Up to 20% off select tools
iPhone 7 Plus Front Camera and Sensor Cable Replacement
Views: 133K
View statistics:
Past 24 Hours:
18
Past 7 Days:
76
Past 30 Days:
295
All Time:
132,780
Comments: 208
190 comments on steps, 18 guide comments.
Go to guide comments
Completed: 121
121 people have marked this guide "completed." Will you be next?
Favorites: 8
8 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 40 minutes - 2 hours
Difficulty: Moderate
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace a faulty front camera on your iPhone 7 Plus. This camera is part of a larger assembly containing a microphone and proximity/ambient light sensors, all of which is replaced as a single unit.
    1. iPhone 7 Plus Front Camera and Sensor Cable Replacement, Pentalobe Screws: step 1, image 1 of 1
      • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 3.4 mm pentalobe screws at the bottom edge of the iPhone (using a P2 screw bit, if you have a set of bits).
      • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
      Ask FixBot
    1. iPhone 7 Plus Front Camera and Sensor Cable Replacement, Mark your opening picks: step 2, image 1 of 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement, Mark your opening picks: step 2, image 2 of 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement, Mark your opening picks: step 2, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone 7 Plus Front Camera and Sensor Cable Replacement, Anti-Clamp instructions: step 3, image 1 of 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement, Anti-Clamp instructions: step 3, image 2 of 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement, Anti-Clamp instructions: step 3, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
      • Squeeze the cups together to apply suction to the desired area.
      • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      Ask FixBot
    2. iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 4, image 1 of 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 4, image 2 of 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 4, image 3 of 3
      • Pull the blue handle forwards to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Ask FixBot
    3. iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 5, image 1 of 2 iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 5, image 2 of 2
      • Heat an iOpener and thread it through the arms of the Anti-Clamp.
      • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
      • Fold the iOpener so it lays on the bottom edge of the iPhone.
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • Insert an opening pick into the gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next three steps.
      Ask FixBot
    4. iPhone 7 Plus Front Camera and Sensor Cable Replacement, Heat the display: step 6, image 1 of 1
      • The next three steps show how to separate the screen using a suction cup.
      • Apply a heated iOpener to the bottom edge of the screen for two minutes. This softens the adhesive securing it.
      • Alternatively, you can use a hair dryer or heat gun to heat the bottom half of the screen until it’s slightly too hot to touch
      • Improper use of a heat gun can destroy the display and/or battery—review this guide for instructions. To prevent screen damage, keep your heat source moving rather than focused on one spot.
      • For tips on using a hair dryer to soften adhesive, check out this guide.
      Ask FixBot
    5. iPhone 7 Plus Front Camera and Sensor Cable Replacement, Separate the display: step 7, image 1 of 2 iPhone 7 Plus Front Camera and Sensor Cable Replacement, Separate the display: step 7, image 2 of 2
      • Apply a suction cup to the lower half of the front panel, just above the home button.
      • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
      Ask FixBot
    6. iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 8, image 1 of 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 8, image 2 of 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 8, image 3 of 3
      • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
      • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
      Ask FixBot
    7. iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 9, image 1 of 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 9, image 2 of 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 9, image 3 of 3
      • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
      • Stop near the top left corner of the display.
      • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
      Ask FixBot
    8. iPhone 7 Plus Front Camera and Sensor Cable Replacement, Screen information: step 10, image 1 of 1
      • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
      Ask FixBot
    9. iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 11, image 1 of 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 11, image 2 of 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 11, image 3 of 3
      • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
      • Don't insert your pick more than 3 mm, as you may damage the display cables.
      Ask FixBot
    10. iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 12, image 1 of 2 iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 12, image 2 of 2
      • Gently pull up on the suction cup to lift up the bottom edge of the display.
      • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
      • Pull on the small nub on the suction cup to remove it from the front panel.
      Ask FixBot
    11. iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 13, image 1 of 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 13, image 2 of 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 13, image 3 of 3
      • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
      Ask FixBot
    12. iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 14, image 1 of 2 iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 14, image 2 of 2
      • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
      Ask FixBot
    13. iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 15, image 1 of 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 15, image 2 of 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 15, image 3 of 3
      • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
      • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
      • Lean the display against something to keep it propped up while you're working on the phone.
      Ask FixBot
    1. iPhone 7 Plus Front Camera and Sensor Cable Replacement, Battery Disconnection: step 16, image 1 of 1
      • Remove the following four tri-point Y000 screws securing the lower display cable bracket to the logic board:
      • Three 1.2 mm screws
      • One 2.6 mm screw
      Ask FixBot
    2. iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 17, image 1 of 2 iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 17, image 2 of 2
      • Remove the lower display cable bracket.
      Ask FixBot
    3. iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 18, image 1 of 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 18, image 2 of 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 18, image 3 of 3
      • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
      • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
      Ask FixBot
    1. iPhone 7 Plus Front Camera and Sensor Cable Replacement, Display Assembly: step 19, image 1 of 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement, Display Assembly: step 19, image 2 of 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement, Display Assembly: step 19, image 3 of 3
      • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
      • Use the flat end of a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
      • To re-attach press connectors, press down on one end until it clicks into place, then repeat on the other end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
      • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
      Ask FixBot
    2. iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 20, image 1 of 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 20, image 2 of 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 20, image 3 of 3
      • Remove the three tri-point Y000 screws securing the bracket over the front panel sensor assembly connector:
      • One 1.3 mm screw
      • Two 1.0 mm screws
      • Remove the bracket.
      Ask FixBot
    3. iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 21, image 1 of 2 iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 21, image 2 of 2
      • Disconnect the front panel sensor assembly connector from its socket on the logic board.
      • This press connector should also be reconnected one end at a time to minimize the risk of bending.
      Ask FixBot
    4. iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 22, image 1 of 1
      Ask FixBot
    1. iPhone 7 Plus Front Camera and Sensor Cable Replacement, Earpiece Speaker: step 23, image 1 of 1
      • Remove the five Phillips screws securing the earpiece speaker bracket:
      • Two 1.8 mm screws
      • One 2.3 mm screw
      • One 2.4 mm screw
      • One 2.8 mm screw
      Ask FixBot
    2. iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 24, image 1 of 1
      • Remove the earpiece speaker bracket.
      Ask FixBot
    3. iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 25, image 1 of 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 25, image 2 of 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 25, image 3 of 3
      • Use the flat end of a spudger to lift the front-facing camera from its housing.
      • Gently bend the camera ribbon cable to the side to clear the way to the earpiece speaker underneath.
      Ask FixBot
    4. iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 26, image 1 of 1
      • Remove the earpiece speaker.
      • Don't touch the four spring contacts with your fingers—your skin oils may cause a malfunction. If accidentally touched, clean the contacts gently with isopropyl alcohol (90% or higher).
      Ask FixBot
    1. iPhone 7 Plus Front Camera and Sensor Cable Replacement, Front Camera and Sensor Cable: step 27, image 1 of 2 iPhone 7 Plus Front Camera and Sensor Cable Replacement, Front Camera and Sensor Cable: step 27, image 2 of 2
      • Gently fold the camera and attached ribbon cable toward the bottom of the iPhone to allow access to the components underneath.
      Ask FixBot
    2. iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 28, image 1 of 2 iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 28, image 2 of 2
      • The sensors on this step are fragile. To increase your chances of removing them without damage, use your iOpener or hair dryer to apply heat to the upper portion of the display before you proceed. Alternatively, add a drop or two of isopropyl alcohol and let it penetrate under the sensors before you pry them up.
      • Slide a spudger under the ambient light sensor flex cable, and lift the sensor out of its housing.
      Ask FixBot
    3. iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 29, image 1 of 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 29, image 2 of 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 29, image 3 of 3
      • Slide the tip of a spudger underneath the proximity sensor flex cable, and lift the sensor out of its housing.
      Ask FixBot
    4. iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 30, image 1 of 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 30, image 2 of 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 30, image 3 of 3
      • Insert the sharp edge of an iFixit opening tool underneath the camera assembly's flex cable, on the opposite side from the front-facing camera.
      • If necessary, use an iOpener or hair dryer to heat the top portion of the display and soften the adhesive securing the flex cable.
      • Pry up to separate the edge of the flex cable from the back of the display.
      Ask FixBot
    5. iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 31, image 1 of 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 31, image 2 of 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 31, image 3 of 3
      • Insert the point of a spudger underneath the same portion of the flex cable that you separated in the previous step.
      • Continue separating the remainder of the flex cable, pushing the spudger toward the row of circular gold earpiece speaker contacts.
      Ask FixBot
    6. iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 32, image 1 of 1
      • Continue using your spudger to carefully separate the last of the flex cable from the back of the display.
      Ask FixBot
    7. iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 33, image 1 of 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 33, image 2 of 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: step 33, image 3 of 3
      • Remove the front camera and sensor cable assembly.
      • A piece of black double-sided insulating tape lies between the display and three rows of copper contacts on the back of the camera/sensor cable. It may remain stuck to the display, or it may come off with the cable.
      • When reassembling, verify the tape is in place, or else cover the contacts on the back of the cable with an appropriate tape, such as Kapton tape.
      Ask FixBot
121 other people completed this guide.
Author
with
Jeff Suovanen
455,911 Reputation
259 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
18 Guide Comments
Do I have to do this if i buy a new phone screen or do they usually come with one?
Tom Robinson - Reply Share
If this Speaker is Not Working or it has any Noise Issues, Apple will Replace whole Front Display Section. Under their Policy, they won’t repair it. Neither Fully Replace your iPhone, only Front Panel Replacement.
macktm - Reply Share
Does 7 and 7plus has the same camera/sensor strip?
Salman Siddeeque Ali - Reply Share
No, it’s a bit different.
The spacing between the metal dots for the earspeaker isn’t there on the 7+ model, but is on the 7.
Benjamin Convents - Reply Share
Anybody got a solution to earpiece not working after ribbon swap?
Seems to be mega common with this repair. I’ve heard a few ideas but nothing concrete. More advice about this issue would be greatly appreciated by me and a bunch of people.
michael wehner - Reply Share
Past 24 Hours: 18
Past 7 Days: 76
Past 30 Days: 295
All Time: 132,780
