
      Ask FixBot
    3. iPhone 7 Plus Rear-Facing Cameras Replacement: step 21, image 1 of 2 iPhone 7 Plus Rear-Facing Cameras Replacement: step 21, image 2 of 2
      • Disconnect the front panel sensor assembly connector from its socket on the logic board.
      • This press connector should also be reconnected one end at a time to minimize the risk of bending.
      Ask FixBot
    4. iPhone 7 Plus Rear-Facing Cameras Replacement: step 22, image 1 of 1
      Ask FixBot
    1. iPhone 7 Plus Rear-Facing Cameras Replacement, Rear-Facing Cameras: step 23, image 1 of 1
      Standoff Screwdriver for iPhones
      $5.49
      Buy
      • Remove the two screws securing the rear-facing camera bracket:
      • One 1.6 mm Phillips screw
      • One 2.2 mm standoff screw
      • Standoff screws are best removed using a standoff screwdriver or bit.
      • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
      Ask FixBot
    2. iPhone 7 Plus Rear-Facing Cameras Replacement: step 24, image 1 of 1
      • Remove the bracket covering the rear-facing camera assembly.
      Ask FixBot
    3. iPhone 7 Plus Rear-Facing Cameras Replacement: step 25, image 1 of 3 iPhone 7 Plus Rear-Facing Cameras Replacement: step 25, image 2 of 3 iPhone 7 Plus Rear-Facing Cameras Replacement: step 25, image 3 of 3
      • Use an iFixit opening tool or a fingernail to disconnect the two camera cable connectors by prying them straight up from their sockets.
      Ask FixBot
    4. iPhone 7 Plus Rear-Facing Cameras Replacement: step 26, image 1 of 2 iPhone 7 Plus Rear-Facing Cameras Replacement: step 26, image 2 of 2
      • Use the flat end of a spudger to pry up the rear-facing camera assembly from the top edge of the iPhone.
      Ask FixBot
    5. iPhone 7 Plus Rear-Facing Cameras Replacement: step 27, image 1 of 1
      • Remove the rear-facing camera assembly.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or search our Answers forum for help.
62 other people completed this guide.
Jeff Suovanen
455,057 Reputation
259 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
12 Guide Comments
Has anybody done the replacement of the cameras glass? I need to do it on mine because it cracked but I want to know if I have to add any type of adhesive and if so which kind/brand?
pxolo10 - Reply Share
Its super easy to do.. I have a guide complete but it has no pictures :(
You can follow this guide.. its kind of the same procedure, all you have to do is take out the old and put the new one in. if it does not stick properly, like it being loose, you can then apply a little bit of super glue or any adhesive.. the phone will not be waterproof/ water resistant tho.
iPhone 6 Camera Lens Replacement
nicolay.94 - Reply Share
i would not recommend superglue (cyanoacrylate). i’ve seen it fogging up nearby surfaces while hardening. could be bad on the lens.
Lorz Lorenz - Reply Share
Hello. Does anyone know how to replace the rear camera’s flashlight. My iphone 7 plus rear camera and flashlight need to be replaced. Not only the camera itself. I didn’t find the flashlight sparepart itself in this website :(
Andrew Samuel - Reply Share
Hi. Are there any replacement for rear camera and flashlight component for iphone 7 plus. Because my rear camera and flashlight is not working. And I didn’t find any component in Ifixit. Please help.
Past 24 Hours: 10
Past 7 Days: 58
Past 30 Days: 233
All Time: 86,270
