Up to 20% off select tools
iPhone 7 Lightning Connector Assembly Replacement
Views: 472K
View statistics:
Past 24 Hours:
20
Past 7 Days:
198
Past 30 Days:
891
All Time:
472,455
Comments: 390
336 comments on steps, 54 guide comments.
Go to guide comments
Completed: 284
284 people have marked this guide "completed." Will you be next?
Favorites: 31
31 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Difficult
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
Is your phone not detecting your charging cable? Does your charging port feel loose? Has the microphone gone deaf? Did you clean the lightning port, but it is still not charging? It might be time to replace your Lightning connector assembly. Use this guide to replace the Lightning connector assembly which includes the lower microphones, antenna cable, and Lightning connector.
Note that this repair does require a fair amount of disassembly, and it will require time and caution.
Video Overview
    1. iPhone 7 Lightning Connector Assembly Replacement, Pentalobe Screws: step 1, image 1 of 1
      • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
      • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
      Ask FixBot
    1. iPhone 7 Lightning Connector Assembly Replacement, Mark your opening picks: step 2, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement, Mark your opening picks: step 2, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement, Mark your opening picks: step 2, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone 7 Lightning Connector Assembly Replacement, Anti-Clamp instructions: step 3, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement, Anti-Clamp instructions: step 3, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement, Anti-Clamp instructions: step 3, image 3 of 3
      Tool used on this step:
      Clampy - Anti-Clamp
      $24.95
      Buy
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
      • Squeeze the cups together to apply suction to the desired area.
      • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      Ask FixBot
    2. iPhone 7 Lightning Connector Assembly Replacement: step 4, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 4, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 4, image 3 of 3
      • Pull the blue handle forwards to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Ask FixBot
    3. iPhone 7 Lightning Connector Assembly Replacement: step 5, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 5, image 2 of 2
      • Heat an iOpener and thread it through the arms of the Anti-Clamp.
      • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
      • Fold the iOpener so it lays on the bottom edge of the iPhone.
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • Insert an opening pick into the gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next three steps.
      Ask FixBot
    4. iPhone 7 Lightning Connector Assembly Replacement, Heat the display: step 6, image 1 of 1
      • The next three steps show how to separate the screen using a suction cup.
      • Apply a heated iOpener to the bottom edge of the screen for two minutes. This softens the adhesive securing it.
      • Alternatively, you can use a hair dryer or heat gun to heat the bottom half of the screen until it’s slightly too hot to touch
      • Improper use of a heat gun can destroy the display and/or battery—review this guide for instructions. To prevent screen damage, keep your heat source moving rather than focused on one spot.
      • For tips on using a hair dryer to soften adhesive, check out this guide.
      Ask FixBot
    5. iPhone 7 Lightning Connector Assembly Replacement, Separate the display: step 7, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement, Separate the display: step 7, image 2 of 2
      • Apply a suction cup to the lower half of the front panel, just above the home button.
      • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
      Ask FixBot
    6. iPhone 7 Lightning Connector Assembly Replacement: step 8, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 8, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 8, image 3 of 3
      • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
      • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
      Ask FixBot
    7. iPhone 7 Lightning Connector Assembly Replacement: step 9, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 9, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 9, image 3 of 3
      • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
      • Stop near the top left corner of the display.
      • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
      Ask FixBot
    8. iPhone 7 Lightning Connector Assembly Replacement, Screen information: step 10, image 1 of 1
      • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
      Ask FixBot
    9. iPhone 7 Lightning Connector Assembly Replacement: step 11, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 11, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 11, image 3 of 3
      • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
      • Don't insert your pick more than 3 mm, as you may damage the display cables.
      Ask FixBot
    10. iPhone 7 Lightning Connector Assembly Replacement: step 12, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 12, image 2 of 2
      • Gently pull up on the suction cup to lift up the bottom edge of the display.
      • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
      • Pull on the small nub on the suction cup to remove it from the front panel.
      Ask FixBot
    11. iPhone 7 Lightning Connector Assembly Replacement: step 13, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 13, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 13, image 3 of 3
      • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
      Ask FixBot
    12. iPhone 7 Lightning Connector Assembly Replacement: step 14, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 14, image 2 of 2
      • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
      Ask FixBot
    13. iPhone 7 Lightning Connector Assembly Replacement: step 15, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 15, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 15, image 3 of 3
      • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
      • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
      • Lean the display against something to keep it propped up while you're working on the phone.
      Ask FixBot
    1. iPhone 7 Lightning Connector Assembly Replacement, Battery Disconnection: step 16, image 1 of 1
      Tri-point Y000 Screwdriver
      $5.99
      Buy
      Ask FixBot
    2. iPhone 7 Lightning Connector Assembly Replacement: step 17, image 1 of 1
      • Remove the lower connector bracket.
      Ask FixBot
    3. iPhone 7 Lightning Connector Assembly Replacement: step 18, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 18, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 18, image 3 of 3
      • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
      • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
      Ask FixBot
    1. iPhone 7 Lightning Connector Assembly Replacement, Display Assembly: step 19, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement, Display Assembly: step 19, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement, Display Assembly: step 19, image 3 of 3
      • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
      • Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
      • To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
      • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
      Ask FixBot
    2. iPhone 7 Lightning Connector Assembly Replacement: step 20, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 20, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 20, image 3 of 3
      • Remove the two 1.3 mm Phillips #000 screws securing the bracket over the front panel sensor assembly connector.
      • Some phones could be Y000. Apple started using Y000 for these at some point in the middle of the product's lifecycle.
      Ask FixBot
    3. iPhone 7 Lightning Connector Assembly Replacement: step 21, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 21, image 2 of 2
      • Disconnect the front panel sensor assembly connector from its socket on the logic board.
      • This press connector should also be reconnected one end at a time to minimize the risk of bending.
      Ask FixBot
    4. iPhone 7 Lightning Connector Assembly Replacement: step 22, image 1 of 1
      Ask FixBot
    1. iPhone 7 Lightning Connector Assembly Replacement, Barometric Vent: step 23, image 1 of 1
      • Remove the two 1.9 mm Phillips screws securing the barometric vent to the rear case.
      Ask FixBot
    2. iPhone 7 Lightning Connector Assembly Replacement: step 24, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 24, image 2 of 2
      • Remove the vent.
      Ask FixBot
    1. iPhone 7 Lightning Connector Assembly Replacement, Taptic Engine: step 25, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement, Taptic Engine: step 25, image 2 of 2
      • Use the flat end of a spudger to disconnect the Taptic Engine connector from its socket on the logic board.
      Ask FixBot
    2. iPhone 7 Lightning Connector Assembly Replacement: step 26, image 1 of 1
      • Remove the three 1.6 mm Phillips screws securing the Taptic Engine to the rear case.
      Ask FixBot
    3. iPhone 7 Lightning Connector Assembly Replacement: step 27, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 27, image 2 of 2
      • Remove the Taptic Engine.
      Ask FixBot
    1. iPhone 7 Lightning Connector Assembly Replacement, Speaker Assembly: step 28, image 1 of 1
      • Remove the Phillips screw securing the Wi-Fi diversity antenna to the rear case:
      • One 3.2 mm screw
      Ask FixBot
    2. iPhone 7 Lightning Connector Assembly Replacement: step 29, image 1 of 1
      • Remove the following three Phillips screws securing the speaker to the rear case:
      • Two 1.3 mm screws
      • One 2.0 mm screw
      Ask FixBot
    3. iPhone 7 Lightning Connector Assembly Replacement: step 30, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 30, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 30, image 3 of 3
      • Use the point of a spudger to lift the two antenna cable connectors up off of the sockets on the logic board.
      Ask FixBot
    4. iPhone 7 Lightning Connector Assembly Replacement: step 31, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 31, image 2 of 2
      Buy
      • Use tweezers to derout the antenna cables from their bracket on the logic board.
      Ask FixBot
    5. iPhone 7 Lightning Connector Assembly Replacement: step 32, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 32, image 2 of 2
      • Use tweezers to remove the antenna cables from the clip on the speaker.
      • Make sure to grasp the cable near the clip in order to avoid damaging the cable.
      Ask FixBot
    6. iPhone 7 Lightning Connector Assembly Replacement: step 33, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 33, image 2 of 2
      • Use the tip of a spudger to slide the speaker assembly towards the logic board and off of the rear case.
      Ask FixBot
    7. iPhone 7 Lightning Connector Assembly Replacement: step 34, image 1 of 1
      • Remove the speaker.
      Ask FixBot
    1. iPhone 7 Lightning Connector Assembly Replacement, SIM Card: step 35, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement, SIM Card: step 35, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement, SIM Card: step 35, image 3 of 3
      • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
      • Press to eject the tray.
      • This may require a significant amount of force. However, ensure the eject tool is properly aligned beforehand as to not damage the eject mechanism inside the phone.
      • Remove the SIM card tray assembly from the iPhone.
      • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
      Ask FixBot
    1. iPhone 7 Lightning Connector Assembly Replacement, Logic Board Connectors: step 36, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement, Logic Board Connectors: step 36, image 2 of 2
      • Use the flat end of a spudger to disconnect the rear-facing camera connector.
      Ask FixBot
    2. iPhone 7 Lightning Connector Assembly Replacement: step 37, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 37, image 2 of 2
      • Remove the following Phillips screws securing the rear camera bracket to the rear case:
      • One 1.3 mm screw
      • One 2.5 mm screw
      Ask FixBot
    3. iPhone 7 Lightning Connector Assembly Replacement: step 38, image 1 of 1
      • Remove the bracket.
      Ask FixBot
    4. iPhone 7 Lightning Connector Assembly Replacement: step 39, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 39, image 2 of 2
      • Use the pointed end of a spudger to pry up and disconnect the antenna bus connector, just left of the rear camera module.
      Ask FixBot
    5. iPhone 7 Lightning Connector Assembly Replacement: step 40, image 1 of 1
      • Remove the two 1.2 mm tri-point screws securing the upper cable bracket.
      Ask FixBot
    6. iPhone 7 Lightning Connector Assembly Replacement: step 41, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 41, image 2 of 2
      • Remove the upper cable bracket.
      Ask FixBot
    7. iPhone 7 Lightning Connector Assembly Replacement: step 42, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 42, image 2 of 2
      • Use the flat end of a spudger to disconnect the upper cable connector.
      Ask FixBot
    8. iPhone 7 Lightning Connector Assembly Replacement: step 43, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 43, image 2 of 2
      • Remove the four Phillips screws securing the Wi-Fi antenna:
      • Three 1.2 mm screws
      • One 1.7 mm screw
      Ask FixBot
    9. iPhone 7 Lightning Connector Assembly Replacement: step 44, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 44, image 2 of 2
      • Remove the top left antenna.
      Ask FixBot
    10. iPhone 7 Lightning Connector Assembly Replacement: step 45, image 1 of 1
      • Remove the following Phillips screws:
      • One 1.3 mm screw
      • One 2.2 mm screw
      Ask FixBot
    11. iPhone 7 Lightning Connector Assembly Replacement: step 46, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 46, image 2 of 2
      Ask FixBot
    12. iPhone 7 Lightning Connector Assembly Replacement: step 47, image 1 of 1
      Standoff Screwdriver for iPhones
      $5.49
      Buy
      • Remove the 2.2 mm standoff screw from the grounding bracket.
      • Standoff screws are best removed using a standoff screwdriver or bit.
      • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
      Ask FixBot
    13. iPhone 7 Lightning Connector Assembly Replacement: step 48, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 48, image 2 of 2
      Buy
      • Use tweezers to gently bend the logic board grounding bracket out of the way.
      Ask FixBot
    1. iPhone 7 Lightning Connector Assembly Replacement, Lightning Connector Assembly: step 49, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement, Lightning Connector Assembly: step 49, image 2 of 2
      • Use the point of a spudger to disconnect the lower cable connector.
      Ask FixBot
    2. iPhone 7 Lightning Connector Assembly Replacement: step 50, image 1 of 1
      $5.49
      Buy
      • Remove the following screws:
      • One 1.4 mm Phillips screw
      • Three 2.2 mm standoff screws
      Ask FixBot
    3. iPhone 7 Lightning Connector Assembly Replacement: step 51, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 51, image 2 of 2
      • Use the point of a spudger to move the SIM card eject plunger out of the logic board's way.
      Ask FixBot
    4. iPhone 7 Lightning Connector Assembly Replacement: step 52, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 52, image 2 of 2
      • Use the flat end of a spudger to gently lift the battery connector end of the logic board up.
      • Make sure you're not pulling against any cables. If you feel resistance, check all cables, connectors, and components are clear of the board.
      Ask FixBot
    5. iPhone 7 Lightning Connector Assembly Replacement: step 53, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 53, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 53, image 3 of 3
      • Lift the battery connector end of the logic board and pull it up and out of the rear case.
      • Be careful not to snag the logic board on any cables.
      Ask FixBot
    6. iPhone 7 Lightning Connector Assembly Replacement: step 54, image 1 of 1
      • Remove the 2.9 mm Phillips screw from the lightning connector.
      Ask FixBot
    7. iPhone 7 Lightning Connector Assembly Replacement: step 55, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 55, image 2 of 2
      • Remove the spring contact from the lightning connector.
      Ask FixBot
    8. iPhone 7 Lightning Connector Assembly Replacement: step 56, image 1 of 1
      • Remove the two 1.6 mm Phillips screws securing the lightning connector cable in place.
      Ask FixBot
    9. iPhone 7 Lightning Connector Assembly Replacement: step 57, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 57, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 57, image 3 of 3
      • Remove the two stickers covering the screws that secure the lightning connector to the bottom of the rear case.
      Ask FixBot
    10. iPhone 7 Lightning Connector Assembly Replacement: step 58, image 1 of 1
      • Remove the two 1.3 mm Phillips screws from the rear case.
      Ask FixBot
    11. iPhone 7 Lightning Connector Assembly Replacement: step 59, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 59, image 2 of 2
      • Use the pointed end of a spudger to separate the two microphones from the bottom of the rear case.
      Ask FixBot
    12. iPhone 7 Lightning Connector Assembly Replacement: step 60, image 1 of 1
      • Heating the lower edge of the iPhone will help soften the adhesive securing Lightning connector cable, making it easier to remove.
      • Use a hairdryer or reheat your iOpener to heat the lower edge of the phone.
      • Wait for about a minute, allowing the adhesive to warm up before proceeding to the next step.
      Ask FixBot
    13. iPhone 7 Lightning Connector Assembly Replacement: step 61, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 61, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 61, image 3 of 3
      • Starting from the middle of the phone, slide an opening pick underneath the lightning connector to separate it from the rear case.
      Ask FixBot
    14. iPhone 7 Lightning Connector Assembly Replacement: step 62, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 62, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 62, image 3 of 3
      • Continue to slide the pick towards the lightning connector to further separate the assembly from the rear case.
      Ask FixBot
    15. iPhone 7 Lightning Connector Assembly Replacement: step 63, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 63, image 2 of 2
      • Continue to slide the pick underneath the lightning connecter assembly.
      • Stop sliding the pick once it passes the battery.
      Ask FixBot
    16. iPhone 7 Lightning Connector Assembly Replacement: step 64, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 64, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 64, image 3 of 3
      • Starting at the corner of the phone, slide the pick underneath the assembly towards the lightning connector.
      • Stop sliding the pick when it reaches the lightning connector.
      Ask FixBot
    17. iPhone 7 Lightning Connector Assembly Replacement: step 65, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 65, image 2 of 2
      • Gently pull the lightning connector out of its hole on the rear case.
      Ask FixBot
    18. iPhone 7 Lightning Connector Assembly Replacement: step 66, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 66, image 2 of 2
      • Slide a pick below the lightning connector to further separate the lightning connector assembly from the rear case.
      • Continue to slide the pick until the lightning connector assembly is no longer adhered to the rear case.
      Ask FixBot
    19. iPhone 7 Lightning Connector Assembly Replacement: step 67, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 67, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 67, image 3 of 3
      • Remove the lightning connector assembly.
      • Before installing or replacing the Lightning connector assembly:
      • Use a plastic tool to scour any bits of adhesive residue from the rear case.
      • Make sure the Lightning connector assembly is correctly positioned so that the two white dots on the iPhone's rear case show through the two circular cutouts in the Lightning flex cable. If they don't, the flex cable will remain misaligned and you won't be able to reconnect it to its socket on the logic board.
      Ask FixBot
    20. iPhone 7 Lightning Connector Assembly Replacement: step 68, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 68, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 68, image 3 of 3
      • A rubber gasket on the bottom of the Lightning connector protects your iPhone from liquid and dust intrusion. If you are installing a new Lightning connector assembly, you may need to carefully remove and transfer the gasket to the new part.
      • The small adhesive patch on the bottom of each microphone also protects your iPhone from liquid and dust intrusion. For best results, replace the two adhesive patches before installing your Lightning connector assembly.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Don't forget to reapply the display adhesive before reinstalling the display.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 7 Answers community for troubleshooting help.
284 other people completed this guide.
Author
with
Scott Havard
51,476 Reputation
31 Guides authored
54 Guide Comments
The old ones were so easy! Why did Apple have to put the thing under the board!!!???
Christopher Crawford - Reply Share
Prob to discourage people from replacing it themselves instead of sending to apple
Elwen Omara - Reply Share
I dunno. It was a pain, but surprisingly I got mine fixed. When I took it to the apple store they flat out told me that they wouldn’t fix it at all. I couldn’t even send it in to them. Something about no communication with the logic board and they refused to touch it. Thankfully the guides are detailed enough for goofs like me to be successful.
Ray Bieze - Reply Share
Ho un problema dopo aver installato il nuovo connettore. Quando l’iphone e scarico, inserendo il cavo, appare sul display il simbolo batteria. Una volta acceso il cavo non viene più segnalato e la ricarica non continua. Cosa può essere?
Fabio - Reply Share
Salve ho lo stesso problema,qual è il problema?
lorenzo Serra - Reply Share
Past 24 Hours: 20
Past 7 Days: 198
Past 30 Days: 891
All Time: 472,455
