iPhone 7 Plus LCD and Digitizer Replacement
    1. iPhone 7 Plus LCD and Digitizer Replacement, Pentalobe Screws: step 1, image 1 of 1
      • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 3.4 mm pentalobe screws at the bottom edge of the iPhone (using a P2 screw bit, if you have a set of bits).
      • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
      Ask FixBot
    1. iPhone 7 Plus LCD and Digitizer Replacement, Mark your opening picks: step 2, image 1 of 3 iPhone 7 Plus LCD and Digitizer Replacement, Mark your opening picks: step 2, image 2 of 3 iPhone 7 Plus LCD and Digitizer Replacement, Mark your opening picks: step 2, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone 7 Plus LCD and Digitizer Replacement, Taping Over The Display: step 3, image 1 of 3 iPhone 7 Plus LCD and Digitizer Replacement, Taping Over The Display: step 3, image 2 of 3 iPhone 7 Plus LCD and Digitizer Replacement, Taping Over The Display: step 3, image 3 of 3
      • If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
      • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      • If the broken glass makes it difficult to get a suction cup to stick in the next few steps, try folding a strong piece of tape (such as duct tape) into a handle and lifting the display with that instead.
      Ask FixBot
    1. iPhone 7 Plus LCD and Digitizer Replacement, Anti-Clamp instructions: step 4, image 1 of 3 iPhone 7 Plus LCD and Digitizer Replacement, Anti-Clamp instructions: step 4, image 2 of 3 iPhone 7 Plus LCD and Digitizer Replacement, Anti-Clamp instructions: step 4, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
      • Squeeze the cups together to apply suction to the desired area.
      • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      Ask FixBot
    2. iPhone 7 Plus LCD and Digitizer Replacement: step 5, image 1 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 5, image 2 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 5, image 3 of 3
      • Pull the blue handle forwards to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Ask FixBot
    3. iPhone 7 Plus LCD and Digitizer Replacement: step 6, image 1 of 2 iPhone 7 Plus LCD and Digitizer Replacement: step 6, image 2 of 2
      • Heat an iOpener and thread it through the arms of the Anti-Clamp.
      • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
      • Fold the iOpener so it lays on the bottom edge of the iPhone.
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • Insert an opening pick into the gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next three steps.
      Ask FixBot
    4. iPhone 7 Plus LCD and Digitizer Replacement, Heat the display: step 7, image 1 of 1
      • The next three steps show how to separate the screen using a suction cup.
      • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
      • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
      Ask FixBot
    5. iPhone 7 Plus LCD and Digitizer Replacement, Separate the display: step 8, image 1 of 2 iPhone 7 Plus LCD and Digitizer Replacement, Separate the display: step 8, image 2 of 2
      • Apply a suction cup to the lower half of the front panel, just above the home button.
      • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
      Ask FixBot
    6. iPhone 7 Plus LCD and Digitizer Replacement: step 9, image 1 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 9, image 2 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 9, image 3 of 3
      • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
      • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
      Ask FixBot
    7. iPhone 7 Plus LCD and Digitizer Replacement: step 10, image 1 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 10, image 2 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 10, image 3 of 3
      • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
      • Stop near the top left corner of the display.
      • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
      Ask FixBot
    8. iPhone 7 Plus LCD and Digitizer Replacement, Screen information: step 11, image 1 of 1
      • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
      Ask FixBot
    9. iPhone 7 Plus LCD and Digitizer Replacement: step 12, image 1 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 12, image 2 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 12, image 3 of 3
      • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
      • Don't insert your pick more than 3 mm, as you may damage the display cables.
      Ask FixBot
    10. iPhone 7 Plus LCD and Digitizer Replacement: step 13, image 1 of 2 iPhone 7 Plus LCD and Digitizer Replacement: step 13, image 2 of 2
      • Gently pull up on the suction cup to lift up the bottom edge of the display.
      • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
      • Pull on the small nub on the suction cup to remove it from the front panel.
      Ask FixBot
    11. iPhone 7 Plus LCD and Digitizer Replacement: step 14, image 1 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 14, image 2 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 14, image 3 of 3
      • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
      Ask FixBot
    12. iPhone 7 Plus LCD and Digitizer Replacement: step 15, image 1 of 2 iPhone 7 Plus LCD and Digitizer Replacement: step 15, image 2 of 2
      • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
      Ask FixBot
    13. iPhone 7 Plus LCD and Digitizer Replacement: step 16, image 1 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 16, image 2 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 16, image 3 of 3
      • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
      • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
      • Lean the display against something to keep it propped up while you're working on the phone.
      Ask FixBot
    1. iPhone 7 Plus LCD and Digitizer Replacement, Battery Disconnection: step 17, image 1 of 1
      • Remove the following four tri-point Y000 screws securing the lower display cable bracket to the logic board:
      • Three 1.2 mm screws
      • One 2.6 mm screw
      Ask FixBot
    2. iPhone 7 Plus LCD and Digitizer Replacement: step 18, image 1 of 2 iPhone 7 Plus LCD and Digitizer Replacement: step 18, image 2 of 2
      • Remove the lower display cable bracket.
      Ask FixBot
    3. iPhone 7 Plus LCD and Digitizer Replacement: step 19, image 1 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 19, image 2 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 19, image 3 of 3
      • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
      • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
      Ask FixBot
    1. iPhone 7 Plus LCD and Digitizer Replacement, Display Assembly: step 20, image 1 of 3 iPhone 7 Plus LCD and Digitizer Replacement, Display Assembly: step 20, image 2 of 3 iPhone 7 Plus LCD and Digitizer Replacement, Display Assembly: step 20, image 3 of 3
      • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
      • Use the flat end of a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
      • To re-attach press connectors, press down on one end until it clicks into place, then repeat on the other end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
      • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
      Ask FixBot
    2. iPhone 7 Plus LCD and Digitizer Replacement: step 21, image 1 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 21, image 2 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 21, image 3 of 3
      • Remove the three tri-point Y000 screws securing the bracket over the front panel sensor assembly connector:
      • One 1.3 mm screw
      • Two 1.0 mm screws
      • Remove the bracket.
      Ask FixBot
    3. iPhone 7 Plus LCD and Digitizer Replacement: step 22, image 1 of 2 iPhone 7 Plus LCD and Digitizer Replacement: step 22, image 2 of 2
      • Disconnect the front panel sensor assembly connector from its socket on the logic board.
      • This press connector should also be reconnected one end at a time to minimize the risk of bending.
      Ask FixBot
    4. iPhone 7 Plus LCD and Digitizer Replacement: step 23, image 1 of 1
      Ask FixBot
    1. iPhone 7 Plus LCD and Digitizer Replacement, Earpiece Speaker: step 24, image 1 of 1
      • Remove the five Phillips screws securing the earpiece speaker bracket:
      • Two 1.8 mm screws
      • One 2.3 mm screw
      • One 2.4 mm screw
      • One 2.8 mm screw
      Ask FixBot
    2. iPhone 7 Plus LCD and Digitizer Replacement: step 25, image 1 of 1
      • Remove the earpiece speaker bracket.
      Ask FixBot
    3. iPhone 7 Plus LCD and Digitizer Replacement: step 26, image 1 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 26, image 2 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 26, image 3 of 3
      • Use the flat end of a spudger to lift the front-facing camera from its housing.
      • Gently bend the camera ribbon cable to the side to clear the way to the earpiece speaker underneath.
      Ask FixBot
    4. iPhone 7 Plus LCD and Digitizer Replacement: step 27, image 1 of 1
      • Remove the earpiece speaker.
      • Don't touch the four spring contacts with your fingers—your skin oils may cause a malfunction. If accidentally touched, clean the contacts gently with isopropyl alcohol (90% or higher).
      Ask FixBot
    1. iPhone 7 Plus LCD and Digitizer Replacement, Front Camera and Sensor Cable: step 28, image 1 of 2 iPhone 7 Plus LCD and Digitizer Replacement, Front Camera and Sensor Cable: step 28, image 2 of 2
      • Gently fold the camera and attached ribbon cable toward the bottom of the iPhone to allow access to the components underneath.
      Ask FixBot
    2. iPhone 7 Plus LCD and Digitizer Replacement: step 29, image 1 of 2 iPhone 7 Plus LCD and Digitizer Replacement: step 29, image 2 of 2
      • The sensors on this step are fragile. To increase your chances of removing them without damage, use your iOpener or hair dryer to apply heat to the upper portion of the display before you proceed. Alternatively, add a drop or two of isopropyl alcohol and let it penetrate under the sensors before you pry them up.
      • Slide a spudger under the ambient light sensor flex cable, and lift the sensor out of its housing.
      Ask FixBot
    3. iPhone 7 Plus LCD and Digitizer Replacement: step 30, image 1 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 30, image 2 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 30, image 3 of 3
      • Slide the tip of a spudger underneath the proximity sensor flex cable, and lift the sensor out of its housing.
      Ask FixBot
    4. iPhone 7 Plus LCD and Digitizer Replacement: step 31, image 1 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 31, image 2 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 31, image 3 of 3
      • Insert the sharp edge of an iFixit opening tool underneath the camera assembly's flex cable, on the opposite side from the front-facing camera.
      • If necessary, use an iOpener or hair dryer to heat the top portion of the display and soften the adhesive securing the flex cable.
      • Pry up to separate the edge of the flex cable from the back of the display.
      Ask FixBot
    5. iPhone 7 Plus LCD and Digitizer Replacement: step 32, image 1 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 32, image 2 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 32, image 3 of 3
      • Insert the point of a spudger underneath the same portion of the flex cable that you separated in the previous step.
      • Continue separating the remainder of the flex cable, pushing the spudger toward the row of circular gold earpiece speaker contacts.
      Ask FixBot
    6. iPhone 7 Plus LCD and Digitizer Replacement: step 33, image 1 of 1
      • Continue using your spudger to carefully separate the last of the flex cable from the back of the display.
      Ask FixBot
    7. iPhone 7 Plus LCD and Digitizer Replacement: step 34, image 1 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 34, image 2 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 34, image 3 of 3
      • Remove the front camera and sensor cable assembly.
      • A piece of black double-sided insulating tape lies between the display and three rows of copper contacts on the back of the camera/sensor cable. It may remain stuck to the display, or it may come off with the cable.
      • When reassembling, verify the tape is in place, or else cover the contacts on the back of the cable with an appropriate tape, such as Kapton tape.
      Ask FixBot
    1. iPhone 7 Plus LCD and Digitizer Replacement, Home/Touch ID Sensor: step 35, image 1 of 1
      • Remove the four Y000 screws securing the bracket over the home/Touch ID sensor:
      • One 1.1 mm screw
      • Three 1.3 mm screws
      • During reassembly, be careful not to overtighten these screws, or your home button may not work.
      Ask FixBot
    2. iPhone 7 Plus LCD and Digitizer Replacement: step 36, image 1 of 1
      • Remove the bracket that secures the home/Touch ID sensor.
      Ask FixBot
    3. iPhone 7 Plus LCD and Digitizer Replacement: step 37, image 1 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 37, image 2 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 37, image 3 of 3
      Ask FixBot
    4. iPhone 7 Plus LCD and Digitizer Replacement: step 38, image 1 of 2 iPhone 7 Plus LCD and Digitizer Replacement: step 38, image 2 of 2
      • Carefully pry up the underlying connector and move it out of the way of the home/Touch ID cable.
      • It's very easy to damage your iPhone during this step. Work slowly and take care where you pry with your tool. If you damage the Touch ID hardware, it can only be replaced by Apple.
      • If the connector doesn't pry up easily, use a hair dryer or iOpener to heat and soften the adhesive securing the connector, and then try again.
      • Don't try to detach the connector completely—simply flip it up slightly so that the underlying home/Touch ID sensor cable can be removed.
      Ask FixBot
    5. iPhone 7 Plus LCD and Digitizer Replacement: step 39, image 1 of 1
      • Heating the area around the home/Touch ID sensor will help soften the adhesive holding its delicate cable in place, making it easier to remove safely.
      • Flip the display assembly over. Use a hairdryer or prepare an iOpener and apply it to the lower edge of the display for about 90 seconds in order to soften up the adhesive underneath.
      Ask FixBot
    6. iPhone 7 Plus LCD and Digitizer Replacement: step 40, image 1 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 40, image 2 of 3 iPhone 7 Plus LCD and Digitizer Replacement: step 40, image 3 of 3
      • Use an opening pick to gently separate the adhesive holding the home/Touch ID sensor cable to the back side of the display panel.
      Ask FixBot
    7. iPhone 7 Plus LCD and Digitizer Replacement: step 41, image 1 of 1
      • Remove the home/Touch ID sensor assembly by lifting it through the front side of the display.
      • To reinstall, first feed the cable through the hole in the front of the display.
      • Your replacement part may come with an extra Y000 screw already installed right of the Home Button. Remove the unnecessary screw so that you can reinstall the home button bracket.
      • Follow this guide to install replacement display adhesive on your screen.
      Ask FixBot
    1. iPhone 7 Plus LCD and Digitizer Replacement, LCD and Digitizer: step 42, image 1 of 3 iPhone 7 Plus LCD and Digitizer Replacement, LCD and Digitizer: step 42, image 2 of 3 iPhone 7 Plus LCD and Digitizer Replacement, LCD and Digitizer: step 42, image 3 of 3
      • Peel back the upper, rectangular portion of the LCD shield plate sticker to separate it from the flex cable underneath.
      • You don't need to remove the sticker completely unless you intend to replace it.
      Ask FixBot
    2. iPhone 7 Plus LCD and Digitizer Replacement: step 43, image 1 of 2 iPhone 7 Plus LCD and Digitizer Replacement: step 43, image 2 of 2
      • Use a Y000 driver to remove three 1.1 mm screws from one side of the display EMI shield.
      • If you have trouble loosening these screws, press the driver harder onto the screw as you turn it. If necessary, use the flat edge of your spudger to brace each display clip from behind so you can apply more pressure to the screws, without bending the clips.
      Ask FixBot
    3. iPhone 7 Plus LCD and Digitizer Replacement: step 44, image 1 of 1
      • Use a Y000 driver to remove two more 1.1 mm screws from the other side of the EMI shield.
      Ask FixBot
    4. iPhone 7 Plus LCD and Digitizer Replacement: step 45, image 1 of 1
      • Remove the 1.8 mm Phillips screw securing the EMI shield near the bottom of the display.
      Ask FixBot
    5. iPhone 7 Plus LCD and Digitizer Replacement: step 46, image 1 of 2 iPhone 7 Plus LCD and Digitizer Replacement: step 46, image 2 of 2
      • Lift the LCD shield plate while pressing down on the flex cable it surrounds.
      • Feed the flex cable through the cutout in the LCD shield plate, being careful not to snag it.
      Ask FixBot
    6. iPhone 7 Plus LCD and Digitizer Replacement: step 47, image 1 of 1
      • Remove the LCD shield plate.
      Ask FixBot
    7. iPhone 7 Plus LCD and Digitizer Replacement: step 48, image 1 of 1
      • Only the LCD and digitizer remains.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or search our Answers forum for help.
200 other people completed this guide.
Jeff Suovanen
455,048 Reputation
259 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
19 Guide Comments
Step 14 Pic# 3 the second cable damaged , what can i do ?!
Ameed Bader - Reply Share
If you damaged only the cable and nothing else, replacing the display should solve the problem—it will come with new cables attached.
Jeff Suovanen - Reply Share
For anyone performing hardware exchanges, there is a free app on Apple store called Dr. Phone that can be used to test the several hardware components… Nice to do before closing it up..
H. Alves - Reply Share
Has anyone else had trouble getting the Y000 screws out from the bracket over the home/Touch ID sensor? All other Y000 came out no problem. These are fighting me. The driver seems to be spinning in place as if too big. Follow up question. If I strip these screws, any idea how to get them out then?
jferguson757 - Reply Share
In my situation the Y screw behind the Home/Fingerprint Button seems to be GLUED ON by design to prevent inexperienced non-certified Apple replacers to remove it. So what I did was left it on to prevent stripping the screw and breaking the button. I just CAREFULLY BENT the metal bracket AT AN ANGLE so that I can maneuver the whole assembly into the hole of the screen and remove it.
Eric Vengeance - Reply Share
Past 24 Hours: 9
Past 7 Days: 76
Past 30 Days: 310
All Time: 212,894
